Kiteboard images with 6D
Started Apr 7, 2013 | Discussions
leroyvanhee
Senior MemberPosts: 1,828
Apr 7, 2013
Canon EOS 6D
Imaginik
Regular MemberPosts: 248Gear list
Re: Kiteboard images with 6D
In reply to leroyvanhee, Apr 7, 2013
I really like the first image. Out of curiosity, how many OOF shots did you have while shooting these with the 6D?
Thanks for sharing your pictures!
Nik
I'm here to learn
 Imaginik's gear list:Imaginik's gear list
Canon PowerShot S70 Canon EOS 550D Canon EOS 6D Canon EF 50mm f/1.8 II Sigma 17-50mm F2.8 EX DC OS HSM +2 more
ASR45
Forum ProPosts: 34,354Gear list
Nice action shots
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +7 more
j2l3m7
Senior MemberPosts: 4,044Gear list
You did a great job taking the photos
Thanks for posting, have a great day.
John
 j2l3m7's gear list:j2l3m7's gear list
Canon EOS 70D Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon PowerShot SX60 HS Canon EF 85mm f/1.8 USM +10 more
leroyvanhee
In reply to Imaginik, Apr 7, 2013
I don't remember many being out-of-focus, maybe 1 in 5. The camera does pretty well when the subject is clearly distinguished from the background (bird against the sky). Where it seems to have trouble is when the surroundings are confussing (bird in a bush). This is probably true of any AF.
Ultradan
Contributing MemberPosts: 553
Is it me or are the first two out of focus - on the rider anyway? (which I presume is what you would want in focus)
The third one looks ok but I'm not sure even that one is locked on?
Ultradan
In reply to Ultradan, Apr 7, 2013
Also what lens are you using out of interest? the EF 400mm L?
leroyvanhee
Yes, the lens is 100 - 400 L. I've noticed that the first focus of a series can be off. So I usually take several in a row. I don't know if the camera refocuses under continuous drive, so I push the shutter button each time. The AF seems to be more accurate if it doesn't change much.
Spad16
Senior MemberPosts: 1,072Gear list
Yes, that is true of any autofocus, and I think the 6D is probably better than most. in finding the subject against a difficult background.. Nice photos.
/Neil
 Spad16's gear list:Spad16's gear list
Canon EOS 6D Canon EOS 700D Canon EF 400mm f/5.6L USM Canon EF 17-40mm f/4.0L USM Canon EF 100mm f/2.8 Macro USM +2 more
Johnyguy
Regular MemberPosts: 203
ofcourse its refocus or lock on focus in continuous drive otherwise what would be the point having  8 fps continuous shoting on some cameras or 4.5 on the 6d
usedtobedontrustme
Contributing MemberPosts: 945Gear list
In reply to Johnyguy, Apr 7, 2013
If you have the camera focus set to AI Servo, you shouldn't have to push the shutter button repeatedly to refocus. It will keep focus on the original subject even if it is moving fast. If you use "Back button focus" good constant focus is just about guaranteed.
Some of my pics are in my DPReview Gallery
dt
 usedtobedontrustme's gear list:usedtobedontrustme's gear list
Canon EOS 6D Canon EOS 7D Mark II Canon EF 50mm f/1.8 II Canon EF 16-35mm f/2.8L II USM Canon EF 100-400mm f/4.5-5.6L IS USM +4 more
Johnyguy
In reply to usedtobedontrustme, Apr 7, 2013
dt
Thank you ,that is what i tryed  to explain.
Ultradan
In reply to Johnyguy, Apr 8, 2013
I also own the 100-400 L, it is a very slow lens for focusing I find and I use a 1DMKII.
Learnphotography
Forum MemberPosts: 56
In reply to leroyvanhee, Apr 8, 2013
Tracking sensitivity in custom menu is the answer. put to -1 or -2.
MisterBG
Veteran MemberPosts: 5,783
In reply to Ultradan, Apr 8, 2013
I'd agree, on the first one the focus point looks like the wake about 2-3 metres behind the skier, although there is also motion blur.
>The only way of discovering the limits of the possible is to venture a little way past them into the impossible.
leroyvanhee
Sorry, I mis-read you comment the first time around. I think the focus is off on the first image (bird in a bush). It seems to be on the water closer to the camera. I disagree that the second shot is off (bird in the sky). Here's a couple of 1:1 crops that make it clearer. Both images have 0 sharpening and 0 noise reduction.
Bird in a bush
Bird in the sky
FranKois
Junior MemberPosts: 36Gear list
In reply to usedtobedontrustme, Apr 22, 2013
No text.
 FranKois's gear list:FranKois's gear list
Canon PowerShot G3 Canon EOS 6D Canon EF 24-105mm f/4L IS USM +1 more
MrScorpio
Senior MemberPosts: 1,365Gear list
In reply to leroyvanhee, Apr 24, 2013
Good shots. My favorite is no 3. Nice to see acceptable sharpness with the 6D AF!
 MrScorpio's gear list:MrScorpio's gear list
Olympus OM-D E-M5 Canon EOS 6D Nikon Df Canon EF 35mm f/2.0 Canon EF 50mm f/1.4 USM +14 more
