Fuji EF-20
Started Apr 7, 2013 | Discussions
Mark1t
Regular MemberPosts: 246Gear list
Fuji EF-20
Apr 7, 2013
I want to buy a fuji EF-20, but i want to trigger it with my studio flash. Is this possible? Will it recognize another flash?
svx94
Senior MemberPosts: 2,289Gear list
Re: Fuji EF-20
In reply to Mark1t, Apr 7, 2013
I think you will lost TTL by doing so.  If TTL is not important to you, you can actual get some old manual flash that capable to do manual output adjustment, and use a cheap trigger.  I think Fuji's flashes are way over priced for the function they can provide.
 svx94's gear list:svx94's gear list
Nikon Coolpix 4500 Nikon D700 Fujifilm X-M1 Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon PC-E Nikkor 24mm f/3.5D ED +9 more
Mark1t
Mark1t OP
Re: Fuji EF-20
In reply to svx94, Apr 7, 2013
But will it recognize another flash automatically?
ddayan
New MemberPosts: 8
Re: Fuji EF-20
If I remember correctly the ef-20 only works in auto/ttl mode and can't be operated as a slave i.e. can't be triggered by another flash. the ef-x20 can, its smaller & looks better however it's more expensive and you can't tilt it for flash bouncing. Another option is the EF-42 which is more powerful but much bigger than the other two.
Mark1t
Mark1t OP
Re: Fuji EF-20
In reply to ddayan, Apr 7, 2013
Thank you! Will the nikon flash work with fuji x100?
ddayan
New MemberPosts: 8
Re: Fuji EF-20
no reason it shouldn't work in manual mode (if the flash has a light sensor), not sure if you can get TTL to work on non fuji flashes
Mark1t
Mark1t OP
Re: Fuji EF-20
thakyou
