Nikon 85mm F1.8G I bought into the hype about how sharp it is. and " how its the best and sharpest"
Started Apr 7, 2013 | Discussions
Reilly Diefenbach
Reilly Diefenbach Veteran Member • Posts: 9,962
Re: Wait a Minute!!
Panos at 85mm with a 36MP camera?
Clark Hampton
Clark Hampton Senior Member • Posts: 2,856
Re: Nikon 85mm F1.8G I bought into the hype about how sh
I have a very old nikkor 85 1.8D and it is THE sharpest lens I own.  I even have an OLD 70-210 variable aperture (I think from around 1989) and it is amazingly sharp.  The 50 1.8G is also very sharp although newer. I love my old primes.  Who knew there was so much sharpness in them. The D800 shows just how good they are.
 Clark Hampton's gear list:Clark Hampton's gear list
Nikon D100 Nikon D200 Nikon D800 Nikon AF Nikkor 85mm f/1.8D Nikon AF Nikkor 135mm f/2D DC +4 more
RockyBalboa New Member • Posts: 23
Re: It's not hype...
Good decision , it should be really sharp even at 1.8 .
tektrader OP Senior Member • Posts: 1,460
Re: Wait a Minute!!
yes, I often do 140 MP stitched panoramas. AND print them at 30 inches x 70 inches. 36MP looks OK, But the stitched photos are magnificent.
I don't doubt some of you have a good copy of this 85mm lens, Mine was CRAP.
Just to close this off. The cat was asleep in the same spot tonight. Heres a photo taken in LIVE VIEW with my 70-200 at 85MM
Its way better than the other lens. Its obvious to me now it was faulty. Click on both of the live view cat photo's, then click "view original" and compare them. The 70-200 VR1 kicked the faulty 85mm F1.8's ass.
 tektrader's gear list:tektrader's gear list
Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon 200-500mm F5.6E ED VR +9 more
just Tony Senior Member • Posts: 1,262
Triangles vs. points of light
nathantw wrote:
One of the things that has never been shown with the f/1.8G is whether points of lights at the corners when shot at f/1.8 are pinpoints or triangle shape.
I haven't tried the 1.8G but I specifically tested the 1.4G for astrophotography. I found it to be not quite suitable for that purpose at 1.4 (check out the blue halos on the mercury lamps too):
85mm f/1.4 AFS-G at f/1.4. Really good for a 1.4 but those aren't pinpoints.
but it's much better by f/4.0, and I consider it to be excellent for a 1.4 design:
85mm f/1.4 AFS-G at f/4.0
These are 2:1 downsamplings at the lower left corner. The streaks extending to the lower right of the brighter lights are the poles that support the lights (it's not an optical problem). Additional light poles are visible to the upper right as well.
In my case I needed a lens that would provide pinpoints, or close it it, when wide open.
Both the 1.4 and 1.8 might be disappointing then.
If the f/1.8G does that then yes, I could have spent $1k less. If the lights are triangle shape, well, it was money well spent.
It's actually a question about whether the triangular smears are equivalent, and which lens cleans up first with stopping down.
(unknown member) Senior Member • Posts: 4,624
I agree, I have a few older wonderful lenses. One is a Nikkor-S 50MM 1.4  Really sharp, even wide open  and great rendition. I shoot with a D300.
Enjoy.....believe in yourself..
 Bajerunner's gear list:Bajerunner's gear list
Nikon D300 Nikon AF-Nikkor 80-200mm f/2.8D ED +8 more
Daisy AU
Daisy AU Senior Member • Posts: 1,564
Re: D800E F/1.8 example
anotherMike wrote:
A few notes:
1) IF you are focused precisely, you shouldn't get too much CA at the focus plane. See example I've provided. You WILL get CA in the out of focus areas. Most every lens you buy will do this wide open. Really only things like the exotics (200/2, etc) or the new Zeiss 135/2 Apo Sonnar are exempt from this. So you can't use this as an excuse to damn the lens, honestly. One must be realistic.
2) On a D800E, there is not a lens I own that is tack sharp corner to corner wide open other than my 200/2, and even that likes being nudged down a touch on the D800E. Again, one must be realistic about results.
3) IF you are properly focused, the 85/1.8G is one of the sharpest lenses you can mount on a D800E at the more regularly used apertures. I've shot a lot of glass in 30+ years (40+ Nikkors alone plus other brands) and this is definitely a very sharp lens - but as I've said, not wide open, and definitely not if you miss focus. You'll have to spend a lot more money to get anything that is even a smidge sharper. I've been there, tested that. I'm far from alone in this opinion, photozone, dxomark and others have come to the same conclusion.
The image provided is a 100% crop (crop needed because one can't upload a full sized image to dpreview gallieres) of a test chart taken at about 5 feet with the 85/1.8G on my D800E, on tripod, mirror lockup, shot delay, and properly live view focused. This is what you should be able to get with a flat target at this aperture. Go see if you can find the CA in this shot. Now - of course if you stop the lens down a bit sharpness will increase, but what I provide is a good realistic starting point of what your lens should be capable of wide open in the focused plane - again, areas in and out of focus will show fringing, just like every other fast lens I own except the 200/2, and that includes the 50/1.8G and the Sigma 35/1.4 btw.
Is this tack sharp? No. See point 1. But if you were to do the same thing with either older 85 Nikkor AFD, the Sigma, or even the 85/1.4G, you might be surprised to see which lens wins (it would be the 1.8G closely followed by the 1.4G). Again, one must get realistic about wide open results on this particularly demanding camera, and one must focus precisely.
-m
Interesting!  So, are you therefore saying that the Nikkor 85/1.4G is really not worth the expense?  .. and the Nikkor 85/1.8G would be enough?  What is better in the 1.4G then to justify the higher cost?  One of these lenses is next on my list, hence my question.
Thanks,
Daisy AU - Brisbane
 Daisy AU's gear list:Daisy AU's gear list
Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
ki11ua Forum Member • Posts: 58
From what I know, except from the additional 2/3 of a stop and better construction, it has a bit better bokeh, a bit faster AF and a bit better flare resistance, all mainly because of the better glasses used.
 ki11ua's gear list:ki11ua's gear list
Sony SLT-A55 Nikon D600 Nikon AF-S Nikkor 16-35mm F4G ED VR Sony DT 18-55mm F3.5-5.6 SAM Sony DT 35mm F1.8 SAM +6 more
Daisy AU
Thanks for that.  I will look at the 1.8G a bit closer, because it's considerably cheaper than the 1.4G.  But on the other hand, I don't have any 1.4 lenses.  Difficult choice, I think.
Thanks,
Daisy AU - Brisbane
Consider then the excellent Sigma 35mm 1.4, which is a much more useful lens for all-around use. Just my thought...
Daisy AU
Re: Wait a Minute!!
Hi,
Now I get it ... that is the problem ... you live DownUnder!    What if one our lovely couriers dropped the box in transit?  (just kidding)
Cheers
tektrader wrote:
I returned the Samyang primarily because wide open it wasnt any better than the 70-200 at F2.8. It was a bit soft.
The Nikon 85 F1.8 has way way more CA than the Samyang which IMO has limited its use. This lens is SOFTER than the 70-200. I am after the crispness and microfocus from the Nikon 85 as I want to use it for stitched panoramas. Doesnt seem I will get it.
BTW I did buy the lens from a USA business and it has a Nikon USA warranty inside. But I live in Australia so I have to send it back to New York now.
I quite liked the rendering of the Samyang, but it wasnt worth $400 extra seeing I already had a 70-200 which was just as sharp.
Samyang photo, Quite good at F8, This image was sharpened etc BTW
mistermejia wrote:
You returned your Samyang 85 1.4??  Now you are having problems with your Nikon 85 1.8?
Doesn't that tell you that there might be something wrong with your camera?  I have the Ronikon 85 1.4 too and i would NEVER sell that lens, at 1.4 my copy is already very sharp.  Something else is going on here, no?
Thanks,
Daisy AU - Brisbane
Daisy AU
I will, although I'm a Nikon devotee ... but I have broken the rule once (Tokina 11-16)  Thanks!
Thanks,
Daisy AU - Brisbane
Can I suggest you go and try one locally before you buy !!  Beat them around the head for a reasonable price. Wouldnt want you to go through what I just did.
Thanks,
Daisy AU - Brisbane
Daisy AU
Thanks,
Daisy AU - Brisbane
Although I know it is a lot cheaper for us here to order from the US, I do buy my lenses locally, but I order smaller gear from B&H in NY.
Thanks,
Daisy AU - Brisbane
nathantw Senior Member • Posts: 1,382
Re: Triangles vs. points of light
Holy Yikes, Batman! Thanks, Tony, for doing the test. That first one doesn't look good.
However, I did tests myself and the lights were pretty round (not perfect though). The magenta cast was removable in ViewNX2 that I use.
http://www.flickr.com/photos/nathantw/
Always have a camera with you and make sure you use it.
Thanks,
Daisy AU - Brisbane
I have a friend that was in the market for the 85mm f/1.4G. She wanted that one badly. I received mine, I tested it and I reported back to her to just get the 85 f/1.8G instead. The reason was that the advantages were small and had her ask herself if it was worth $1000. She agreed that the 85 f/1.8G would be better.
I tested the 85 f/1.4G with the 85 f/1.8AF (non-D) and the difference in the out of focus highlights are so small. The 85mm f/1.8 had donut shaped out of focus circles though it's not really noticeable unless you look hard. It doesn't sound like the 1.8G has that problem.
m_appeal Veteran Member • Posts: 3,434
The 1.4 has a special look IMO
that I can't get with the f1.8
This is with the sigma:
Joe Porto Senior Member • Posts: 1,064
Stop shooting rulers...try it on real subjects.
You will see that it is very sharp as a portrait lens, even wide open. If you are shooting a ruler with thin lines and high contrast, of course it is going to exhibit CA. But on people, flowers, etc., this lens is excellent.
 Joe Porto's gear list:Joe Porto's gear list
Canon PowerShot G15 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +5 more
Daisy AU
nathantw wrote:
Thanks,
Daisy AU - Brisbane
I believe the bokeh with the 1.4 is better, but, like you said, is it worth the price? I'm inclined to get the 1.8 for that reason.  I appreciate your advice, thank you.
Thanks,
Daisy AU - Brisbane
Daisy AU
Re: The 1.4 has a special look IMO
Nice shot!  I agree with you that 1.4 gives better bokeh and is probably a bit sharper, but as I do not want a third party lens and prefer to stick with Nikkor, my decision is basically one of being satisfied with the 1.8 or paying almost 3 times more (here in Australia) for the 1.4.  Thank you for the example.
Thanks,
Daisy AU - Brisbane
