Lightroom edits using both PC and Mac
Started Apr 6, 2013 | Questions
Deji
Deji Regular Member • Posts: 153
I'll soon be getting a 15" MacBook Pro to replace a derelict Dell laptop. I'm looking for help with using Lightroom 4 seamlessly with the MBP and my Win 7 desktop (which I love for editing because of its dual-monitor setup).
In the coming months, I will be traveling often with the MBP and taking substantial numbers of photographs.
I would appreciate your help with organising my storage and workflow on the road and (most importantly) when I return home.
Can I copy the current catalogue and image files from the Win 7 desktop's HDD to a USB 3 external drive then take the external drive on the road, hook it up to the MBP add images files, freely edit all these files AND finally, when I return home, hook it back up to the Windows machine and continue my editing?
Are there file format issues which will prevent me from moving this drive back and forth as I've described above? Is there another way to achieve what I want? Or do I have no alternative but to buy virtualisation software, install Windows 7 and run LR4 in Windows?
Thank you for your help.
Deji
 Deji's gear list:Deji's gear list
Canon EOS-1D X Canon EOS 5DS R Canon EF 15mm f/2.8 Fisheye Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.2L II USM +17 more
Larry Paris
Larry Paris Regular Member • Posts: 156
Re: Lightroom edits using both PC and Mac
I take my MBP on the road along with an 256G Lacie external drive with a thunderbolt port for the MBP.  The Lacie also has a USB port.  I download my photos from my camera through my MBP to the Lacie where I import them into Lightroom.  I edit the photos on the road and I save all changes to the Lacie.  When I get home I plug the Lacie into my Desktop (I have an iMac) and import them into Lightroom with edits intact.  You will plug in the USB into your PC through the USB port, import your edited photos into Lightroom, and Lightroom will automatically create previews of each photo and save them to your Lightroom catalog.
Larry from Chilliwack
 Larry Paris's gear list:Larry Paris's gear list
Sony RX100 II Nikon D800E Nikon D4S
Deji
Deji OP Regular Member • Posts: 153
Thanks for the response Larry. So essentially, import your "road" catalogue into your "home" catalogue, right?
Have you ever transferred a portion (or all of) your "home" catalogue to the Lacie, done edits on some of its images and added more images while you're on the road and then seamlessly re-imported all of the changes into the "home" catalogue?
Do you know if moving catalogues between a Mac and PC will raise any file-format issues?
Appreciate any comments.
Deji
Howard Moftich Veteran Member • Posts: 7,708
there are no PC <-> Mac file format issues.
Larry Paris
You are not importing the catalog--you are importing the photos to your windows catalog.  I wouldn't try to move your catalog between platforms--it could get really messy.  The way I've suggested is the simplest.
Deji
Thank you Howard.
Deji
Deji
Thanks Larry, this is one of the issues I was hoping to clarify.
Deji
ChrisBurch Regular Member • Posts: 436
I have a Windows desktop and recently upgraded to a MacBook Pro.  I can import and edit photos on the MacBooks and then export them to my desktop with no problems at all.  I perform an export of the edited photos with "Original" selected under File Settings.  You'll get the raw files plus a .xmp file for each image.  When you import these photos, the .xmp file will load your edits from your laptop.  It won't matter if you're using Mac or Windows.
 ChrisBurch's gear list:ChrisBurch's gear list
Canon EOS 5D Mark II Canon EOS 40D Canon EOS-1D X Canon EOS 5D Mark III Canon EOS 70D +17 more
AShimon Contributing Member • Posts: 797
Congrats. You won't have any issues between the two. But if the only reason you include the PC is because of the dual monitors, why not just plug one of them in to your MBP and skip the PC altogether?
HenryL64 Contributing Member • Posts: 521
Could you elaborate on how moving a catalog between platforms could get messy?
Henry
graybalanced Veteran Member • Posts: 4,826
Just about all Adobe products (Lightroom, Photoshop, etc.) use cross-platform-safe file formats, that's why you should have no problem there.
The only problems you might run into would be the differences in disk formatting that Windows (FAT32, NTFS) and Mac (HFS+) expect, which can affect which platform can read and write to a drive. But if it ever becomes a problem that gets in your way you can get cheap software that will allow either side to fully read and write to the other platform's disk formats.
