7-14mm lens hood cover panasonic. Anyone know of a cheap knockoff? What is the mm size?
Started Apr 5, 2013 | Discussions
jennajenna
Senior MemberPosts: 1,282
Apr 5, 2013
Anyone know of a cheap knockoff on flea-bay?
Also, What is the mm size? 68mm? 73mm?
THANKS
Detail Man
Forum ProPosts: 16,158
Re: 7-14mm lens hood cover panasonic. What is the mm size?
In reply to jennajenna, Apr 5, 2013
... What is the mm size? 68mm? 73mm?
Inner diameter dimension is around 70mm. Outer diameter dimension is around 75mm.
alabaster
Senior MemberPosts: 1,580Gear list
In reply to Detail Man, Apr 5, 2013
Exactly 70mm ID on calipers. See if you can find a pringle top that's 70mm.
 alabaster's gear list:alabaster's gear list
Nikon D2H Olympus E-M1 Nikon D810 +1 more
jeffharris
Veteran MemberPosts: 6,055Gear list
Re: 7-14mm lens hood cover panasonic. Anyone know of a cheap knockoff? What is the mm size?
THANKS
You can buy them directly from Panasonic for about $15 or $20. You have to dig around their parts web site.
I got an extra with a plan to cut off the front plate and epoxy on a step-up filter ring. Still waiting for the inspiration to actually do it....
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical +27 more
