Panasonic 100-300 vs. Olympus 75-300 II lens test
Started Apr 4, 2013 | Discussions
Adjuster
Contributing MemberPosts: 920Gear list
Apr 4, 2013
I have had the Panasonic 100-300mm lens for some time. Last year I tested it in comparison with the Olympus 75-300 lens. The Panasonic won hands down at every focal length.
I was curious whether the new Olympus 75-300 II lens would be any better. Son of gun, it is. I tested them with the OM-D on a heavy duty Gitzo carbon fiber tripod and a RRS BH-55 bullhead. Hard to have a more stable platform. Tested the lenses at 100, 200, 250, and 300mm. Lenses produced the same results except at 300mm, where the Olympus seems to be better.
Olympus 75-300mm lens
Panasonic Lumix 100-300mm lens
So the good news is that Olympus has produced a better lens. The bad news is that I am compelled to buy it. Sigh.
 Adjuster's gear list:Adjuster's gear list
Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +1 more
FrankParis
Senior MemberPosts: 1,042Gear list
Re: Panasonic 100-300 vs. Olympus 75-300 II lens test
In reply to Adjuster, Apr 5, 2013
Mechanically, it's a beauty, too. No lens creep for one thing. Fast focusing. I know nothing about the Panny 100-300.
Frank Paris
 FrankParis's gear list:FrankParis's gear list
Olympus PEN E-PM1 Panasonic Leica D Summilux Asph 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
Anders W
Forum ProPosts: 21,460Gear list
Thanks for the test. But I am not so sure about the conclusion. Note that a) the new 75-300 is optically identical to the old save for new (and hopefully better) antireflective coatings and b) the two lenses were not focused identically in your test images (focus placed closer to the camera with the Pany 100-300).
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +28 more
Adjuster
In reply to Anders W, Apr 5, 2013
I was concerned about those issues as well. I wanted to give Olympus the benefit of the doubt in case the older one was a bad copy. I tested the lenses repeatedly with the OM-D and the results were always the same. So if the focusing was off, it was off consistently. The "Do Not Enter Sign" was consistently sharper with the Olympus lens. Hard to see in the photos, but the horizontal white line was sharper with the Olympus.
Are you suggesting that I should send the Panasonic to their service center to have it adjusted?
Anders W
The old may have been a bad copy. Hard to tell at this point. But there is no real reason to expect any optical difference between the new and the old lens design, except possibly with respect to flare.
Focus may well have been different consistently. In the shots you show, neither lens is focused perfectly on the "Do not enter" sign. As far as I can tell, focus for the Oly is on the middle section of the leftmost trunk and for the Pany on the topmost section of the same trunk. It follows that the sign is more out of focus with the Pany than the Oly, which probably explains the difference you are seeing.
I wouldn't think so. But I am not so sure that you need to buy the Oly to replace it based on this test. Neither image looks all that sharp to me even in the part where they are perfectly focused. But this may be because of jpeg processing (e.g., the NR setting) and atmospheric conditions. I trust it you were using a tripod.
The 100-percent crop in the post I link to below shows the sharpness level that the 100-300 can actually manage at the long end:
http://www.dpreview.com/forums/post/50934220
Timbukto
Senior MemberPosts: 4,370Gear list
Why would you buy another lens or any lens based on this test?  There are so many ambiguous things about this test.  You are stopped down more on one lens another.  It looks like you are shooting through a window or something.  It looks like the middle of the chain link fence is OOF, but the edges are in focus.
In the end the picture is utterly baffling and I wouldn't buy *either* lens based on either result.
 Timbukto's gear list:Timbukto's gear list
Canon EOS M Canon EF 200mm f/2.8L II USM Canon EF-M 22mm f/2 STM
PC Wheeler
Forum ProPosts: 15,046Gear list
I have the Lumix 100-300, and with a GH3 the Oly lens would be poor choice.
My experience is that the 100-300 is good out to about 250 (500mm equiv) and loses a bit beyond that point -- so I try to not shoot beyond 250 with it.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot SX50 HS Canon PowerShot ELPH 330 HS Panasonic Lumix DMC-FZ1000 Sony a6000 Sony E 10-18mm F4 OSS +5 more
bgalb
Senior MemberPosts: 1,664Gear list
The test conditions were totally wrong to compare the critical sharpness of two lenses.  The test target was really strange.  Why the foggy appearance at the bottom of the image? There wasn't enough light to make a good test.  Its hard to tell, but it looks like there may have been a pretty good wind blowing.  Different sections of the fence are in and out of focus.  Not to mention that the focus point was different for the two lenses.
To do a valid outdoor test, you need calm, clear conditions with good light and a flat surface perpendicular to the lens axis with good, but not excessive, contrast between elements of different brightness.  If it was windy during this test, then 1/15 second is too slow.  It doesn't really matter how good your tripod was.  Also, the slightest touch on the camera will induce a lot of vibration motion with the long lens attached at 300 mm. A wireless shutter release comes to mind as useful to prevent camera vibrations due to handling when mounted on a tripod.
I have the panny 100-300 with a Roesch Tripod Mount.  Am always looking for a little more sharpness at 300 mm and would get the new oly 75- 300 in a heartbeat if I was convinced it was noticeably sharper at 300.
 bgalb's gear list:bgalb's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Leica D Summilux Asph 25mm F1.4 Panasonic 12-35mm F2.8 +7 more
Adjuster
That is why I wanted to test it.
The focus rectangle was located directly over the sign.
You all may be right. I was shooting through a window. Will do another series of tests this weekend when I hopefully will not be stuck at the office.
BTW, shutter shock was a 1/8 and I used the 2 second delay all to avoid unnecessary vibration.
It would be nice if the Olympus were as good as the Panasonic as it is smaller and easier to carry.
Anders W
For whatever reason, the focus is nevertheless not on the sign in either image.
I suspected something like that. Shooting through a window is definitely not a good idea when testing lenses.
You mean antishock was at 1/8. Note that using antishock and self-timer at the same time is a bit superfluous although it won't hurt of course. But the best solution here is to simply set antishock to a couple of seconds and forget about the self-timer. The camera then has a couple of seconds to stabilize from your touch as well as the first part of shutter action (shutter closing prior to exposure).
PC Wheeler
Ouch!
Phil
Adjuster
In reply to PC Wheeler, Apr 5, 2013
PC Wheeler wrote:
Well, at least it was clean. Okay guys. I won't do that again.
Ouch!
Phil
Easy for you to say. You are in Los Angeles. I am in the Boston area and it is too cold to play around outdoors.  This weekend should be better.
Also wanted to test it with a distant target.
jennajenna
Senior MemberPosts: 1,282
You should really re-shoot your test. Try something outdoors. or Indoors. But not thru glass lol.
sderdiarian
Veteran MemberPosts: 3,835Gear list
Where were you?  I live in the Boston metro area and last weekend was beautiful, seasonably cool but hardly cold.  Shooting through a window for a test is just plane silly.
Sailin' Steve
 sderdiarian's gear list:sderdiarian's gear list
Panasonic Lumix DMC-GM1 Olympus OM-D E-M10 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +1 more
Adjuster
In reply to sderdiarian, Apr 5, 2013
Sailin' Steve
I shot the photos today. Today was not beautiful. I just got the lens today.
Okay, is this junior high? I want to hear from more people telling me not to shoot through a window. Come on guys. You can do it.
Chatokun
Regular MemberPosts: 447Gear list
Adjuster wrote:
Sailin' Steve
If you insist. Shooting through a window is pointless! It adds a whole other element to the image to add distortion, softness, and other such issues! Also, don't shoot on a hot day above pavement. The heat totally distorts the atmosphere. Don't shoot the moon. The atmosphere totally distorts the atmosphere. Don't shoot in rain. Humidity. Snow. Sleet. Under water. In the dark.... I got nothing.
 Chatokun's gear list:Chatokun's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-LX100 Olympus OM-D E-M5 Olympus PEN E-PL1 Panasonic Lumix DMC-GF3 +12 more
ajamils1
Senior MemberPosts: 1,443Gear list
In reply to Chatokun, Apr 5, 2013
Olympus 75-300 might be a great lens but lack of stablization means that it can only be used with an Olympus body with IBIS where as Panny 100-300 can be used on Oly or Panasonic bodies. So when you buy this lens make sure that you do not plan on getting a Panasonic body in future.
 ajamils1's gear list:ajamils1's gear list
Sony Alpha 7R II Sigma 24-105mm F4 DG OS HSM Sony FE 35mm F2.8 Sony FE 55mm F1.8 Olympus 40-150mm F2.8 Pro +2 more
PC Wheeler
Distant targets, outdoors, with long lens introduce atmospheric effects, unless you have a very special day. You may get more of those in the East than we do here in L.A. area.
Phil
texinwien
Senior MemberPosts: 3,317Gear list
Buy That Window!
Adjuster wrote:
Sailin' Steve
I'm not sure about the lenses, but that window appears to be an excellent piece of optics. A bargain at any price!
tex
 texinwien's gear list:texinwien's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus 12-40mm F2.8 OnePlus One Canon EOS 300D +20 more
Ulric
Senior MemberPosts: 3,199Gear list
You should also not shoot through a piece of cardboard or heavy cloth.
 Ulric's gear list:Ulric's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +9 more
