I modified a 38xx I-refill cartridge ...
Started Apr 4, 2013 | Discussions
JJ Winkel Senior Member • Posts: 1,387
I have since a long time a new 3880 I-refill kit from InkRepublic, but till now never got to install it mainly due to some drawbacks like too large, too much air causing banding when nearing emptiness, etc...
But as I also read that they have many advantages I decided to try to make one smaller.
Some preliminary pics :
Size comparison
In Situ
Cover almost closed
To avoid a too long post, I made a pdf describing what I did, it's here:
http://www.casimages.com/f.php?f=130404070553781858.pdf
Before I permanently seal the test cartridge and start "destroying" the other eight ones, please feel free to submit any further suggestion or comment.
C&C welcome if ever there's a pic of mine posted above !
JJ.
Serhat Abaci Regular Member • Posts: 265
Re: I modified a 38xx I-refill cartridge ...
intressting!
but the pdf file is broken
 Serhat Abaci's gear list:Serhat Abaci's gear list
Canon EOS M Canon EOS Rebel SL1 Canon EF 40mm f/2.8 STM Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +3 more
JJ Winkel OP Senior Member • Posts: 1,387
The pdf file is good.
Serhat Abaci wrote:
intressting!
Serhat,
I tested the pdf, it is ok,
Unfortunately you cannot read it on-line, you have to download it first.
Sorry for the inconvenience, but if required I can publish it as a post here.
JJ.
HotArt Regular Member • Posts: 118
Size comparison
In Situ
Cover almost closed
JJ.
 HotArt's gear list:HotArt's gear list
Olympus Stylus SP-100
Size comparison
In Situ
Cover almost closed
JJ.
This looks like a great idea.
Have you considered cutting the cartridge to the same size as the orginal, while using a smaller diam. fill hole & plug in order to be able to close the printer's cover completely?
Also, have you tried it with ink for a number of days to make sure every thing holds up when the modified cartridge is pressurized?
Andrew Curatola Senior Member • Posts: 1,551
Very good idea if it keeps working down the line without any problems. If I had a 3880 I would have giving it a shot. I have all the tools you mentioned plus more. Your idea is how things get invented.
Andrew
 Andrew Curatola's gear list:Andrew Curatola's gear list
Panasonic Lumix DMC-FZ1000 +1 more
Petruska Veteran Member • Posts: 7,500
Looks good, but....
Size comparison
In Situ
Cover almost closed
JJ.
I would question your new plexiglas end panel gluing attachment to the cartridge integraty.  This is an unknown bonding interface, dissimilar materials, plus the cartridge operates with internal pressurization placing more force on that glue joint.  It may last forever, but I would be worried about it may fail and the ink that could flood the floor or carpet.  Floor protection may be required until the glue joint proves its durability.
This is still a very professional cartridge modification and one wonders why the China suppliers just don't make it this way to begin with.
Bob P.
johnsong Senior Member • Posts: 1,173
Serhat Abaci wrote:
intressting!
Need to add .pdf to the fill
Additional testing ....
Bob's hint about gluing plexiglas to the cartridge plastic got me wondering.
So far I only tested the robustness of the joint by trying to rip the two parts apart by hand, and though I am not a famous bodybuilder I did apply some force without breaking the joint. But decided to do another more scientific rupture test, if only to put my mind at rest.
Details :
Cartridge body seems to be made of some white hard plastic pvc that can be cut, drilled, sanded, glued, etc ...
Back plate is made of transparent hard PMMA (Altuglas / Plexiglas), 2 mm thick, it's 2nd prefered glue is cyanoacrylate glue better known as SuperGlue both in liquid or gel form (1st prefered being Chloroform ...... excellent if you want to make very neat and invisible joints, but that's another story).
So far I used two scrap off cuts glued together with gel superglue like that and left to dry minimum 24 hours :
For the scientific test I modified the jig like that :
I started with lighter weights and ended here :
2920g = 6.44 pounds
I stopped there as it was the scale's max, I didn't really want to break the jig and the axle began to bend
So now some maths :
The test jig's glued surface (colored light blue) is about 1.6 cm²,  actual full size it will be 4.90 cm² thus the equivalent test weight would have been  2.92 kg x 4.9 / 1.6 = 8.94 kg / 19.7 pounds
And it still didn't break yet .....
Now about pressure :
The internal area of the backplate is : 63 x 25 = 1575 mm² = 15.75 cm² =  2.44 in²
The equivalent test pressure would be :  8.94 kg / 15.75 cm² = 0.568 kg/cm² = 8 psi
Would you think that's enough ?  Can that poor rubber accordion pump of the 3880 exceed that pressure ?
Before that I did use some other glues like silicone and MS Polymer (supposed to be the strongest of all ... :-O) none resisted very long.
One more detail : inkjet inks are water based, so no solvent to attack the joint in the long run.
JJ.
Well cutting the cart to the same size as the OEM ones would have been like using the 80 ml refillable ones with only the benefit of the better valve, but then it would have been necessary to reduce the tube to the internal air filter and give up the nicer and larger refill plug too.
The small protrusion doesn't bother me really as long as I can almost close the cover to keep the carts shielded from direct sunlight, and it is nice to see the ink levels at a glance.
Not yet as I actually have not yet glued the backplate, still waiting for some more comments, but I will for sure and let you know.
JJ.
jtoolman
jtoolman Veteran Member • Posts: 5,518
JJ.
To me, the biggest advantage of this modification is the ability to top fill as opposed to the filling method integrated into the small 80ml refillables. Since the modified carts extend a bit beyond the
80 ml carts, what gains in internal ink volume are attained?
I have done a top fill modification to both on my 80ml refillable cart sets for my two 3800s and so far it is working very well.
The positives are that I can top off the carts when needed and there is no resetting needed as the chips always read full. Since one never removes the carts, the outlet port seals are not exposed to the wear caused by removing and reinserting.
The negatives are that you can no longer fill to the top. Due to the location of the new fill plugs.
If I had to do it over again, I would forgo this mod.
You do thing right!
Details :
2920g = 6.44 pounds
So now some maths :
JJ.
I'm also an engineer and I appreciate when someone looks at a new design from all angles.  I love the glue line bond shear test method apparatus!  Looks like the glue works well with the two dissimilar materials.  One good thing with the clear plexiglas end cap, you can see if any ink is slowly migrating through through bond line.
Bob P.
irvweiner Contributing Member • Posts: 705
Re: You do thing right!
'Us Engineers' love to keep making love to our projects'!!!
1: Several 2-56 screws could be placed around the rear perimeter, guaranteeing the rear cover plate never breaking off due to a creeping fracture in the glue joint.
2: A 6-32 or 1/4-20 Nylon bolt plus O-ring could be used as a new flush ink entry port on the cart's top or new (slightly thicker) rear cover plate.
3: Stop and create more prints!!  YES
irv weiner
JJ.
Re: The negatives are that you can no longer fill to the top. Due to the location of the new fill plugs.
As you know following your design I too use cartridges with the fill hole in the top position. I fill the cartridges to the top by leaning the printer backward while refilling.
I have another question, since there is a cost to every modification (even if it is only time), buying both sets of cartridges & using the inkrepublic chips fitted on the cone style cartridges might be an option (it they would work). Does any one know if the inkrepublic chips can be fitted on the cone style cartridges?
First summary, not yet conclusion ...
My experiment was not to compare one against the other, I already had my IR carts and to use them or not use them, that was the question .... Not using them meaning getting rid of more cash.
I can only compare what I now actually know of the IR carts having carried an autopsy on one and from what has been said / shown on-line about the 80 ml refillable carts. So what have I got so far :
1) Modified IR / InkJetCarts carts, reduced length:
Benefits:
  • True 80 ml useful capacity (measured)
  • Very good ink valve almost identical to oem
  • Nice one way air filter preventing ink back flow into printer pressurizing system
  • Sturdy build with one thick wall only
  • Clearly visible ink level
  • Large refill plug easy to fill and manipulate
  • No piggy back chips and resets maintenance cart too, no need of an additional resetter
Drawbacks:
  • Work involved
  • Still protrudes but no need to remove/rework the printer cover
  • Chip reset procedure not so user friendly
  • More expensive (but I already had mine ... )
2) Modified 80 ml Inkjetmall / IJF / ..., with top fill modification:
Benefits:
  • Less work involved
  • Do not protrude, printer cover can be closed
  • Chips show always full and no need to remove them to reset the chip
  • Cheaper (unless one has to buy the oem chips too)
Drawbacks:
  • Multiple thin walls to drill thru, less long term reliability ?
  • Need for additional fill hole plugs, reliability after multiple reuse ?
  • Reset requires not empty oem chips to start with
  • Requires additional maintenance chip resetter
  • Possible carts locked due to chip protruding ( But see my post here : What really happens ...
Not drawbacks but questions:
  • As these carts are even smaller than my reduced ones, what is their actual useful capacity ?
  • How is their air pressure system ?
  • What happens to it if filling to the top ?
If I wrote something wrong or forgot some points, please let me know.
Thanks for reading ....
JJ.
jtoolman
Re: First summary, not yet conclusion ...
Benefits:
Drawbacks:
  • Work involved
Benefits:
Drawbacks:
JJ.
With the IJF carts for the 3800 the maintenance cart becomes always empty. Even though they include a supposedly special chip for the MC, I have found ( twice already ) that the always full chip ends up not being recognized and you simply can just leave the original MC chip in place. It automatically resets it and keeps it always empty.
Also, with the IJF carts and their controller chips, you only need the Mk and PK original chips. So in case you have to buy them from someone like CONE, the total outlay will not be as much as having to buy a complete set.
The total volume I have been able to fill up these carts is only about 60-65, maybe 70 ml tops.
The internal square wall supports take up a lot of what would be useful ink volume.
The weak point on my top fill mod is the double walled area that one would have to drill through. To really have a good seal, you really need more surface area on the hole. If the cart had any area that was at least 1/8" thick, then a better sealing hole could be produced.
During testing with a set of failed carts, I found that I would have a few hole/plug seals that would leak and some that would not. I was originally using the 5/32" drill. Since I have a complete set of numbered and letter size drills I figured that If I ever do this again, I would use a decimal size that is about 4 thou smaller in diameter that the 5/32" simply to provide a tighter plug seal of the hole.
The other problem is that since my hole is located on the flat corner of the top of the cart and it's at an angle, I cannot fill to the top. In fact I have to keep the ink level below the hole, thereby loosing another 7-10ml of ink volume. It's not really that big a deal since you still have like 60ml of ink per cart to print with.
The so called 80ml refillable carts are also not very translucent so it is not easy to visually monitor levels, without actually removing them. Which negates the very reason for the top fill mod.
Now Up and Running with Cone InkThrift dye inks ......
A few more pics :Fill'em up ......
60 ml each
In Situ
Printing cover closed ....
As I have a stock of A3+ Epson PGPP, I made a specific profile and printed an evaluation print, then scanned it with my IT8 profiled V750 scanner :
Look at the full size scan (un-retouched)
OK, Agreed the Epson PGPP is no good for B/W but with the Cone InkThrift dye inks the colours are gorgeous and the gloss excellent, much better than with OEM inks.
Thanks for reading ......
JJ.
That looks sooooo good!
60 ml each
In Situ
JJ.
Very nice modified set of carts.  I really like that the cover doesn't close all the way, it lets you see when you are running low on ink much easier.
Yes the Cone dye inks are great.  Both the pigment and dye inks have a great gloss, I always say better than OEM.
You should market these modified carts.
Bob P.
Some news and updated pdf
Well 4 months later the carts are still as when I mod them, no trouble no leak no nothing .....
I updated the pdf with some more pictures :
http://www.casimages.com/f.php?f=130815065755573689.pdf
JJ.
williamio Contributing Member • Posts: 517
Re: Some news and updated pdf
JJ.
Looks really interesting. May I know how much time you took to modify the carts? I dont think I can be that handy
by the way, I am using the original refill carts from Inkrepublic. It works fine without modification. the only downside (probably not a real disadvantage) is the open cover. I took it out by following some tips on
http://www.nifty-stuff.com/forum/viewtopic.php?id=7914
