Over/underexposure not shown in OM-D EVF??
Started Apr 4, 2013 | Discussions
pavinder Regular Member • Posts: 253
Just coming to grips with all the menu options on my OM-D EM-5, trying to test as much as possible during my 10 day return policy (it's a second hand camera body).
Thanks to all the posters on the various OM-D setup threads - really valuable information and tips.
However there's one problem I seem to be having, but maybe I've just got a setting wrong somewhere…
In M mode:
Changing shutter speed or aperture is reflected visually in both the LCD and the EVF.  The image becomes darker or lighter (Live Boost is turned off).
Also, the Exp.Comp. level meter indicates how many stops under/overexposure the current settings will give.
In S mode:
Changing shutter speed is NOT reflected visually in either the LCD or the EVF. I realize this is the normal way it functions from reading other threads.
Now, if the shutter speed is changed to the point that over or underexposure will occur (i.e. beyond the aperture's possible range), the aperture number will start blinking in the LCD, but NOT in the EVF.
Why does the aperture value not blink in the EVF?  This makes no sense to me at all.  Without this, there is no indication in the EVF of any under or overexposure.  Have I simply got a setting wrong somewhere?
Any advice would be very much appreciated.  I only have a couple of days left on the store's exchange policy so need to know if there's a problem very soon!
Anders W Forum Pro • Posts: 21,465
Re: Over/underexposure not shown in OM-D EVF??
In M mode:
In S mode:
Don't know what the problem might be. On mine, the f-number will start blinking in the EVF as well as on the LCD. This is true about all the EVF/LCD modes I am using (normal, highlight/shadows warning, level-gauge, zoom-frame).
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
KenBalbari Regular Member • Posts: 276
Turn off live view boost.  In the display menu (menu D I think).
Note that the live view histogram is also worthless for determining exposure when the "boost" mode is on, as exposure chamges will also not be reflected in the histogram (it reads from the display).
 KenBalbari's gear list:KenBalbari's gear list
Olympus PEN E-PL2
cfh25 Senior Member • Posts: 1,070
Find the shadows/highlights screen is best for indicating under/over exposure
pavinder OP Regular Member • Posts: 253
I assume you mean the screen which shows blinking coloured areas - blue for underexposed, orange for overexposed. Yes, I can find this and I can find the Histogram, and I appreciate your recommendations.
But my concern is that there is actually a HARDWARE PROBLEM for which I should take it back for exchange.  The non-blinking aperture number in the EVF suggests to me there is a problem.
But it seems strange that it should flash in the LCD but not the EVF - after all, it's just a software function, which is why I wonder if it's caused by my settings.
I don't want to make a special trip to the store to exchange the camera, only to find out it's a setting in a menu.
As I said, Live Boost is switched off.
I took the camera back to the shop.
They tested it, said it seems problematic, but found that the all other OM-Ds at the shop did exactly the same thing when set in the same way.
We isolated it down to using Style 2 for the EVF.  With Style 1 and 3 the problem didn't occur.
However we then checked the firmware version and saw that it was still at 1.1.  An update to 1.6 solved the problem.
Gregm61 Forum Pro • Posts: 14,517
Auto ISO? Often the "problem" is, auto ISO is adjusting as you are changing all the settings, keeping the exposure the same no matter what you do. No matter the exposure mode, be it manual, program, shutter speed or aperture priority, If you want to be seeing the changes to exposure settings in the EVF as you make them, you need to be setting your ISO manually.
Most of the time I am manually setting my ISO's, but every once & a while I will have it on auto ISO, make some exposure adjustments and get frustrated because nothing seems to be changing on the screen, then I realize I am in auto ISO and tha camera is adjusting the ISO settings as I make my adjustments. I change it manually to the ISO setting I want and, viola, the EVF starts showing the changes again.
"There's shadows in life, baby.." Jack Horner- Boogie Nights
 Gregm61's gear list:Gregm61's gear list
Leica M9 Panasonic Lumix DMC-GX7 Olympus E-M1 Leica M (Typ 262) Olympus Zuiko Digital ED 50mm 1:2.0 Macro +21 more
