Which lens in range 24...40 that works well against light.
Started Apr 3, 2013 | Discussions
krikman Regular Member • Posts: 402
Help me choose a lens!!!!
I found that too much my pictures were damaged by contra-light. Some lenses loose contrast, some had complex flares. I've had 16-85 that was able to make contrast photos against light, but sold it.
Now I shoot with D300s so DX or FX doesn't matter. Also it may be fix in range 28-40 mm.
I want to make pictures of this kind:
Help me!
Nikon D300S
Chad Gladstone Senior Member • Posts: 2,608
Re: Which lens in range 24...40 that works well against light.
Nikon 28 1.8g
Chad Gladstone
 Chad Gladstone's gear list:Chad Gladstone's gear list
Nikon 1 V1 Nikon D800E Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +7 more
krikman OP Regular Member • Posts: 402
Chad Gladstone wrote:
Nikon 28 1.8g
Chad Gladstone
Nice shot, but can you post picture with flares from 28/1.8? How annoing they are?
anotherMike Veteran Member • Posts: 8,080
The Nikon 28/1.8G is remarkably resistant to flare (this doesn't mean you can't get it to flare - you can get ANY lens to flare), probably moreso than any wide angle I've used in a while. Certainly and considerably more flare resistant than the new Sigma 35/1.4 for example.
The Nikon 24/1.4G is also pretty good, and while I sold my Nikon 35/1.4G since the Sigma is a touch sharper, the Nikon 35./1.4G is very flare resistant.
-m
This is at 2.8 with the sun pointed directly at the camera.  I could not even see her to take the picture because I was blinded by the sun.  There is a slight loss of contrast, but nothing like the any other lens I have.  I will produce the phenomenon you are requesting, but I will have to wait for the sun to come down.
Chad Gladstone
Thank you.
Actually I use Tamron 28-75 which is still good allaround lens with flare resistance.
But Tammy have color-shift inside (good for portrait because it warms skintones, but flattens reds and greens) so I miss clear and bright Nikkor colors.
Also I plan tu use AF-S 28G wide open for available light portraits and for product shots at home mini-studio. Good contra-light important here too.
Show please a little more samples of your photos with 28. How AF-S 28G performs in bad lighting or at night?
krikman wrote:
Thank you.
Sorry, it will have to wait until tomorrow.  I was a the Utah Jazz game with just the 85 1.8g tonight.  I can say that the 28 is unrivaled at this FL in anything near the price range, though.  This sigma 35 is really good as well, just not as good for what I have seen for shooting into the sun,  (It is next on my list to purchase).
Chad Gladstone
Thanks again.
I spend few hours on www.lenstip.com.
These are good reviewers and just every lens in their tests got troubles in contra light.
http://www.lenstip.com/346.9-Lens_review-Nikon_Nikkor_AF-S_28_mm_f_1.8G_Ghosting_and_flares.html
Interestingly even pricey monsters with nanocoating flares almost a chip ones.
(unknown member) Veteran Member • Posts: 3,441
Help me!
Test the Nikon 50mm F/1.8D.
Worst case Example from my WalimeX pro 35mm F/1.4 = Samyang:
Regards: Carsten
Ernie Misner
Ernie Misner Senior Member • Posts: 2,443
The best anti-flare insurance with any lens is to find a pole, tree, etc., that will cast a shadow on the front of the lens.   100% directly into the light this is of no help though.
Carsten Pauer 2 wrote:
Help me!
Nikkor 50 AF-D too long.
Samyang lacks autofocus and too big and heavy for casual shooting  = When beatiful light arises at evening before sunset or after storm - possible I don't take thit lens and leave it at home.
Anyway interesting feature. I don't even mention before where to buy samyangs.
Sadly you cannot hide in the rabbit's hole and still photographing the world.
One of ruined by flares photo:
Jose Rocha Senior Member • Posts: 1,028
Simple... Nikkor 24-70 f/2.8. Did some full body portraits last weekend in contra-light and was very pleased with the rendering and found no traces of flare or ghosting.
From my experience with this lens, it only produces nasty blue rays that cover the entire frame when you shoot foliage against the sun, in I can't replicate easily. But I'm sure no zoom lens would survive that test, only my primes did better.
 Jose Rocha's gear list:Jose Rocha's gear list
Nikon D700 Olympus OM-D E-M10 Nikon AF Nikkor 180mm f/2.8D ED-IF Tamron SP AF 90mm F/2.8 Di Macro Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +3 more
From my experience Nikkor 24-70 won't loose contrast and have great color reproduction (as 16-85 did). But both zooms flares against multiple light sources as in night sample before.
While looking for samples and reviews of AF-S 28 f/1.8, I like this lens more and more...
