Are the constant aperture Panasonic lenses worth it (and are you wating for Olympus?)
Started Apr 3, 2013 | Discussions
zenpmd
zenpmd Senior Member • Posts: 1,129
Buying them together is just such a lot of money. But imaging the possiblities of the two together is just mind blowing for the size and quality.
What is everyone elses thoughts, and who is waiting for Olympus are about to offer? As far as I know there is no plan for a zoom like the 35-100 2.8, just the shorter zoom, which is sadly not as wide as the Panasonic but might be smaller (due to the lack of IS) and hopefully won't have the CA that it suffers from on the Oly.
Yours thoughts most welcome!
jungoo
jungoo Junior Member • Posts: 35
Re: Are the constant aperture Panasonic lenses worth it (and are you wating for Olympus?)
they are worth it.
 jungoo's gear list:jungoo's gear list
Panasonic Leica Summilux DG 25mm F1.4
Chatokun
Chatokun Regular Member • Posts: 447
It seems the zooms are ideal if you use little to no primes. I've heard some recommend still keeping the 45mm 1.8 and/or the 25mm 1.4, then only use the 12-35 and 35-100 for all other focal lengths. Seems like a good plan if that's what you like, and I believe it's generally cheaper than getting all the primes in those ranges too.
Let's do a quick comparison(all prices approximate via Amazon in USD, new):
12-35mm - Currently as low as $985 new. Let's just say ~$1000.
12-35mm + 25mm = ~$1500~1600
Now Prime version:
12mm: $800
14mm: $200~300
17mm: $500
25mm: $500
total: ~$2000, plus or minus a hundred or so if you choose 20mm instead or go for brand new vs used. Also Sigmas change the game.
35-100mm - $1300 lowest(same company) and ~$1400 Average.
35-100mm + 45mm ~$1800
Primes:
45mm: $400
75mm: $900
Or:
PanLeica 45mm: ~$500-700
75mm $900
I left the 60mm out as it's Macro specific, and the 35-100mm covers that. I don't think anyone who has the 75 would buy the 60 only for the focal length, but I could be wrong. Another issue here is that the FL range of 35-100 covers more than the primes we have available in that range, so it's a less fair comparison.
So, as you see, the Zoom ranges can be cheaper, but the primes offer faster speeds and generally better quality, though the zooms are fast and good quality too. However, for the zooms to be cheaper, you need to pretty much forgo Primes. Having both is good for convenience and flexibility, but definitely costly.
 Chatokun's gear list:Chatokun's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-LX100 Olympus PEN E-PL1 Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 +12 more
DLBlack
DLBlack Forum Pro • Posts: 11,835
Yes for me a constant f2.8 is worth it.  I am waiting to see what Olympus is going to come up with.  The patent has at least a 12-40 f2.8 and a 12-40 f2.8-4.0 versions of what might be the upcoming lens.
Anyhow, for me lkast year was the year for primes.  I got all the fast primes (12/2.0, 17/1.8, 25/1.4, 45/1.8, 60/2.8 and the 75/1.8) and spent way over my annual photo gear budget.  This year I have budgeted for the 12-35/2.8 and the 35-100/2.8.  Since it is now kind of near if the rumor is true for for the wide-normal fast zoom, plus I am enjoying the fast primes I am waiting to see what Olympus is going to announce.  I really expect a companion lens to the rumor lens.  So my guess is a 12-40 like the patent is for and wilkl be released in May or June.  Then a companion lens that might be a 40-125/150 to be released in the fall.  There was a runor for such a lens back in December so it just might come to be, but it will be a while. Both hopefully being straight f2.8.
Dave
 DLBlack's gear list:DLBlack's gear list
Pentax K-7 Pentax K-5 Olympus OM-D E-M5 Olympus E-M1 Olympus E-M5 II +31 more
Pixnat2
Pixnat2 Veteran Member • Posts: 3,811
I depends on which camera you use.
You shoot with a Panansonic camera
In this case, they are definitely worth it, no contest. Those zooms are very sharp, high quality, stabilized and their weaknesses (CA and distortion) are well corrected by the camera software.
You shoot with an Olympus camera
In this case, the answer is more complex. It depends mainly on your CA tolerence and if you shoot RAW or JPEG.
If you shoot mainly RAW and use softwares like LR, you can correct CA and distortion fairly easily. In this case, those zooms may worth it, if you're willing to spend this money knowing the lenses weaknesses, of course.
If you shoot JPEGS, that's more problematic. In this case, spending 1000$ for a zoom that shows a fairly large amount of CA can be considered as a bit too expensive, but of course, it's a personal opinion, YMMV.
Personally, I shoot RAW+JPEGS, but I'm not CA tolerant, and as I shoot mainly with the EM-5, I'll wait for the Olympus 12-40.
 Pixnat2's gear list:Pixnat2's gear list
Canon PowerShot G7 X Olympus PEN E-P1 Panasonic Lumix DMC-GH2 Fujifilm X-E2 Fujifilm X-T1 +1 more
PC Wheeler
PC Wheeler Forum Pro • Posts: 15,770
I'm very pleased with those two Panasonic zooms. The fit nicely with my PL 100-300 (though I wish it was of equal quality, but 100-300 f/2.8 would be big and expensive.
My only prime is the 20 f/1.7 (and the PL 8 fisheye is a prime of sorts!). Also have the Oly 9-18 -- and a PL 14-140 left over from my GH2 kit (nice for wandering around with one lens for casual shooting).
One thing: I use a GH3, so long unstabilized Oly lenses would be a poorer choice.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot SX50 HS Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-ZS100 Sony Alpha a6300 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +6 more
PC Wheeler
Re: I depends on which camera you use.
CA bugs me, too -- one factor in my preference for Panasonic bodies and lenses.
Phil
zenpmd
zenpmd OP Senior Member • Posts: 1,129
So it is 90 percent certain that the Olympus will be 12-40? If so, that is a huge advantage for me, since 40, by being a 35mm equivilent of 80 is just about ok for faces, whereas 70mm on the Panasonic is inadequate.
I agree the zooms aren't bad value when you consider the cost of primes - but to me, thats more an indicator of how expensive the primes are rather than how cheap the zoom is (though I appreciate that is an academic distinction.
But is crazy how, say, Nikon and Canon have both 35mm and 50mm dslr options which are both great and cheap.
My personal complication is that I will continue to use a GH2 alongside by Oly for video - but only really for indoor shooting where the Oly gives me flickers in Europe - and therefore most likely using a tripod so stabilisation is less of an issue.
Rol Lei Nut
Rol Lei Nut Senior Member • Posts: 1,426
Right now, when I need a quality zoom and size, weight & focusing speed aren't vital, I'm quite happy using my Oly 4/3 12-60.
I'm not considering the Panny 2.8 zooms because:
1) the 35 of the 12-35 I find too short - I would still have to change lens often to get those missing Millimetres.
2) I don't really have a use for a 35-100 f/2.8
3) The Panny lenses are probably bigger (OIS) and have more CA than possible Oly ones.
I'd be interested in an Oly 12-xx 2.8 (or 2.8-4.0) zoom, *if* it comes close to the 12-60 quality (and is far batter than the 12-50) and is considerably lighter than the 12-60.
12-40 would be the absolute minimum range. 12-45 or 12-50 would be better.
Chatokun
Had to run out for lunch so didn't fully complete my post earlier. Personally, I have an EM-5 and the 12-50 as my main 12mm. I tested both the SLR Magic 12mm and the Olympus 12mm (great lens) but I can't justify the cost at the moment. I'm personally more of a primes guy, but I'm not sure I want all the primes in that range.
I have the 25mm and the 14mm, which I'll keep either way. I use LR for most photos(though the EM-5 have very nice OOC jpegs). I have been seriously considering the 12-35mm, as it offers several FLs I don't have a strong fast lens for (the 12-50 is nice in strong light or with a flash, but the 12-35 would obviously be superior). With the rumors of the 12-40mm, I've been waiting to see what they release before I make a decision.
I've seen it mentioned that Canikon have had lenses out for years, and much of the new lenses are smaller upgrades, while PanOly are making new lens and need to recoup R&D for them. I don't know how lens factories work, but I do know that in technology factories need to be rebuilt to accommodate smaller chip sizes fairly often(though the miniaturization war seems to be slowing down). If such necessities are involved with lenses as well, then they may have to recoup those too. Though, Oly and Pan have both been in 4/3 size for a while, so maybe not. Sigma has made lenses for both, so I'm not sure if it requires different factories or not.
bowportes
bowportes Senior Member • Posts: 2,546
Now Prime version:
12mm: $800
14mm: $200~300
17mm: $500
25mm: $500
Primes:
45mm: $400
75mm: $900
Or:
75mm $900
Odd that you left the 60mm out, since it's no more "macro specific" than the panLeica 45, which you include. Given the choice between the 60mm focal length and the 75mm one, I'd pick the former any time. So I guess you are wrong there.  Interesting exercise in comparative costs.
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +9 more
sigala1
sigala1 Senior Member • Posts: 3,634
Worth it if you're a wedding photographer
Worth it if you're a wedding photographer and need a fast zoom to ensure you capture critical moments that can only be photographed once.
Not worth it if you just take pictures of flowers and trees and your kids.
Savas Kyprianides
Savas Kyprianides Veteran Member • Posts: 3,473
They are expensive and I am waiting for Olympus.
bowportes
I must be missing something here. How is it that a 70mm  FL (35mm equivalence) is "inadequate for faces" but adding another 10mm makes it "just about ok"?
The 12-35mm lens is an outstanding lens for people period, whether talking about just head-and-shoulders portraits or depicting people in contexts.  The last time I perused some of my 35mm people shots, the faces all looked fine.
tedolf
tedolf Forum Pro • Posts: 22,049
Not unless you are a wedding photographer.....
the marginal cost/marginal benefit analysis doesn't pan out compared to prime lenses.
As long as you can change lenses, you are better off with primes: better IQ, smaller and lighter, more features (e.g. snap focus), lower cost and faster.
Tedolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +8 more
NCV
NCV Senior Member • Posts: 3,278
Yes, (with a good RAW converter to get rid of CA) for what I use a 2.8 zoom for.
Not having to change lenses all the time is a big positive when I am out hiking in the mountains.
The 2.8 makes a lens far more useful in low light .
 NCV's gear list:NCV's gear list
Nikon D300 Olympus OM-D E-M5
syncopation
syncopation New Member • Posts: 21
What about the forthcoming Tamron 14-150mm? Any interest in that?
 syncopation's gear list:syncopation's gear list
Panasonic Lumix DMC-G3
Alumna Gorp
Alumna Gorp Senior Member • Posts: 1,531
What makes you think those from Olympus are going to be cheaper.
I`m waiting to see what Olympus come up with, for the simple point there lens offering could be smaller.
 Alumna Gorp's gear list:Alumna Gorp's gear list
Fujifilm X10 Panasonic Lumix DMC-G2 Panasonic Lumix DMC-GF2 Olympus OM-D E-M5 Panasonic Lumix G 14mm F2.5 ASPH +4 more
Alumna Gorp
Now Prime version:
12mm: $800
14mm: $200~300
17mm: $500
25mm: $500
Primes:
45mm: $400
75mm: $900
Or:
75mm $900
Best also add the new Sigma 60mm f2.8, I`ve read that it will sell for around £180, ideal if you don`t need macro.
bowportes
Could be cheaper, but maybe not.
Could be smaller, but maybe not.
Could be better quality, but could be poorer quality.
Could appear this year, or the next, or the next.
In the meantime, for those of us who are thoroughly enjoying using the 12-35mm on a daily basis, it's definitely worth it.. And it didn't cost much either once I factored in the money made from lenses I no longer used regularly that were sold.
