HS50: Is it any good for video?
Started Apr 3, 2013 | Discussions
2raj Senior Member • Posts: 2,172
This is a question for all the HS50 owners out there. How goos is the video from this camera?
I use the HS10, and the video quality leaves a lot to be desired, so I shoot most of my family videos with the LX5.
I would appreciate any hands on impressions about the video quality, manual zoom, focussing, internal sounds etc.
thanks,
raj...
Just a Pixelpusher, currently experimenting with Fuji HS10 and Panasonic LX5
 2raj's gear list:2raj's gear list
Fujifilm FinePix F40fd Fujifilm FinePix HS10 Olympus PEN E-PM2
FujiFilm FinePix HS10 (FinePix HS11) Panasonic Lumix DMC-LX5
tom1234567
tom1234567 Senior Member • Posts: 1,040
Re: HS50: Is it any good for video?
I use the HS50 and the video quality leaves a lot to be desired IF you video inside in poor light it is crap, outside it is a little better, I would invest in a cheap Panasonic, or sony for video,
here is test http://www.youtube.com/watch?v=78KOaBDt0Zk
cheers Tom G
I'm a 30yr old trapped in a 62yr old body
 tom1234567's gear list:tom1234567's gear list
Nikon D7200 Tamron SP 70-300mm F/4-5.6 Di VC USD Sigma 105mm F2.8 EX DG Macro Sigma 17-50mm F2.8 EX DC OS HSM Nikon AF-S Nikkor 50mm f/1.8G
2raj OP Senior Member • Posts: 2,172
Thanks for the link.
MarvinErich Junior Member • Posts: 39
Re: HS50: Is it any good for video? P520 response.
MarvinErich wrote:
Look this.
http://www.youtube.com/watch?v=aK0x3_RHt-U
This doesn't answer my question. You are showing me a video shot with the Nikon Coolpix P520.
jcmarfilph Veteran Member • Posts: 7,592
thanks,
raj...
Raj,
The quality and focusing are better than previous HS cams but there is still the dilemma of shooting while zooming. Panny and Sony are still better choices for video recording because of the slow and smooth motorized zoom.
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
2raj wrote:
MarvinErich wrote:
Look this.
If competitors does not matter, what difference does it make if it's good or not?
alexisgreat Veteran Member • Posts: 6,459
Re: lossless digital zoom
Joms, an idea- since manual zoom is useless for video and videos normally use only a very small part of the sensor's resolution why doesn't Fuji implement lossless digital zoom for video and use the rest of the sensor's pixels to implement it? When implemented this way digital zoom has the same image quality that optical zoom would.  Plus it would aid in focusing and composing.  You also have the IDZ Fuji already has and the two types of digital zoom could be multiplied together.
http://Alex_the_GREAT.photoshop.com
 alexisgreat's gear list:alexisgreat's gear list
Olympus C-7070 Wide Zoom Fujifilm FinePix HS20 EXR Fujifilm FinePix HS50 EXR Olympus E-520 Olympus PEN E-PL6 +3 more
It is not the manual zoom per se as useless for video. IF and only IF you need to zoom in and out gradually while recording then it becomes a problem. Otherwise, you can zoom in and fix the focal length of recording or zoom in/out in one shot to avoid jerkiness.
-=[ Joms ]=-
LTZ470
LTZ470 Forum Pro • Posts: 11,926
They make all kinds of Zoom Levers for Manual Lens and they work great...Panasonic makes them for their lens as well...see first link below first photo
http://www.personal-view.com/talks/discussion/3266/zoom-and-focus-levers/p1
--Really there is a God...and He loves you..
FlickR Photostream:
www.flickr.com/photos/46756347@N08/
Mr Ichiro Kitao, I support the call to upgrade the FZ50.
I will not only buy one but two no questions asked...
Yep, if I remember correctly, doesn't Panasonic actually make a lens that has both manual and motorized zoom?  You can use either (or both.)
thanks,
raj...
Raj,
-=[ Joms ]=-
Thanks Joms. Does the HS50 pick-up lens noise when zooming? I believe that was an issue with the HS10.
Best regards,
raj...
Re: LTZ470...
FlickR Photostream:
This is pretty interesting. I did not know they made such a gadget, definitely better than hand rotating the lens barrel.
