Getting The DPP Look In Lightroom ?
Started Apr 3, 2013 | Discussions
Bright Angel Veteran Member • Posts: 4,814
Newbie post:
I've been using Lightroom for a few months with the 5D3.
15 mins ago, I thought I'd try out DPP.
It looks a basic interface, but, just loading up one image as a test, DPP just makes the photo look better than Lr, without making any adjustments in either program (better reds for example).
(Obviously my camera settings have been applied).
Question:
Is it possible to get the look of DDP in Lr, maybe download and install in profile in Lr.
Below is a side by side screen grab to illustrate.
Thanks for any info.
www.MarkSykesPhotography.co.uk
Canon EOS 5D Mark III
erbtype Regular Member • Posts: 118
Re: Getting The DPP Look In Lightroom ?
I don't use LR but I do find that pictures run through Camera Raw into PS have a slight grey 'screen' to them, almost as if someone is holding a very, very fine sheet of tracing paper over the picture, which I fix using the Levels panel (CTRL-L) and a tiny tweak in the Hue/Saturation panel (CTRL-U). It may be down to my in-camera settings (1DMkIV, contrast -1) but I find the default in-camera settings too strong (for my taste at least).
Basically experiment until you find the settings you like which best represent the moment as you captured it.
Bright Angel OP Veteran Member • Posts: 4,814
Thanks for the reply
nekrosoft13 Regular Member • Posts: 440
Bright Angel wrote:
Newbie post:
Question:
one of the "problems" is that LR does not take real camera profile into account. It tries to emulate the default levels of each camera profile, but if you made adjustment to them in your camera lightroom will not pick those up.
instead it will just load a real true RAW image.
 nekrosoft13's gear list:nekrosoft13's gear list
Canon EOS 7D Mark II Sony Alpha 7R II Sony Alpha a6300 Canon EF 50mm f/1.2L USM Canon EF 85mm f/1.2L II USM +19 more
philmar Senior Member • Posts: 2,076
I think there are DPP-look profiles out there that you can use like a preset. If I recall you may have to pay for them (someone has gone to the bother of creating them).
Every once Iin a while I play with DPP to see what results I can achieve. In the end I stick with LR because I love using presets, the incredible local adjustment tools, virtual copies, file management and the user interface blows DPP out of the water.
I may have a better starting point with DPP but i don't care. it is where I end up that's more important. DPP may give you a better head start but I find LR still gets me to my end product faster.
Phil M. - Toronto, Canada
Time to kill? Then have a look at a few of my photos, including one published by National Geographic : http://www.flickriver.com/photos/phil_marion/sets/
 philmar's gear list:philmar's gear list
Canon EOS 30D Canon EOS 5D Mark III Canon EF 50mm f/1.8 II Canon EF 16-35mm f/2.8L USM Canon EF 24-70mm f/2.8L USM +3 more
bhollis
bhollis Veteran Member • Posts: 3,180
What I'm seeing in the DPP pic is a little more saturation and contrast.  Easy enough to change in LR.  You can create a user preset in LR to make these kinds of changes.
Bob Gates
Bob Gates Senior Member • Posts: 1,479
Before doing anything else, set the LR profile to the same as your in camera setting that DPP picks up and uses (e.g. "Camera Neutral," "Camera Landscape," "Camera Standard," etc.) and compare the results.  These profiles should show up under "Camera Calibration," you don't need to download them.
Bob Gates, Jamesville, NY USA
http://bobgatesphoto.com
 Bob Gates's gear list:Bob Gates's gear list
Fujifilm X-T1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +2 more
** Thank You All Very Much **
Thank you all very much and thank you Bob
Your method does the trick.
I can fine tune it if needed (bringing down the red and orange in the HSL sliders, for the example shown above).
Zee Char Forum Pro • Posts: 10,873
Re: ** Thank You All Very Much **
I used to hate Adobe colours. They have come a long way in the last few years and the addition of camera profiles makes it even better. I did some tests a while ago. Both DPP and LR are set to faithful. Pretty close.
 Zee Char's gear list:Zee Char's gear list
Canon EOS 7D Mark II Canon EF 300mm f/4.0L IS USM Canon EF 70-200mm f/2.8L IS II USM Canon Extender EF 1.4x III Sigma 2x EX DG Tele Converter +3 more
