Does Aperture support the Fuji X100S?
Started Apr 3, 2013 | Discussions
jov95
jov95 Junior Member • Posts: 49
Hello all. I have one of the new iMacs and am thinking of going to Aperture or Lightroom. I am going to be picking up the new FujiX100S here soon and was wondering if Aperture supports it or not. I know Lightroom just had an update to add that camera. I was leaning towards Aperture for the lower cost and ease of use for a beginner. Thanks for any info.
Fujifilm X100S
webfrasse
webfrasse Veteran Member • Posts: 3,853
Re: Does Aperture support the Fuji X100S?
http://www.apple.com/aperture/specs/raw.html
RAW support is not a feature of the Apps from Apple. It's a built-in feature in OSX and released as an update for OSX, not for Aperture or iPhoto etc.
Mikael
Stubb
Stubb Contributing Member • Posts: 507
No. Aperture does not support the Fuji X100S. Aperture and iPhoto have never supported non-Bayer raw files (Foveon or X-Trans), so I wouldn't get your hopes up that Apple's next raw update suddenly provides X100S support.
 Stubb's gear list:Stubb's gear list
Olympus OM-D E-M5
NachoYogi
NachoYogi Regular Member • Posts: 142
My XP1 and X100s are why I switched to Lightroom 4 from Aperture.
 NachoYogi's gear list:NachoYogi's gear list
Canon PowerShot G10 Fujifilm X100S Canon PowerShot S110 Fujifilm X-Pro1 Nikon D300S +9 more
David247
David247 Senior Member • Posts: 2,406
YES!
Ignore those who don't actually check before speaking.
Aperture currently supports the following Fuji cameras.
David
Lightweaver's Photo Gallery: http://dwrobinson.zenfolio.com
Lighweaver's Blog: http://lightweaversblog.blogspot.com
"It's about the light. It is always about the light. Everything else is just tools to show the light in its infinitely changing forms."
 David247's gear list:David247's gear list
Panasonic Lumix DMC-FZ150 Olympus E-510
noirdesir
noirdesir Forum Pro • Posts: 12,372
NO
And ignore in particular those who think they know more when they actually know less. And those who fail to actually read and understand the answer they declare as being incorrect.
For the benefit of David here in bold the part he missed or did not understand:
"Aperture and iPhoto have never supported non-Bayer raw files (Foveon or X-Trans), so I wouldn't get your hopes up that Apple's next raw update suddenly provides X100S support."
One could forgive David for not knowing that the X-100s has an X-Trans, ie, a non-Bayer, sensor whereas the X-100 has a traditional Bayer sensor. But the answer in bold above should have given him pause to think.
David247
Re: NO
I stand corrected.  I failed to note the 's' version.
David
David118
David118 Forum Member • Posts: 60
Re: NO
I use Aperture and I just got the X20.  I gather it is unlikely that aperture will support raw files from the xtrans sensor.   So I assume I am stuck switching to Lightroom.  I like to make Apple photo books.  This may sound silly but is there a way to work on the raw file in Lightroom or any other program and then import the processed file into aperture without losing anything?
If not is there another book making program that is a customizable and as easy as the Apple one?
noirdesir
Re: NO
Sure, just export the images at full size from LR (after having done any adjustments you like) as jpegs (using maximum jpeg quality) to a folder and then import them from there in Aperture.
webfrasse
Re: NO
Sure, what could you possibly loose? Do the work in LR, export to tiff, dng or jpg and drop it in an Aperture Project. I do it all the time (for other reasons)
Mikael
_7D_
_7D_ Regular Member • Posts: 218
YES (Aperture 3.4 or later) Re: Does Aperture support the Fuji X100S?
Aperture 3 supports the RAW formats from more than 150 digital cameras and camera backs. Aperture also lets you work with most DNG files. Shoot JPEG? Using Aperture, you can import JPEG images from virtually all digital cameras.
  • FinePix S2 Pro
  • FinePix S3 Pro
  • FinePix S5 Pro
  • FinePix X100**
  • X-Pro1***
  • X-A1***
  • X-E1***
  • X-M1***
  • X20***
  • X100S***
RAW Support Requirements
Aperture 1.5 or later with Mac OS X v10.4.11 Tiger or Mac OS X v10.5 Leopard or later.
* Requires Aperture 2 or later with Mac OS X v10.4.11 Tiger or Mac OS X v10.5.2 Leopard or later.
** Requires Aperture 3 or later.
*** Requires Aperture 3.4 or later.
historianx
historianx Senior Member • Posts: 2,207
Re: YES (Aperture 3.4 or later) Re: Does Aperture support the Fuji X100S?
still no support for the X-E2 tho, which carries the same sensor and proccessor as the X100S. That should come soon, with the release of the X-T1.
 historianx's gear list:historianx's gear list
Fujifilm X100S Fujifilm X-Pro1 Nikon D7100 Leica D-Lux (Typ 109) Nikon D750 +3 more
guido1953
guido1953 Senior Member • Posts: 1,374
Per Apple site, these are the supported Fuji Cameras:
Fujifilm:
FinePix S2 Pro
FinePix S3 Pro
FinePix S5 Pro
FinePix X100**
X-Pro1***
X-A1***
X-E1***
X-M1***
X20***
X100S***
Guido
Alpha Doug
Alpha Doug Veteran Member • Posts: 9,219
Re: NO
While LR5 does not have the same flexibility in book creation that Aperture has, it now has a built in book making module that supports books published by Blurb.  If you like what Blurb has to offer in terms of printing and pricing, you can very easily create books within Lightroom.  Personally, I think they are a little pricey, and there are very few template available, but it is certainly doable.
Only my opinion. It's worth what you paid for it. Your mileage may vary! ;-}
www.dougwigton.com/
 Alpha Doug's gear list:Alpha Doug's gear list
Canon PowerShot S95 Sony SLT-A77 Olympus PEN E-PM2 Sony Alpha NEX-6 Sigma 17-70mm F2.8-4 DC Macro OS HSM +1 more
Alpha Doug
Well, it seems they do support X-Trans sensors after all.
www.dougwigton.com/
