printing rip for IMAC
Started Apr 2, 2013 | Discussions
jacquelyn Regular Member • Posts: 138
Have been using Qimage for years with my PC; however, I am switching to an Imac and this is one program that I will miss a great deal. (won't work with Mac's).
Any suggestions?  I have been googling around but so far what I have found is a bit difficult to understand. I will of course download trial versions when the computer arrives but thought I would check if any one had any high marks for anything in particular.
Thanks.
Howard Moftich Veteran Member • Posts: 7,854
Re: printing rip for IMAC
download/use a virtual machine (Fusion/Parallels/Virtualbox) and run Win7/Qimage in that on the Mac if you really must have it.
jacquelyn OP Regular Member • Posts: 138
thanks, I have been struggling with the idea of running a program that will allow windows, but thought it would compound the learning curve. However, if that is the only option for a few programs I may need to re think this issue.
MacXTi Forum Member • Posts: 92
Maybe you should describe what the program does so well that you are wanting done on the Mac.
Rory
Well, it's the 'sanest' option.  Virtualbox is completely free ($0) so you can easily road test that as long as you have a copy of Win7 or even XP.  There will be a learning curve but certainly not as much as learning a new RIP-'ish' application.  You could try BlueCubit or TurboPrint
I have copies of both xp and windows7 so that isn't an issue.
You have been very helpful in giving me information to help in my decision.
Perhaps it is a matter of familiarity as I have been using it for years.
However, I tested it before purchased years ago and it made a difference in the print quality.
Sharper images (and I am a sharpness freak ), allows printing layouts , printing tiff files, and even RAW if one likes. At a reasonable price.
With my research I found something for Mac's but it was a huge difference in price and the tutorial wasn't as easy to understand.
Just a few reasons.
gaussian blur Veteran Member • Posts: 5,458
What were you using before it?
All of that can be done with Mac native software, and likely do a better job too. I use Lightroom but there are many options.
What software was that? Even iPhoto can do what you listed.
Conchita Veteran Member • Posts: 9,914
Yes, what gaussian blur said. The reason there's never been anything like q-image for mac is that the demand just isn't there, because OS X never had the printing challenges that windows had. The idea of needing a program just for printing is very alien to mac users who aren't windows switchers, although mac printing isn't without its own pitfalls.
The reason the mac rip you found is so costly is probably that it's some kind of a commercial  program.
I have been using Qimage
I understand about supply and demand as well as what these programs for a Mac bring to the commerical enivornment.
However, for my workflow I don't want to print from either LR or PS. LR I don't care for which I realize is probably strange for most folks these days.
Am sure the learning curve will be fun when the computer arrives, and I will find a lot of things that may be available that will leave other software in the dust.
Just have been doing a lot of printing this weekend when it hit me that Qimage was not going to be an easy changing of a licenses.
thanks to all for your tips and suggestions.
graybalanced Veteran Member • Posts: 4,863
This is dismissing the original poster too quickly. Qimage is serious software, and to lump its capabilities in with iPhoto is to greatly oversimplify the comparison. The people who use Qimage to set up advanced fine art printing, and the printing services who gang up customer jobs with Qimage, for example, would find their needs not met in the least by iPhoto.
The plain fact is that there is no Mac equivalent for Qimage, just as there is no Mac equivalent for ProShow Gold (another powerful application that Windows ask Mac users ask about, but get incorrect answers for).
Right, but you said Qimage made a difference in the print quality. My question is compared to what?
I'm not suggesting someone use iPhoto instead of Qimage. What I'm saying is the list of things jacquelyn said were important are not unique or even hard to do. If something low end like iPhoto can do it (which it can), then higher end apps can certainly do it, and quite a bit more.
There's no need for Qimage on the Mac, that's why. Nothing it does can't be done with existing Mac software. Plus the author won't write it since he hates Apple.
What incorrect answers do Mac users get about ProShow Gold? There's no Mac version, but there are several other slide show apps that do run on the Mac.
BeachnCruz Senior Member • Posts: 2,034
Ditto .... graybalanced stated the situation very well. There are many Mac Users that have chosen to use outstanding PC applications like Qimage and ProShow Gold on their Macs, because these applications are so good at what they do.
http://www.ddisoftware.com/qimage-u/support.htm
Jim
I ran test using Qimage vs Photoshop on controlled files and the Qimage prints where sharper, and as a sharpness 'fool" that is important.
IMO, much depends on how you ran your test(s).  There are a number of sharpening options and many parameters and techniques you can use/set in PS, not to mention external plug-ins like PixelGenius, NIK, Topaz that can create myriad results from bad to good to great, esp. if you're an adherent to the 3pass (capture, creative, output) sharpening workflow idea.
Jacques Cornell
Jacques Cornell Veteran Member • Posts: 6,330
Sharpening tools, not RIP
My friend uses ImagePrint ($1500). I use Topaz/Nik plugins to sharpen and then print straight from Aperture up to 16"x24" on my Epson 4000. There's very little difference in sharpness, or even overall print quality. If sharpness is your thing, you don't need a RIP to get it. You just need good sharpening tools in your image editor. Unsharp Mask in Photoshop doesn't count.
'No matter where you go, there you are.'
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 12-35mm F2.8 +27 more
Re: Sharpening tools, not RIP
good to know, as I have those tools available as well.
I will give it a trial run when I get everything set  up as I want to keep the workflow as simple as possible.
