Sensor Size & Versatility
Started Apr 2, 2013 | Discussions
Martin.au
Martin.au Forum Pro • Posts: 10,271
Re: Sensor Size & Versatility
Biggs23 wrote:
EinsteinsGhost wrote:
I didn't pick his lenses. He picked his own, to advertise what he fits in a "small waist" belt. I picked mine, for focal lengths, I would normally carry which generally is about small, fast primes. If you want to take up the challenge, what kind of weight and size are you looking at with lenses to match the FoV I mentioned with a FF body?
Who cares about weight? I thought we were originally talking about image versatility?
Any opinions I express are my own and do not represent DPReview
The definition for versatility wasn't specified.
You don't care about weight?
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
joejack951 Senior Member • Posts: 2,682
You commented on the weight of his kit and compared it to the weight of yours. To me, that gave the impression that you saw the two kits as somehow comparable.
You have a field of view of 15-75mm full frame equivalent. If I had to match your focal length range, I'd get a 16-35/4 VR and a 24-85/3.5-4.5 VR lens which tip the scales at a combined 2.5 lbs. As it stands, the widest lens I own is a 24-120/4 VR that I rarely shoot at 24mm. Maybe someday when other things aren't screaming for my money I'll pick up an ultrawide. They seem like fun at times.
FWIW, if I wanted to travel really light and had a D800 (I don't), I could probably get by with just the 16-35/4 VR at 1.5 lbs. and crop to get to 70mm equivalent (leaving me with 9MP images).
I like this game.
By my reckoning that puts you at 1578g - 900 for the d800 and 678 for the lens.
For me
OM-D, 12-50, 75-300, 60mm macro, fl300r - 1350g. (That's a small kit I carry quite often).
FF focal length - 24 to 600 with macro.
Add in the 7-14 for 1650g
If we're going to keep shrinking sensor sizes, a Canon SX50 weighs 540g and has a 24-1200mm equivalent lens with macro mode. I'm sure there's a wide angle converter somewhere for it. At $430, it sure beats the $4300 cost of your kit.
FWIW, a D600 plus 18-35 and Tamron 28-300 costs about $3400 and weighs 1700 grams.
 joejack951's gear list:joejack951's gear list
Nikon Coolpix AW100 Nikon Coolpix P7700 Nikon D300S Nikon D3S Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Martin.au
I like this game.
For me
Well as I said at the start, FF won't win a size battle, or price typically, against m4/3 and generally m4/3 won't win a size battle against bridge cameras.
Eg: OM-D, 9-18, 14-42, 40-150 - $2000-2200ish and less than 1kg.
69chevy Senior Member • Posts: 1,617
The constant arguing of valid points only proves that all current formats have their place in the world.
If they lose their place, they go away. (People don't buy them).
I will say again if by versatile you mean these dictionary definitions,
 69chevy's gear list:69chevy's gear list
Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM Canon EF 135mm f/2.0L USM Canon EF 16-35mm f/4L IS USM +1 more
coudet Veteran Member • Posts: 3,869
No one wins or loses that battle, same size.
If one wants something that handles well, MFT falls a little short, though GH3 is a big step in the right direction.
Lower performance should always cost less. Though, equivalence works against MFT here.
In FF terms: 18-36mm F/8-11, 28-84mm F/7-11, 80-300mm F/8-11.
Not horrible for such a small format. Though, I like the F/2.8 pancakes better.
.competently1. Capable of doing many things   2. Having varied uses or serving many functions.   AND   is:competentlyIf your definition of               If any of these considerations have to be factored in, then you can comprimise your way down to your iPhone being the more versatile.   Size, weight and cost not being factored, a pro-bodied DSLR, with an arsenal of lenses, is the most versatile camera in the world.   Then you realize that this entire question is impossible to answer.   2. Adequate for the purpose.   1. Properly or sufficiently qualified.
I am not sure why my formatting went crazy, but this is what I typed. I am on an old version of IE and cannot edit.
AND
If your definition of competently is,
1. Adequate for the purpose.
2. Properly or sufficiently qualified.
Then you realize that this entire question is impossible to answer, even the definitions are subjective.
If any of these considerations have to be factored in, then you can compromise your way down to your iPhone being the more versatile.
EinsteinsGhost
EinsteinsGhost OP Forum Pro • Posts: 11,977
I commented on this argument:
ljfinger wrote:
Ulric wrote:
And the Canon FF primes or zooms will easily fit into the fridge you brought to the picnic.
People that claim there is a meaningful difference in physical size are kidding themselves, in my opinion.  I use a small waist pack and carry a full-frame camera with four lenses two teleconverters and a full-sized flash plus accessories like batteries, filters, cards, micro tripods, and even a water bottle, site map and snacks.
The person you responded to is definitely exaggerating, but so are you. How much space and weight do you think a FF camera, with an ultra wide zoom, a wide angle prime (20-30mm), a normal fast prime (50mm) and a short fast telephoto (85mm) cost?
Not much...like I said, I use a small waist pack, and that includes a 70-200/2.8, a 24-105, a 15mm fisheye and a 35/1.4.
You might want to also note that I didn't stop with couple of zooms to cover a FL range. So, let me ask again,
How much space and weight are we talking about, carrying an ultra-wide zoom, a wide angle prime (pick 20-35mm), a normal prime (50mm) and a 75-90mm short telephoto prime? With NEX-6, you're looking at about 2 lb, or the weight of a typical Full Frame body-only.
Irrelevant to the discussion.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
EinsteinsGhost
Versatility of anything isn't about considering a select piece of the entire makeup. It is something's ability to adapt easily to several different situations.
EinsteinsGhost
Jorginho wrote:
It can't do it all.
It can do pretty much anything a comparable DSLR/DSLT can. However, it will be a tall order to reverse that.
It cannot shoot BIF or sports very well.
Well, if you cannot, but I can, then it isn't the tool that is the problem. Although, I don't shoot BIF and Sports regularly. But I know, anytime I want to, I can as these test shots should tell you, and those are with the most basic and the very first of NEX-series (NEX-3):
Auto Focus
Manual Focus
No long zooms available.
Non-issue to me. It is extremely rare for me to feel the need for anything past 135mm (200mm equivalent). In some of these cases above, are the few moments I go to 200mm or better.
Of course, a superzoom like FZ-200 or Sx50 could do it all too. Could do more.
Let me see it.
Sony lenses for the NEx cannot do what DSLR lenses can in that department. Samsung and m43s have better IQ in general, a lot better and m43s has a much longer focal length. But even these are not where DSLR systems are yet.
Sony NEX can do more than a comparable DSLR can. To repeat, I can if I were to carry just one camera today, for its versatility, Sony NEX-6 would be my pick. Not any comparable DSLR, not any DSLT. And forget m4/3 and lesser cameras.
EinsteinsGhost
Compromise is a part and parcel of versatility. And in fact, smart phones exist on that premise, and from portability, to functions (camera, video, phone to challenging laptops).
Biggs23 MOD Veteran Member • Posts: 4,014
Not within the realm of today's most popular cameras and lenses, no. I'm not going to carry around 100lbs but if I'm looking for versatility I'm going to take something that's truly versatile in terms of the creation of the final image. FF + lots of 2.8 or faster glass meets that criteria better than anything else available.
Any opinions I express are my own and do not represent DPReview.
 Biggs23's gear list:Biggs23's gear list
Nikon D4 Nikon D750 Nikon D5 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +4 more
Exactly, making my original (from the first thread) argument even stronger.
True.
Versatility is about what gives the best performance in a widest range of shooting scenarios, that's FF.
Jorginho wrote:
It can't do it all.
No, it can't, depending on what you mean by 'comparable' anyway. It can't do a LOT of things that a FF dSLR can.
A non-issue for YOU, but not for a lot of other people. That's just one of the the things it can't do.
Again with this 'comparable' thing. What's your definition of 'comparable'? The dictionary definition of 'comparable' just means 'able to be compared', which means that ALL dSLR's and SLT's are comparable.
But what does what YOU would choose have anything to do with the original question?
He provided his idea, to respond to mine.
Ok, so he didn't respond with exactly what you asked for but instead stated what he carries. A reasonable response but not much good for a direct comparison of versatility, weight, and size. However, the fact that his kit fits in a waist pack (versus say a large backpack) is still relevant to the discussion. You aren't putting your NEX kit in your pocket either and most likely put it in a bag of some sort in lieu of always wearing a jacket with large pockets or some other workaround to avoid a bag.
Nikon D600, 18-35/3.5-4.5, 35mm f/2, 50mm f/1.8, 85mm f/1.8 = 1886g / 4.1 lbs.
For almost zero weight increase (+25g), you could swap the 85/1.8 for a Tamron 90mm f/2.8 macro for some added versatility.
Weight difference: 2.1 lbs., Ergonomics and DOF control of FF system: Priceless
I'm just making conversation. We don't need to always be in constant argue mode.
olliess Senior Member • Posts: 1,069
joejack951 wrote:
...the fact that his kit fits in a waist pack (versus say a large backpack) is still relevant to the discussion.
Does he use something rather larger than this?
http://store.lowepro.com/beltpacks/outback-200
EinsteinsGhost
joejack951 wrote: Ok, so he didn't respond with exactly what you asked for but instead stated what he carries. A reasonable response but not much good for a direct comparison of versatility, weight, and size. However, the fact that his kit fits in a waist pack (versus say a large backpack) is still relevant to the discussion.
As I said then, lugging around 8+ lb of gear, even if held by just a string, isn't my idea of small, light and convenient. I offered to make a direct comparison.
But one can put a NEX-6 in a pocket. In fact, if I'm out shooting casually, I might not need a bag at all (that is the kind of gear list I provided). And correct, I'd be wearing cargo shorts/pants.
Nikon D600 (850g) versus Sony NEX-6 (345g) - Size Comparison Body only
Nikon D600 w/16-35mm f/4 VR versus Sony NEX-6 w/10-18mm f/4 OSS*
*used 18-55 OSS lens, but 10-18 is thicker and slightly heavier, but otherwise comparable.
Sony 10-18 offers a 15-28 FoV and the Nikon has 16-35, fairly comparable. Now combined weights:
Sony NEX-6 w/10-18 f/4: 570g (345g + 225g), 1.25lb
Nikon D600 w/16-35 f/4: 1530g (850g + 680g), 3.4 lb
EinsteinsGhost
Not really. Because your argument was one-dimensional whereas versatility is about being multi-dimensional. And generally speaking, Jack of all trades and master of none is better representative of versatility.
Draek
Draek Senior Member • Posts: 2,028
No, that'd be a medium format camera equipped with a handful of high-quality prime lenses, as results of upsampling are never as versatile as capturing a larger, more detailed image to begin with in terms of producing a final image.
It's a tad impractical for some situations (such as street shooting, or photographing a classical concert), but then so are 35mm SLRs and f2.8 zooms (such as in street shooting, or photographing a classical concert; funny that).
 Draek's gear list:Draek's gear list
Fujifilm FinePix F70EXR Samsung TL500 Canon PowerShot A1200 Sony Alpha DSLR-A390
Not in this case.
The trade is photography, the tradesman is the photographer.
Which tool allows him/her to produce better results in the widest range of conditions?
This tells you which tool is more versatile.
