HS50EXR and F900EXR reviews, continued ...
Started Apr 2, 2013 | Discussions
jcmarfilph Veteran Member • Posts: 7,592
Re: part 14 -- dynamic range extension ...
Kim Letkeman wrote:
I note that there seems to be some doubt about how bad DR100 is for general purpose shooting.
So I cut to the chase and show you exactly what you lose when you shoot DR100 ...
In anything approaching challenging light it is ruinous and a complete waste of time ... but see for yourself ...
http://kimletkeman.blogspot.ca/2013/04/hd50exr-review-part-14-dynamic-range.html
Deliberately shooting at +2/3 EV what a joke. Who shoots that way and recover it later? Use proper metering and I bet you wouldn't see any difference at all.
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
Peter71951 Contributing Member • Posts: 553
-=[ Joms ]=-
Anyway, I shot these at +2/3 EV so that I could see some detail in the lamp itself. There is so much light above, below and to the right that the lamp was otherwise a silhouette.
That's the reason. Set your eyes on DR400 please.
Peter
Kim Letkeman
Kim Letkeman OP Forum Pro • Posts: 33,333
PerH wrote:
Very good test Kim. This is not news. DR400 is superior in most situations.
Thanks. It's not news to you, but some do need to be reminded now and again ...
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F200EXR Fujifilm FinePix F770EXR Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GF3 +16 more
Kim Letkeman
That statement shows such a profound lack of understand of what the meter is for that I feel for you as a photographer who chooses to learn nothing about the fundamentals. So start by rereading the reason for my choice and see if you can fathom what I was driving at.
I'll wait ...
Now ... as I said, I did not want a silhouette of the lamp. Had I exposed for the highlights, I get no detail in the shadows. They turn to mush if I lift them with such a tiny sensor (sound familiar?)
So instead, I expose at a compromise setting by compensating the meter. Lifting the shadows a bit during exposure allows me to get more detail with less noise and I can pull back the highlights to retain detail there as well, but only if I shoot at DR400 and take advantage of EXR's extended dynamic range.
I am certain that you skipped over that entire explanation to make some sort of inane comment ... so have at it. I only acknowledged you because your comment was too naively (or intentionally) obtuse to be left without response ...
Kim Letkeman
-=[ Joms ]=-
Yes, exactly.
MitchyK7 Regular Member • Posts: 131
Kim, I used to avoid DR400 all the time on my HS20, as i found it tended to flatten the images. Much like zooming in, but without zooming in. The images would loose the feeling of depth, so i would only use DR400 or higher for specific shots, fast speed, sunsets etc. So with this in mind, how would you say the HS50 fares in regards to image depth at more or less constant DR400, and what is the best way to counter this? In composition, or in PP? And how?
Many thanks for all the work, i've actually learned a lot more from these boards (Myfinepix, is a shambles these days) about my camera than Fuji bothered to inform me about it. lol
Just by using +2/3 EV knowing Fuji cams tends to blow highlight is a sure sign of ignorance and blatant work to justify your claim which in reality will happen only to 1/1000 shots.
I'll wait ...
Then expose the lamp and deal with the highlight (exposed using -EV). Sounds familiar?
Blasting +2/3 EV on an already bright subject is a disaster.
Again, wrong metering.
I am certain that you are doing crafted lousy comparison to justify your claim about MSize being always better than LSize and then now DR400 being always better than DR100.
-=[ Joms ]=-
Kim Letkeman
I feel diminished ...
I'll wait ...
*sigh* ... I honestly wish that you knew how to express what you think you are saying, because what you wrote makes no sense. By compensating to open shadows I was "exposing for the lamp" .... using -EV exposes for the light, which ruins the exposure for the lamp.
Opening dark shadows on a tiny sensor creates massive noise and smoothing ... whereas pulling down highlights in DR400 mode does no damage at all.
I doubt that you understood that, but you will have some follow-on quip anyway.
As I showed, it is not a disaster if you understand what can be done.
Obviously, only you know what you are capable of handling, and I am certainly not surprised that you do not understand the above and consider it a disaster. I imagine you are very familiar with that outcome ...
Again, you clearly do not understand the purpose of metering.
There are several very good books on getting appropriate exposures for what you are trying to accomplish ... you might want to get yourself some of them and actually read them. The first few in the list here are excellent.
http://kimletkeman.blogspot.ca/2010/04/my-favorite-ie-best-photography-books.html
Frankly, the effort to try to think in terms that can get through a Neanderthal level of understanding of the fundamentals makes me realize that I should never have taken you back off of the ignore list. It diminishes me to have this interaction and I need to stop wasting my time.
Kim Letkeman
The flattening is a good thing is you are after the best possible capture. You want the least level of tone and sharpening so that you can apply that during processing.
However, JPEG shooters will want to experiment with DR400 plus a film mode. That should allow for more pleasant tones at the risk of blowing highlights or blocking shadows. But the finished product will have more punch.
I edit every image, JPEG or RAW. If you have not read my EXR article, then you should do so. I clearly explain why I recommend what I recommend. I also clearly explain the many variations in settings that are used for various circumstances (which puts the lie to the comments form Dave that I advocate one set of settings for every situation) ...
Yes, there is much to learn and Fuji makes it incredibly complex.
CAcreeks
CAcreeks Veteran Member • Posts: 8,926
MitchyK7, DR400 should not flatten shadows
Could be the HS20 has a different implementation.
In the DPreview test of the F200EXR, note that the tone curve for DR400 is exactly the same as DR100 in shadows until you get past midtones, then it rolls off instead of climbing steeply.
http://www.dpreview.com/reviews/fujifilmf200exr/9
Wellington100 Veteran Member • Posts: 8,338
Re: I feel diminished ...
I'll wait ...
I can't understand why your settings have suddenly become controversial with the HS-50. The bottom line is if people don't want to use the high DR capability of the EXR sensors, why buy them in the first place? It does not makes sense to me to use these cameras and not take advantage of the expanded DR.
Its the same reason why I would much rather have the X10 than the X20. The X10 has a unique selling proposition around its DR with great benefits for all day shooting in any light conditions, the X20 is just a step on the way to a RX100, its not unique in any meaningful way.
Doctors are bad for your lifestyle.
CAcreeks
Re: diminished by no EXR
I agree.  Rather than pontificate further, I offer a non-EXR image showing <irony> really excellent dynamic range!
EXIF stripped but this is from Canon D10, perhaps still the best waterproof digicam. Yup that's Brian taking a picture of me taking a picture of Anasazi petroglyphs.
Photo (c) 2013 Brian Vogt
You look like were up the creek, with a paddle
I'll wait ...
It's on the bottom of my list why I bought the HS50. Speed, reach, excellent manual zoom, built and ergonomics and competitive IQ are the primaries. By shooting RAW I can forget the advantage of DR400 MSize in JPEG. And I am not a primitive user who thinks EXR should be used at half resolution only.
-=[ Joms ]=-
Kim Letkeman
several new parts ...
I love that one ...
I spent some time today performing a few tests that I thought were needed, including one that explains very well why we see so many blurry images from the HS50EXR.
I will be performing other tests of course, and if you have some you want to see I will try to get them done before the cameras go back in a week.
If you want to comment or make a request, you know where to find me and you know where to find the reviews.
CAcreeks
Shoot HS50 in Burst Mode!
Thanks a lot for review #15 on burst mode. Totally amazing how sharpness improves during the burst.
Is this also advisable for the F900EXR? I would think so.
Re: Shoot HS50 in Burst Mode!
I have advised that setting since I started using HS30.
http://www.dpreview.com/forums/thread/3269226
It does not improve sharpness at all but it only gives you higher rate of keepers especially on shots with very low shutter speed and the important thing is it allows you to use the camera buffer so you can continuously shoot and track the subject.
Check my HS50 settings, you won't regret it.
http://www.dpreview.com/forums/thread/3452045
-=[ Joms ]=-
Tim39 Senior Member • Posts: 2,884
Any chance of getting a link to that review?
Tim
CAcreeks
http://kimletkeman.blogspot.ca/2013/04/hs50exr-review-part-15-shooting-in.html
Also
http://kimletkeman.blogspot.ca/2013/04/hs50exr-review-part-16-film-modes-and.html
and
http://kimletkeman.blogspot.ca/2013/04/hf50exr-review-part-17-white-balance.html
nicknd99
nicknd99 Regular Member • Posts: 186
Re: several new parts ...
Kim Letkeman wrote:
I love that one ...
Kim,
Took a look at your latest results, thanks!  Would you shoot burst mode for stationary subjects as well?
 nicknd99's gear list:nicknd99's gear list
Fujifilm X10 Fujifilm X-S1 Fujifilm XF1 Fujifilm X30 Fujifilm X100T +17 more
