Ultra wide portable background?
Started Apr 1, 2013 | Discussions
Mark A. Small
Mark A. Small Contributing Member • Posts: 595
Does anyone have a suggestion for a very wide portable background?  Ii photograph a lot of dancers and I am looking for something 15' wide, white and that can form a nice clean line with the floor or a piece of seamless that I lay on the floor.
thanks.
Mark
its all about creating a place you can be yourself, and in an instant, allowing me to capture you as art...
www.markandrewimages.com
Sailor Blue
Sailor Blue Veteran Member • Posts: 9,173
Re: Ultra wide portable background?
Several strips of seamless cut off and taped together with a little overlap then taped lengthwise to the wall and floor.
Overlap so that the overlap throws the least the least possible shadow.  Not sure about the wall but for the floor overlap the one closest to the camera on top the one furthest from the camera.
Living and loving it in Bangkok, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Tamron SP AF 90mm F/2.8 Di Macro +10 more
robertfel Contributing Member • Posts: 723
Put the seamless paper up horizontally.
 robertfel's gear list:robertfel's gear list
Nikon D700 Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +11 more
Mark A. Small
Mark A. Small OP Contributing Member • Posts: 595
Thanks for your comments.  The problem with putting seamless paper up horizontally is it isn't easy and in some cases it isn't possible depending on the walls.  I shoot in dance studios frequently and the dance barres typically run the circumference of the room.  So while it is a good, inexpensive solution - it won't work for me.
If anyone else has any experience or solutions with this, I'd appreciate your advise.
Thanks.
