Sigma 35 f/1.4 and 5D Mk III?
Started Apr 1, 2013 | Discussions
pso Veteran Member • Posts: 3,017
Hi all - Wondering if anyone has this combo and your opinions on how the lens performs with this camera.
Also, how do you find the autofocus (speed, accuracy)?
Thanks.
Pak K So
'Enjoy your life, guy'
Canon EOS 5D
bhollis
bhollis Veteran Member • Posts: 3,180
Re: Sigma 35 f/1.4 and 5D Mk III?
You might find this thread of interest.
http://www.dpreview.com/forums/post/51145082
arnie1 Forum Member • Posts: 88
Thanks.
Pak K So
I have this exact combo and it is as good as it gets. The lens performs beautifully and is very accurate at all distances. Couldn’t be happier
pso OP Veteran Member • Posts: 3,017
Thanks, believe it or not I did search and did not find anything useful.  I will look at the post.
Pak K So
Thanks arnie...I am very tempted : )
Pak K So
Collett
Collett Veteran Member • Posts: 5,018
Great combo.  I would highly recommend the Sigma 35F1.4Art.
I find it to be on par with my Canon primes in terms of AF speed, and actually the focus accuracy has been better with the Sigma 35 than with my 50L because I have been having problems with inconsistent focus on the outer points with that lens and not others. No problems or issues with the Sigma whatsoever.  Here are a few shots.
Thanks.
Pak K So
Jim
Thanks Collett for the input and excellent samples as well.  I think I am gonna go for it.
Pak K So
Collett
Sure thing.  Did I mention how sharp the lens is wide open? You are not going to find anything better at F1.4.
Pak K So
Jim
I am excited for sure for the sharpness boost...my biggest fear is the autofocus from the Sigma.  I have read a small handful of mixed reviews about this (not many)...knowing my luck, I'd get one of the problematic ones.
Pak K So
ScottD1964 Senior Member • Posts: 1,324
There is a huge difference in Sigma lenses in the last year or so.  Starting with the 85 f1.4 and current 120-300 f2.8 HSM OS through the new current line up releases they seem to have solved many of their focus issues as well as QC issues.
While not being OEM lenses, Sigma is certainly stepping up to put themselves to the front of the line on third party lenses and with the 35 f1.4 they have put themselves at the head of the pack for OEM or third party offerings.  That is pretty impressive at 1/2 to 1/3 less than the OEM offerings.
Scott
 ScottD1964's gear list:ScottD1964's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R Rokinon 8mm f/2.8 UMC Aspherical Fisheye +3 more
millan Forum Member • Posts: 58
I was deciding between this lens and Canon EF 35 mm f/2 IS USM and was biased against Sigma after bad opinion from the past. But this lens totally blowed me away! No FF/BF focus issues, exeprionally sharpness wide open and nice bokeh. I absolutely love this lens!
5D Mk III + Sigma 35mm f/1.4 HSM, f2.0
5D Mk III + Sigma 35 mm f/1.4 HSM, f1.4
onechobeach Regular Member • Posts: 232
Been considering this lens and has been hesitant because of the lack of weather sealing.
Had been considering the Canon but that has no weather sealing either.
We have lots of bad weather here in the north of England and likes shooting out in all weathers.
Has been waiting for a Canon 35mm F1.4 mk 11 but that is likely to cost a huge sum of money.
Considers because the reviews of the Sigma have been superb.
MadManAce Regular Member • Posts: 197
I do not mean to hijack this thread but I am searching for a good copy of this lens.  I know it exists because I rented one from LensRentals.com and it was excellent.  I am running a poll on Fred Miranda / Canon trying to see if others have had better luck.  Maybe the recent batch was hurried to meet demand; but after three duds in a row, I am now considering the more expensive and optically weaker Canon.
 MadManAce's gear list:MadManAce's gear list
Canon EOS 5D Mark III Olympus E-M1 Canon EOS 6D Canon EF 35mm f/1.4L USM Canon EF 85mm f/1.8 USM +6 more
ThatsTheShot
ThatsTheShot Forum Member • Posts: 53
Pak K So
I don't own this lens but was interested in it's performance, I did a search on Google and also found some small report on it's focusing irregularities.  Let's hope this has been addressed/fixed by now.
 ThatsTheShot's gear list:ThatsTheShot's gear list
Canon EOS 5D Canon EOS 5D Mark II Olympus PEN E-P5 Olympus OM-D E-M5 Canon EOS 5D Mark III +25 more
rsn48 Veteran Member • Posts: 7,254
Don't forget "docking station"
Don't forget the docking station which should be out soon, or is out now, to allow you to make adjustments to the lenses software.
Hind sight is always better than foresight, except for lost opportunity costs.
ThatsTheShot
Re: Don't forget "docking station"
Good point, that's very interesting capability, would be interesting to see the outcome.
Daniel Regular Member • Posts: 152
I got mine a week ago.  It arrived with front focusing issue.. have to adjust with +13 focus alignment in my Canon 5D mk 3.
Got some climbing pics from last weekend, all shots at F1.4:
Daniel
Hey Daniel,
Have you noticed any difference with you +13 focus alignment when shot in different lighting than from when you calibrated?  I have tried four Sigma 35mm lenses and all needed significant AF adjustments but when the light (WB) changed the results were unreliable.  I really wanted the Sigma to work but I was forced to buy the Canon 35L and forever I will know that I paid more for an optically inferior lens, but for me focus always takes top priority.
The Photo Ninja Senior Member • Posts: 2,239
It should be free!
I shouldn't have to pay to update the lens firmware.  What a load of crock!  Btw, just got this lens two days ago.  Good so far, but it did cause my camera to lock up and I had to remove the battery after about 40 shots.  I've taken a hundred since then with no issue.  Sharpness at 1.4 is good and at f/4 exceptional.
MadManAce wrote:
Hey Daniel,
Focus is constant in different lighting.  I only time I noticed that focus is not constant is if I set to Single-point Spot AF when testing on tripod with cable shutter release.  However all other AF selection are ok, even Single-point AF.
