X100s OVF frame lines accuracy
Started Apr 1, 2013 | Discussions
Lakeview Man Regular Member • Posts: 340
Hi all,
feeling a bit of Gear Acquisition Syndrom these days because I'm tired of waiting for the XF23mm for my X-pro1. So, what do I want? A second camera body! - with a 23mm - easy solution = the X100s I will miss out on the f/1.4, but I will get a second camera.
Now, with my 35mm fixed on my X-pro1 for many situations I find that I use the EVF just because the frame lines in the OVF is not as accurate as I'd like them to be.
How accurate are the frame lines on the X100s? Can you compose your picture without doing any cropping i post process?
 Lakeview Man's gear list:Lakeview Man's gear list
Fujifilm X100T Nikon D810 Canon EOS 7D Mark II Fujifilm X-Pro2 Canon EF-S 10-22mm f/3.5-4.5 USM +17 more
Fujifilm X100S Fujifilm X-Pro1
Gary H Senior Member • Posts: 2,162
Re: X100s OVF frame lines accuracy
Short answer is 'no'. Long answer, with some.. very little.. experience, this isn't an issue.
 Gary H's gear list:Gary H's gear list
Fujifilm FinePix X100 Fujifilm X100S Canon EOS-1D Mark III Sony Alpha NEX-6 Sony Alpha 7 +13 more
Oger Junior Member • Posts: 43
I had this problem with the X100 as well.
Not accurate at all. Switch to EVF for critical compositions.
Lakeview Man OP Regular Member • Posts: 340
Thanks,
For critical framing, I guess I can live with that.
But does anyone know if the frame lines are more or less accurate than the X-pro1/XE-1 with the 35mm on?
(unknown member) Senior Member • Posts: 1,321
The Fuji X OVF framelines are only estimates. This situation is similar to what you will experience with cameras using mechanical OVF rangefinders.  Some analog rangefinders make better estimates than the Fuji and some don't.
With regard to composition the advantage of  the OVF is you can see what's outside of the frame. The disadvantage is the frame is just an estimate.
I use the OVF as much as possible and switch to the EVF when framing is critical, the subject is closer than about 6 ft or when AF  region accuracy is important.
 wchutt's gear list:wchutt's gear list
Fujifilm X-Pro1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +20 more
N_Architect Forum Member • Posts: 50
Reading this thread, brings up a question in mind: I have the X-Pro1 and the X100S, used them little so far.
When I work with the OVF on, I notice (in both cameras) that pressing the shutter button half-way through, in order to focus and then recompose, the frame lines (the whole frame 'box' inside the OVF) moves right and down (i.e. south, south-east).
This makes framing so difficult. Is it normal, or is there something I can do to change it?
 N_Architect's gear list:N_Architect's gear list
Canon EOS-1D Mark II N Olympus E-1 Samsung NX10 Canon EOS 5D Mark III Nikon 1 V2 +15 more
nubsimo New Member • Posts: 12
This has to be, to correct the parallax error between the OVF and the lens. The moved framelines are about to show you the final frame, that will be captured based on the distance between camera and subject. You can still compose right by using the additional centered focus point... Its a feature, not a bug.
Well noted, many thanks.
Did not get fully what you described by using the "...additionally centered focus point..." but I'll take a look at the manual (user guide) plus will read more here so then hopefully I'll be able to practice and get it right.
baobob
baobob Veteran Member • Posts: 7,222
My estimation for my X100 is 85%
With 35mm and XP1 there is still an uncorrected issue, the 18mm and 60mm being all both also 85%
Sony RX100 Olympus Tough TG-4 Fujifilm X-T1 Nikon D7200 Fujifilm X-T10 +12 more
kreislauf Forum Member • Posts: 57
Jesus common! Do people read before they drop more than 2000 $ on equipment!? I kind of envy and hate those users at the same time!
Parallax correction was for many of us a huge selling point to invest into the ovf, especially when you focus below 10 ft..
 kreislauf's gear list:kreislauf's gear list
Sigma DP3 Merrill Fujifilm X100T Nikon 1 V1 Leica Summilux-M 35mm f/1.4 ASPH Leica Summicron-M 50mm f/2 +4 more
darngooddesign Senior Member • Posts: 4,692
Jesus Kerislauf! Do people read before they post on a two year old thread!? Etc....
www.darngoodphotos.com
 darngooddesign's gear list:darngooddesign's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8
