D7100 - Face close-ups test images, harsh lighting, ISO 1600-6400
Started Apr 1, 2013 | Discussions
RudyPohl
Senior MemberPosts: 3,718
Apr 1, 2013
In order to test my new D7100 the staff at our local camera store agreed to let me shoot and share their portraits. The lighting was a mixture of overhead florescent and natural light coming in the storefront windows. The images were shot at ISO 1600, 2200, 3200, 6400. I left the WB on auto figuring it could do a better job than I could in the mixed lighting.
Images were shot in RAW, converted to JPEG in View NX2, lightly processed in Photoshop CS5. The lens was the Nikon 70-300 G VR.
Rudy
ISO 1600
ISO 2200
ISO 3200
ISO 6400
Nikon D7100
Sensei Mike
Contributing MemberPosts: 522Gear list
Re: D7100 - Face close-ups test images, harsh lighting, ISO 1600-6400
In reply to RudyPohl, Apr 1, 2013
Hi Rudy, these shoots look good to me which makes me happy because this is the set up Ill be using.
How do you feel about the these shots?
 Sensei Mike's gear list:Sensei Mike's gear list
Nikon D300 Nikon D7100
dzajba
Regular MemberPosts: 180
In reply to Sensei Mike, Apr 1, 2013
TBH on 100% view they look abysmal:/
I know it's 24 mpix and these probably should be zoomed in that much, but there is a substantial loss of detail even at ISO 1600.
RudyPohl
Hi Mike:
In a nutshell, I feel pretty good about these images, I can definitely live with them for my limited uses.
I returned to photography last September after a many-year absence and have discovered a real liking for wildlife photography, so probably 80-90% of all my shots are or birds and animals. However, I do like shooting people and fast-moving outdoor sports in particular (especially men's rugby).
So, while portraiture is not my thing, I do want this camera to be able to take reasonably good-quality facial close-ups under a variety of lighting conditions, some demanding. I figure that if faces can come out as well as these have at higher ISO levels then under more controlled lighting they would be even better.
Rudy
FoolyCooly
Veteran MemberPosts: 3,484
@ 100% everything looks like watercolor. I personally would rather see film-like grain instead of smooth mush. I think you need to scale back your NR in post.
*These are fine for shared 1200 pixel digital files and small print but they will look terrible printed at anything larger than 8x10.
RudyPohl
In reply to dzajba, Apr 1, 2013
Hi dzaiba: All I can say is "it is what it is"....
I always post full-size test images so that I and others can evaluate them at 100%. I took several dozen of these images of the staff at the camera store at various ISO settings and chose the best ones to process and post here. There wasn't much involved regarding my technique, I needed to stay out of the way of customers and shoot on the fly from a distance. So this is what this camera and this lens was able to produce under these shooting conditions.
If you and others conclude that the IQ for these conditions is abysmal, well then I guess it is.
Thanks for your forthright opinion.
Rudy
RudyPohl
In reply to FoolyCooly, Apr 1, 2013
Hi FoolyCooly:
Agreed, pretty crappy looking at 100%. I'll post a RAW image with no NR shortly.
Rudy
RudyPohl
Re: D7100 - Face close-up RAW ISO 6400, zero NR or sharpening
OK, here's the RAW file at ISO 6400 converted in View NX2 with no PPing except for adjusting the brightness levels.
Rudy
ISO 6400 RAW no PPing
Brev00
Veteran MemberPosts: 7,404Gear list
Anything shot with a D7100 is of high interest these days.  I guess you are trying to get a real life set of images for all of us to study, but, I think your choice of lens for this setting is pretty obscure.  If you were using a 50/85 prime or a 17-50 type zoom, I could understand the usefulness of the set.  But, shooting at 300mm indoors wide open is just not a common occurrence.  A variable aperture lens is going to struggle so why put that distraction into a series of test shots of a camera?  A frog won't swim well in boiling water.
www.flickr.com/photos/brev00
 Brev00's gear list:Brev00's gear list
Nikon D90 Nikon D7100 Tokina AT-X Pro 12-24mm f/4 DX II Sigma 17-70mm F2.8-4 DC Macro OS HSM Sigma 70mm F2.8 EX DG Macro +3 more
Mako2011
Mako2011 MOD
Forum ProPosts: 19,764
Still welcome.
In reply to Brev00, Apr 1, 2013
I often shoot wide open with a long lens at events. It helps when your unable to close the distance and still shoot this type of compositions.  I'm thinking this is fine. Might event be the only lens he had so still a valuable contribution to the forum. Perhaps not common but why would we want to only see common examples. In the next few months we will see a thousand D7100 portraits with "traditional" lens...I enjoy an example that pushes the limits a bit. Especially at the worst end of that lens...helps determine if pro glass is really needed.
When preparing the frog for the table...his ability to swim doesn't always have to enter into it
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
scokill
Senior MemberPosts: 2,358Gear list
Those look pretty bad and poorly processed for whatever reason.
SOOC at 3200 on my quick indoor test and a couple of tests at 10,000 (hi .5)
 scokill's gear list:scokill's gear list
Nikon D610 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF Nikkor 50mm f/1.8D +1 more
Brev00
Re: Still welcome.
In reply to Mako2011, Apr 1, 2013
What I attempted to say is that I would like to see a lens selected for these shots that would be able to better bridge the gap between the lighting and the camera.  There is so much noise in these images, I am not even sure they are focused correctly on the subjects.  A slow lens will often miss focus in poor lighting (I should know) creating even more noise in the expanded out of focus area.  So, what I think we are seeing are more the limitations of the lens.
If I were determining a lens purchase from these shots, I would be selling all my variable aperture lenses and getting the trinity or primes.  Tomorrow (I think B & H is closed one more day for Passover).
Touche!
lock
Veteran MemberPosts: 6,178
substantial NR
Way too much for my taste.
Lock
lock
There must be something wrong
I can see the nr artifacts. Her hair is more like a curtain sticking to her head.
Lock
TylerQ
Regular MemberPosts: 340
I don't see anything wrong with these images. For crying out loud! 6400 ISO and such nice results? What do you all expect anyway? Try doing this with a Nikon D1 or D1X from 10 years ago. It's amazing what quality you can get from high ISO images with not only the D7100 but the D7000. But then when you came from a film background and used to shoot Tri-X pushed to 1600, grain is no big deal.
RudyPohl
Hi folks:
Thanks for your forthright remarks above..., please say whatever is on your mind, I want real feedback not baby food.
The reason I used this lens - the Nikon 70-300 VR - is because this is the only I own right now, and will be for a while yet, I suspect. I chose to buy ithis particular one because it's many glowing reviews say it is the best consumer-grade lens available.
I wouldn't for a moment think that this lens could even begin to compare with any quality pro lens, however, it is marketed as a good quality lens that can give reasonably good results under most circumstances so I'm try to determine whether that is actually the case.
So, despite the weakness of the lens, can anyone recommend an approach to post processing that would help mitigate the IQ issues seen in the RAW file?
Thanks again,
Rudy
scokill
In reply to TylerQ, Apr 1, 2013
I agree, but something is up with these.  But I have been thinking that same way recently.  I have a bunch of photos on my HD that I've thought are either too noisy, or this or that and my daughter is putting together a scrapbook of dance photos and took a bunch and printed them out at CVS.  I had no idea and would have spent time cropping, etc.  While they are small prints, they look great  as they are.
joeyv
Contributing MemberPosts: 587Gear list
Looks horrible because of too much NR. Can evaluate the camera better if the samples are w/o NR.
Thanks.
joeyv
mosswings
Veteran MemberPosts: 7,289Gear list
RudyPohl wrote:
Hi folks:
Thanks again,
Rudy
Let me reset the discussion a bit.  We are talking about ISO1600-6400 in a DX sensor. And the images are still pretty dang good.  You are attempting to take pictures in a dimly lit environment with a lens that is too slow for the task and as a consequence are not operating it at its peak sharpness point nor at the correct shutterspeed to stop subject motion.  That the 70-300 gets soft beyond 220 is also a factor here.
So overall, the pictures look dim, dingy, and with poor contrast.  A lot of that is just the lighting. Here's a shot I took with this camera in not much better conditions with similar shutterspeed restrictions because I wouldn't go beyond ISO 800 in my D90.  You can see similar qualities in the capture:
On the other hand, zoom in to the water droplets on the flowers and you'll see about as much detail as one can expect from a D90 with an 18-105 lens.  The shutterspeed and ISO all worked really well here.  Yes, I was at low ISO, but there wasn't any room for subject motion, and the light was just bright enough to pop the details.
Your 1st and 4th shots show clear subject or camera motion.  In the eyes of the 3rd shot's subject and in the details of the 2nd shot subject's glasses, a surprising amount of detail and quality.  That they're taken at ISO 1600 and 3200 wide open with not the best lens is pretty amazing.
The main problem with these images that I can see is white balance and lack of spot metering on the subject's face, coupled with too slow of a shutterspeed.  I would not use anything less than 1/(2*FL) for any critical shot.  For your 300mm shots, this means 1/600 second. Only in the 4th shot are you coming close to that.  And only in that shot would I say that the IQ and actutance is becoming substantially worse.  I'm dang impressed with the ISO 3200 performance.  That also happens to be the best lit shot of the series.
 mosswings's gear list:mosswings's gear list
Olympus XZ-1 Olympus Stylus 1 Nikon D90 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +5 more
mistermejia
Senior MemberPosts: 3,340Gear list
RudyPohl wrote:
Hi folks:
Thanks again,
Rudy
Yikes!!  Ayayai mama mia!!  Not the nicest looking photos (skin)
I will bet that most likely is not the lens, but that Toshiba sensor, but then again i am not surprised at all being a previous D7000 owner.  I rather see more grain then that way too smooth fake skin look.  I bet is that sensor.  If i am wrong i am buying pizza for everyone here!
Rudy, do you have one or two photos that you might have taken at lower ISO that you can post?
Thanks.
 mistermejia's gear list:mistermejia's gear list
Fujifilm FinePix S5 Pro Fujifilm X-E1 Rokinon 85mm F1.4 Nikon AF-S DX Nikkor 35mm f/1.8G Fujifilm XF 18-55mm F2.8-4 R LM OIS +6 more
