Do lenses have subjective qualities not shown in any technical specification?
Started Mar 31, 2013 | Discussions
Alex Notpro
Alex Notpro Contributing Member • Posts: 975
I used to love the 50 f/1.4D and 85 f/1.8D  on my D7000, but now that I upgraded to a D700 I need a longer lens for portraits. I prefer old 'D' lenses over their AF-S equivalents, as I believe they perform better as investments in addition to taking photos that are 99.9% as good as the newer lenses (I once compared the 50 f/1.4D to the 50 f/1.4G for several days before making this sweeping generalization).
So. Thorn between the 85 f/1.4D, 105 f/2DC, and 135 f/2DC, and not wanting to spend too much money upfront (I don't like buying lenses with the intention of returning them), I decided to buy two old primes to study and compare: 105 f/2.8D Micro, and 135 f/2.8 AI-s.
So now I can play around with cheap primes in the 3 focal lengths, 85-105-135, before deciding which one to drop $1,000+ into.
Now here's where it gets interesting...
After much real-world testing, mostly in "home studio" conditions (kids in my living room, bounced flash and off-camera flash), I quickly concluded that I don't like the results from the 105 f/2.8D Micro.
When bench-testing (lab-like conditions), the 105 is sharp. In real usage, it's too often un-sharp and the colors seem off and unattractive, and boring. The 85/1.8 is a reliable stunner, always sharp in the plane of focus, even wide open, beautiful colors across the frame. The 135/2.8 is a close second, despite being handicapped by the Manual Focus.
Hence the question. Do lenses have subjective qualities not shown on any technical specification? Otherwise, what exactly in the technical specification of these lenses, is the 105/2.8D lacking relative to the other two?
 Alex Notpro's gear list:Alex Notpro's gear list
Leica Nocticron 42.5mm Sony FE 35mm F1.4 Sony Alpha 7 Sony a5100 Panasonic Lumix G Vario 7-14mm F4 ASPH +16 more
Nikon D700 Nikon D7000
RBFresno
RBFresno Forum Pro • Posts: 10,879
Re: Do lenses have subjective qualities not shown in any technical specification?
Yes.
RB
 RBFresno's gear list:RBFresno's gear list
Nikon D2H Nikon D4 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +12 more
paulski66
paulski66 Senior Member • Posts: 2,736
Yes. Of course.
No text.
 paulski66's gear list:paulski66's gear list
Panasonic Lumix DMC-LX5 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +2 more
krikman
krikman Regular Member • Posts: 399
Yes. Lenses have important and decisive characteristics behind specs. Most common annoing flaws are:
1. Optical.
- flares at some conditions;
- looses contrast contra-light;
- complex distortions at wide end; (i.e. not straigt barrel or picussion)
- while most lenses washes far plane smoothly, only few actually renders 'near focus plane bokeh' or as I call it "focus plane transitions". It is most common flaw and reason that some lens "draws" picture, but some not.
In reality is shows as a very thin focus plane sharpness surrounded by harsh transitions. for example of such 'bokeh' picture ruined by 55-200vr, but some defective lenses make it much worse.
This sample from 55-200vr shows bad and intrusive bokeh
2. Mechanical.
- focus ring path too short;
- focus ring rotates with autofocus;
- change lenght while zoom or focus;
- wobbles and clicks inside;
- "eyepiece blow" while zooming.
3. Handle.
- Too thick for comfortable handling;
- Sigmas zoom rotates contra direction for Nikon.
- some zooms distribute weight to far end while zooming.
- Feeling of plastic and metal finish.
Optical qualities often meet in lens-to lens variations, while mechanical and handle issues are common for all pieces of same model.
krikman
Another sample from kit 18-105. Picture destroyed by harsh rear plane while othervize good enough.
Sorry I can't find completely bad pictures from tests because they are gone obviuosly.
PSCL1
PSCL1 Senior Member • Posts: 3,044
Yes, lenses have "subjective qualities" but these are probably a combination of factors which, if identified, could be objectified (e.g. field curvature, vignetting, resolution). E.g. the old 105 f2.5 AI Nikkor was considered the greatest portrait lens of the film era and magical properties were imputed to it.  Consideration of the lens data sheets Nikon used to publish for all lenses revealed that it's optimum aperture was f4, not the typical f8 of most lenses.  Shooting at f4 and normal head-and-shoulders portrait distances, the person being photographed would just pop out from the background, a very 3-dimensional look.  But it was a product of optimal aperture at optimal distance for the likely subject.   If you really want to see posters rhapsodize subjectively about lenses, try the Leica forum, where countless Leica lens owners rationalize the special look of those lenses.  I personally think what they are perceiving is an evenness of resolution and of illumination over the entire field of the lens, giving it a particularly 'real' look.  But I've never seen Leica or anyone else put forth any lens data to support that hypothesis.
 PSCL1's gear list:PSCL1's gear list
Leica X1 Nikon D80 Olympus PEN E-PL1 Panasonic Lumix DMC-G3 Sony Alpha NEX-3N +27 more
Rich Rosen
Rich Rosen Senior Member • Posts: 1,901
Of course they do. On this forum alone, I read how much warmer, more dreamy, sharper one lens of a particular FL is over another lens of the same FL. Those terms are not in any specifications I know of.
 Rich Rosen's gear list:Rich Rosen's gear list
Nikon D810 Nikon D1X Nikon D610 Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +25 more
Emil Varadi
Emil Varadi Senior Member • Posts: 1,255
Definitely. Some lenses can be magical.
Though there will be a number of posters who will dispute this and will try to ridicule those who can see it.
My belief is, they cannot see it, as some people for example cannot see color just black and white.
We has been disputing this at great lenght in this thread:
http://www.dpreview.com/forums/post/50268190
 Emil Varadi's gear list:Emil Varadi's gear list
Ricoh GR Nikon D800E Nikon AF-S Nikkor 24mm f/1.4G ED Sigma 35mm F1.4 DG HSM Art Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR +2 more
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,443
Re: Be realistic!
One of the first "rules" of marketing or selling is to emphasise a products strengths, and to play down or to avoid drawing attention to any weaknesses
There are often important to some, but not necessary to all, performance differences between lenses not mentioned in the manufacturers specification.
There is then the subjective issue of different photographers having different needs.
Someone on a limited budget never making larger than A3 prints can be perfectly happy with a "do it all" lens like they 18-200 DX or FX equivalent. For someone regularly shooting in low light anything slower than f1.4 may be unacceptable.
This is one of the reasons why Nikon provide photographers with a number of choices for any specific focal length.
Leonard Shepherd
Many problems turn out to be a lack of intimate knowledge of complex modern camera equipment.
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
Grevture
Grevture Veteran Member • Posts: 4,180
Agree, and ...
I agree with (most) of what you brought up as examples of "flaws" (or "character as some might call it ) but just wanted to add on to that slightly:
We all have a wild variety of personal hang-ups, habits, preferences, idiosyncrasies that combined with all the characteristics of lenses - both those in and those out of specification - mean some people will like some lenses more then others and it is hard to define exactly why and how it became like that.
What I am getting at is that photography is a creative endeavour which at times makes it hard to pin down what it is with a lens, a camera or a combination of lens and cameras which works better then other combinations.
Example: I absolutely loved the 135/2.0 DC on my D70s and my D200, but I could not use it at all on my D2H and later my D3 - for me that lens was excellent on a small body camera, and did not work at all on a big body camera. Rational? Not very, but none the less how it was for me and I ended up selling the 135. Optically it was the same, in terms of handling it was not.
I don't suffer from insanity, I enjoy every moment of it!
By the way, film is not dead.
It just smell funny
 Grevture's gear list:Grevture's gear list
Nikon D70s Nikon D3 Nikon D3S Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF +7 more
Grevture
Yes, lenses have subjective qualities not shown in technical specifications
Such a generalization might work for some lenses, but certainly not for others. The AF-S 85/1.8 most certainly is a better lens then the older D model. Same with the 85/1.4. For some the difference will be clear and important, for others less so. As for the 50/1.4 I would agree with you - the newer AF-S might be better optically (like noticeably better OOF rendition), but is bigger and focuses slower. I'll keep my Af-D until it falls apart.
In that context you could also have tried the AI-s 105/2.5 - a brilliant gem of a lens
Keep in mind these are lenses made with rather different design goals, a close -up lens like the 105 Micro is great for close ups, for working with extension tubes, for getting maximum sharpness at say f8 or f11 ... While a 85/1.8 is meant to be used wide open or nearly so, and has less focus on contrast and more on pleasing out-of-focus rendition (contributing to a subjectively "better" sharpness.
So, yes, they will be different, because they were made with different uses in mind.
I would not say it is really lacking, just that it is good for different things then you might have used it for. It is after all first and foremost a close up lens, hence the 'Micro' in its name.
Say we had thrown in the 70-200/2.8 VR II in the comparison and went of to shoot a basketball game. Then the zoom would probably have excelled, and the others would have appeared somewhat (or a lot) less useful. That does not mean it was anything wrong with them, just that they were used slightly out of their context while compared to a lens made for exactly such a context.
Some lenses are general purpose tools which work reasonably well in almost all conditions, but excel at none. Others are more specialized, purpose made, and more or less fail at things they were not made for, while excelling at the very things they actually were designed for.
It just smell funny
