Off Camera Flash
Started Mar 31, 2013 | Questions
Wateraddict
Wateraddict Regular Member • Posts: 193
Off Camera Flash
What type of off camera flash are some of you using for the K5 ? Was just reading a few books of Scott Kelby's and he talks a bit about sync the camera to an off camera flash . I would imagine this is probably possible on the K5 . Just wondering what a good starter flash would be or what would be recomended by some of you ?
 Wateraddict's gear list:Wateraddict's gear list
Fujifilm X100T Nikon D700 Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF Nikkor 35mm f/2D Nikon AF Nikkor 50mm f/1.8D +4 more
Pentax K-5
Gerry Winterbourne
Gerry Winterbourne Forum Pro • Posts: 10,847
Re: Off Camera Flash
You'll get recommendations about third party flash guns: I'l leave that to others.  Of the Pentax units the AF-540 FGZ is much the best although it's relatively expensive.  Whatever brand you buy, I strongly recommend that you get one with a swivel head: it's really frustrating if you can't point your flash gun where you want it.
If you've been readingKelby, do you know of David Hobby?  His website is a store of useful information about flash http://strobist.blogspot.co.uk/2006/03/lighting-101.html
You can sync from your K-5 either by using a sync lead, wireless triggers, light triggers or the inbuilt wireless flash system.  The inbuilt system has the big advantage that it's free but (a) its range is limited to about 4m to the off-camera flash gun and (b) it might not work with some third party guns.
Light triggers are (in my experience) a pain but might be worth trying if you want more range at low cost.  After that there are plenty of options but at some sort of cost.
For what I do the inbuilt system works fine.  It uses the onboard flash to trigger the other(s) and you can't turn its output down to zero (as you can with, say, Nikon).  What I do is mount a home-made diffuser on the front of the lens: this reduces or removes harsh shadows if I keep some output from the onboasrd or acts as a handy holder for a bit of black card if I want to cut it out (the light still triggers the remote unit(s)).
Gerry
_______________________________________
First camera 1953, first Pentax 1985, first DSLR 2006
miles green
miles green Veteran Member • Posts: 4,991
I agree with Gerry.
Personally, wireless P-TTL using the pop-up to trigger the off-camera flash has been effective in some cases, but can be a frustrating until you it set up correctly and start getting successful exposures. The user might be at fault here...
I MUCH prefer manual mode with wireless triggers, like for studio flashes.
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +9 more
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,682
miles green wrote:
I agree with Gerry.
http://www.aokatec.com/AK-TTL.html
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
Gerry Winterbourne
miles green wrote:
I agree with Gerry.
Hi Miles.  I'm not arguing, but for the OP I should mention that the inbuilt wireless system supports all the methods on the gun: P-TTL, A and M and (I think) HSS.  Using two sources (onboard + one gun) or three sources (onboard + two guns) you need to use M to be to balance the light from different directions, so I've always used that mode.
Gerry
