Beginner has lens hood question
Started Mar 31, 2013 | Questions
CathyJ New Member • Posts: 18
I've recently graduated from point&shoot to a Sony A57.  It came w/ 2 kit lenses.  The bigger Tamron lens came with a hood, but the Sony 3.5-5.6/18-55 did not come with a hood.  I do a lot of hiking and outdoor photos and quickly realized I need a hood for this lens.  I've looked at Amazon and Ebay and it is overwhelming which one to get.
Is this what I need?
http://www.ebay.com/itm/55MM-Flower-Lens-Hood-for-SONY-18-55mm-75-300mm-A55-A290-A580-A560-/170855660011?pt=LH_DefaultDomain_0&hash=item27c7ca79eb#ht_2904wt_1134
I prefer not to buy one that has to be shipped from overseas (many are from Hong Kong and China).
I welcome any suggestions of elsewhere to buy, or alternate hood that might be needed.  Also, I purchased a Sony DT 2.8/30 macro lens.  I haven't used it yet, but will I need a hood for it?  I'll do a lot of blooms, bugs, and tiny critter photos with it.
Cathy
Sony SLT-A57
Peter A. Stavrakoglou Veteran Member • Posts: 7,759
Re: Beginner has lens hood question
The hood you linked to on eBay is a "universal" hood - it screws onto the lens thread like a filter would.  It will work fine.  I prefer a hood that mounts to the hood mount, not the lens threads and it's for two reasons: 1) I can mount the hood backwards on the lens when not in use so it won't take up the extra space it would with a mounted hood, and 2) the hood will attach easier and quicker when it attaches to the proper hood mount.  This is the hood I would buy (it is from China, though):
http://www.ebay.com/itm/Lens-Hood-for-Sony-NEX-3-NEX-5-NEX-5N-NEX-7-SH112-18-55mm-f-3-5-5-6-16mm-F2-8-/170787783061?pt=LH_DefaultDomain_0&hash=item27c3bec195
My humble photo gallery: http://www.pete-the-greek.com
 Peter A. Stavrakoglou's gear list:Peter A. Stavrakoglou's gear list
Fujifilm X-S1 Panasonic Lumix DMC-FZ200 Sigma SD15 Canon EOS 7D Sigma SD1 Merrill +16 more
CathyJ OP New Member • Posts: 18
I'm glad you pointed that out to me, I didn't realize it didn't go on the hood mount.  I already have a lens filter attached so that hood wouldn't have worked.  I suppose I can choose one from China, I won't be out a lot of money if it doesn't get here.
Hank3152
Hank3152 Forum Pro • Posts: 13,460
If your front element rotates when zooming or focusing than a petal shaped hood won't work......perhaps this is the hood you need, but I'd read the reviews first........
http://www.bhphotovideo.com/c/product/625947-REG/Sony_ALCSH108_ALC_SH108_Lens_Hood.html
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm f/2.8L Macro IS USM +5 more
As far as already having a filter on the lens, you also might have threads on the filter so you could use the hood you linked to.
jhorse Senior Member • Posts: 2,399
Hi, I too hike and have reduced my equipment to the minimum, but still use a DSLR (Nikon D5100).  I have 18-55, 55-200 and 35 lenses all with the same filter thread of 52mm. I opted to buy one collapsible, rubber wide angle hood (for the 18-55) and one collapsible normal rubber hood (for the 35 and 55-200). I also use a protect filer when necessary (although hood also does a good job of protecting the lens element) and a polarizing filer; both 52mm screw in. The filters have front threads so I screw the filter to the lens and then the hood. Never had any issues with vignetting, even at 18mm.  Pro: a simple, small and light weight set. Con: have to screw everything to the front of the lens. For me the pro outweighs the con.
You can get these cheap, collapsible rubber hoods on Amazon. Hope that helps.
 jhorse's gear list:jhorse's gear list
Fujifilm X20 Olympus OM-D E-M10
I bought this lens hood and there is no way it will attach to my 3.5-5.6/18-55 SAL1855 lens.  It's not a big deal because I'm not out a lot of money, but is there something I don't know?  The diameter of the lens hood is the same as the diameter of the lens or the filter.  I can't get past them to the hood mount.
http://www.ebay.com/itm/Lens-Hood-for-Sony-NEX-3-NEX-5-NEX-5N-NEX-7-SH112-18-55mm-f-3-5-5-6-16mm-F2-8-/170787783061?pt=LH_DefaultDomain_0&hash=item27c3bec195#ht_1727wt_900
Never mind.  I found out this lens hood is for the E mount, not the A mount.
