Moire...
Started Mar 31, 2013 | Discussions
Greyser
Greyser Veteran Member • Posts: 4,117
Moire...
Most of K-5 IIs users say that they do not see moire at all. Would someone post something like these, taken with K-5 IIs please?
Thank you in advance,
SG
 Greyser's gear list:Greyser's gear list
Pentax K-5 Pentax K-01 Pentax K-5 IIs Pentax K-3
Pentax K-5 IIs
Direr
Direr Regular Member • Posts: 232
Re: Moire...
You mean something like these?
 Direr's gear list:Direr's gear list
Pentax K-5 IIs Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 105mm F2.8 EX DG Macro +5 more
Greyser
Greyser OP Veteran Member • Posts: 4,117
Re: Moire...
Yes and no. Thank you for the quick reply. Actually it's pretty good. However, I'm looking for the detailed big feathers, like the ones on my samples. Do you have anything like that by any chance?
Thanks again,
SG
Direr
Re: Moire...
Thanks again,
SG
Not really. But I would think the fine texture of overlapping feathers at various angles is perfect to induce moire.
Anyway, after 3200+ shots on my IIs including landscapes, portraits, birds, with various lenses and in different lighting conditions,  I can certainly say I am yet to see any meaningful moire, and I do look for it during pp.
brandrx
brandrx Forum Pro • Posts: 28,107
Re: Moire...
Hi Greyser,
Are you thinking about getting a K-5 IIs?
I've been considering it myself.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
Greyser
Re: Moire...
brandrx wrote:
Hi Greyser,
Ron
Yes. My k-5 is 2 years old and 60+K shots young. Who knows what the new K-3 or whatever else sensor is. If it is introduced in April, it going to take about a year to get a camera in stores and at least first performance info.
jeanphilippe Goube
jeanphilippe Goube Senior Member • Posts: 1,565
I have a couple...
:-)All shots with FA*600 in optimal conditions. In the series below 2 shots exhisbit little moiré or false colors, are you able to point it ? These are common birds easy to shoot, I made these tests to see if moiré could occur. Now I'm not looking for moiré anymore...
Good luck
jpgoube
 jeanphilippe Goube's gear list:jeanphilippe Goube's gear list
Pentax Q Nikon D810 Pentax 01 Standard Prime Pentax smc FA 43mm F1.9 Limited Pentax 02 Standard Zoom +5 more
Greyser
Re: Moire...
Thanks a lot for the help.
jeanphilippe Goube
Re: Moire...
No replies ?
In fact after several hundreds of bird shots like above I haven't seen moiré that really affect my pictures...
The main issue with the K5iis is the price tag. In europe K5ii prices are decreasing, K5iis not; the price difference is now 290 euros - 377 $, thats more than 34 % off
Cheers
jpgoube
Chris Mak
Chris Mak Senior Member • Posts: 1,650
Re: Moire...
High iso chroma noise is more of an issue shooting birds, than moiré. To spot moiré, you will really have to view images at 100%, and when I first got the K5IIs, and looked for signs of moiré, it always turned out to be color noise.
In some 3000 shots of all sorts, I've only been able to succesfully shoot real moiré in..... 1 image!
 Chris Mak's gear list:Chris Mak's gear list
Pentax K-3 Sony Alpha 7R Pentax HD DA 560mm F5.6 ED AW Carl Zeiss Distagon T* 2/28 Carl Zeiss Distagon T* 2/35 +2 more
eenymac
eenymac Senior Member • Posts: 1,021
Re: Moire...
That's what I found as well.  The only times I found it were when shooting the local Herons, where I found what I thought was moire pattern on some of the large but fine feathers, and again only when taken at about a 45 degree angle to the bird.  A bit of colour noise removal did the trick, so no moire as yet, just very detailed shots.
 eenymac's gear list:eenymac's gear list
Pentax K-5 Pentax K-3 Pentax K-3 II Pentax smc DA 35mm F2.8 Macro Limited Pentax smc DA* 300mm F4.0 ED (IF) SDM +4 more
Dale108
Dale108 Veteran Member • Posts: 6,130
Re: Moire?
klimbkat
klimbkat Senior Member • Posts: 1,905
Re: Moire...
Here are a couple . . .
Galapagos Hawk
Juvenile Boobie
I can't find any moire in the original shots.
Greyser
Re: I have a couple...
Thank you, Jeanphilippe. The 2nd shot is exactly what I was asking for. It looks fine to me.
Greyser
Re: Moire...
Thank you, guys for the quick response and samples. I may wait a month to see what is coming next (if the rumors about new Pentax announcements are true) and may buy IIs, due to proven sensor performance and no AA filter.
jeanphilippe Goube
You are wellcome, I have detected moiré on the second shot on some feather bottom right; here is the 100 % crop
And also some traces of false colors on the wing of the the tit here
Honestly if I hadn't look for it, knowing that the K5iis could cause moiré, I would not have seen it !
I think that the fine patterns of the feathers are all oriented differently, so when moiré occurs it is limited to a small area and barely detectable. For me it is a non issue.
jpgoube
Greyser
It's good to know. Thank you.
bjdavey
bjdavey Forum Member • Posts: 88
Re: Moire...
I've not found moire to be an issue:
asahi man
asahi man Contributing Member • Posts: 812
Re: Moire...
Greyser wrote:
brandrx wrote:
Hi Greyser,
Ron
The K-3? comes in Sptember,in Sommer we see the new mediumclass bodys.
Best regards
james45
james45 Regular Member • Posts: 158
Re: Moire...
Lost in the codenames, now. Do you mean the K3? FF in September...? And the one you've been calling the "apsc highclass" in Summer?! So what, if anything, is coming in April? Or has that been abandoned? Or is it announce in April, available in summer?
Confused!
