Can't open multiple raw files from Bridge CS6 ?
Started Mar 30, 2013 | Discussions
jfphoto1 Junior Member • Posts: 35
Can someone with Photoshop CS6 experience ever encountered the error message when attempting to open multiple  CS2 Raw file from Bridge CS6 file menu "open in camera raw"
"Bridges parent application is not active Bridge requires that a qualifying product has been launched at least once to enable this feature "
What is strange is that I can click on a single file and it opens directly into CS6 camera raw with no problems
I am using the most recent Camera Raw 7.4 RC
Thanks in advance
Joel
 jfphoto1's gear list:jfphoto1's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +1 more
DavePlugh Senior Member • Posts: 1,421
Re: Can't open multiple raw files from Bridge CS6 ?
No I've not seen that error message. It sounds like the error message is saying you need to run the parent application prior to running Bridge at least once. So I assume that means Photoshop.
Stupid question I know but... Have you have run your copy of Photoshop? At least once?
 DavePlugh's gear list:DavePlugh's gear list
Canon EOS 450D Canon EF-S 55-250mm f/4-5.6 IS Canon EF-S 18-55mm f/3.5-5.6 IS +1 more
jfphoto1 OP Junior Member • Posts: 35
Yes of course. As I mentioned I can open a single cs2 file from bridge by clicking on it. But if I attempt to open multiple files from the file menu open in camera raw I get that message
I hate to read like a jerk, but....
Opening up a single CS2 file in bridge and then clicking on it will bring you to Adobe Camera RAW. Not necessarily the Photoshop application. So my question remains... Have you gone to your Start menu, selected "Photoshop CS6" and run it?
Steve Bingham
Steve Bingham Forum Pro • Posts: 23,512
The standard procedure is:
1- In Bridge, Highlight all the files you want to convert (shift key)
2- At the very top of ACR, check "All".
The files will then be converted one after the other. Mine take less than 1 second each (16 bit), but I have a very fast computer. 30 raw fifes takes 20 seconds.
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D810 Nikon D5500 Nikon D7200 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF Nikkor 85mm f/1.8D +27 more
BrotoF Forum Member • Posts: 58
I have the same message even if I try to open a single RAW file using the command 'Open in Camera RAW'. I guess it's a bug with some Bridge dll file. But I do the following in Bridge: I select one (or more raw) file(s) and I doubleclick on this file (or on any one if you have many files selected). This does the job properly...
Expertpro New Member • Posts: 1
I have had the same problem, I could not open multiple raw files from Bridge CS6. The solution is simple:
- Select all files (or any files you want to select)
- Right click on any file and choose open (do not chose "open in camera raw" as you will receive the error)
and voila, problem solved
