XZ-10 ISO samples
Started Mar 29, 2013 | Discussions
jim4850
jim4850 Regular Member • Posts: 286
XZ-10 ISO samples
Since these are rare here's some test shots.
100 ISO
100 ISO crop
200
400
800
1600
3200
6400
6400
 jim4850's gear list:jim4850's gear list
Olympus SZ-16 iHS Samsung WB350F Samsung NX mini +2 more
Olympus Stylus XZ-10
jim4850
jim4850 OP Regular Member • Posts: 286
Re: XZ-10 ISO samples
Sorry I appear to have stuffed up, they lack EXIF info, usually I don't have a problem but I must have made a mess of it
tkpatric Senior Member • Posts: 1,319
Thank you. Almost too good to be truth!
 tkpatric's gear list:tkpatric's gear list
Canon PowerShot G15
Kerusker
Kerusker Contributing Member • Posts: 892
Thanks for posting your ISO comparison - very interesting.
Could you please verify that the ISO values are correct? Especially the 100 and 200 ISO?
The latter seem to be worse than higher ISOs. Did you use standard settings?
Thanks.
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Pentax K-5 II Pentax K-5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 55-300mm F4.0-5.8 ED
jim4850
I think I'll have to redo a bit fancier, I only used P mode and the aperture varied, I should do it more manually with the same aperture, but for now bedtime reckons.
I'll find something better to aim at.
jim4850
More spam
All shot at F4 in dim light to avoid overblowing ISO 6400
full size ISO 100
100
200
400
800
1600
3200
6400
full size 6400
Kerusker
Re: More spam
Jim,
thanks for your SPAM
You did choose a tough target but the ISO effect is clearly visible.
Up do ISO 800 the XZ-10 is doing very well for it's small sensor; ISO 1600 is still usable and up to 6400 it's good enough for the net.
Amazing (me thinks).
][.Kerusker
Re: More spam
Kerusker wrote:
Jim,
][.Kerusker
Thank you Jim, and it is indeed amazing!
Canon PowerShot G15
marike6 Senior Member • Posts: 5,071
I do appreciate you taking samples, but is it possible to just go outside and take a normal landscape or cityscape image.  Taking cans of food, or newspaper indoors at close range is not all that useful.
Also there is not need to do all the work to make crops, if doing so is going to strip the EXIFs.  Just make some images around the yard, in daylight, low-light, flowers, whatever.
I'm considering the XZ-10 but I honestly don't understand what all the review sites are doing as there are almost no samples on the web.  Nothing but a few sites for abroad, but DPR, PhotographyBlog, TechRadar, et al, are useless for the two most interesting high end compact released recently, the XZ-10 and P330.
So since you happen to have the XZ-10, you are in a position to change all that by putting up some full-sized images on Flickr.  They don't have to be test photos, just some images outdoors.
Thanks for your hard work, but honestly just some simple un-resized images would help most.
Much appreciated.  Regards, and happy shooting, Markus
 marike6's gear list:marike6's gear list
Nikon Coolpix P330 Panasonic Lumix DMC-GH2 Nikon D800 Fujifilm X-E1 Panasonic Lumix G 20mm F1.7 ASPH +7 more
jim4850
Still a mystery to me? I didn't strip the EXIF out, in fact it annoys me when people do that, the EXIF still shows up with them in my gallery here, but for some reason despite having the settings what I think was correct they disappeared when posted here.
This was a specific test which I think may have been requested, being only a hobbyist and not wanting to get too far ahead of myself nor in the limelight, I'll just sit back for a little while and leave a bit of room for someone else to post samples.
sean000 Veteran Member • Posts: 7,149
Actually he did these because many of us were asking for them.  I think what sets this camera apart from others in its class is the bright lens, which makes it attractive for indoor available light. The question many of us have is whether the brighter lens (f/2.7 at the long end) makes it better for this type of shooting than the Nikon P330 (which is f/5.6 at the long end). The Nikon has the larger sensor, but is the image quality at, say, ISO 1600 better than what the XZ-10 can do at 400? Unfortunately almost all sample photos I have found are at the base ISO.
I've had an easier time finding outdoor landscape/cityscape samples from the XZ-10. Personally I think any modern camera will do very well at base-ISO landscapes and cityscapes (although only a small percentage will be exceptional). It's in lower light that things get interesting, and the samples in this thread look better than I would have expected. True there is more noise and less detail than what my E-M5 can do, but given the difference in sensor sizes the gap isn't what I would have expected. Of course these are just one set of samples and I don't know how much noise reduction was applied, but when it comes to shooting photos of kids and family in available light (which is how my wife will use it) fine detail isn't super important and some noise is fine as well.
Sean
 sean000's gear list:sean000's gear list
Olympus Stylus XZ-10 Nikon D70 Nikon D200 Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 +13 more
Barr1e
Barr1e Senior Member • Posts: 1,743
Hi Jim -
Thanks for all your efforts.
I am enjoying my XZ-10 too - lots to learn with some of the sub files tucked away in various modes which help to produce some interesting pix, like this collage below.
A  pic takem in A.mode of the same church which I have reduced to 1600p on the long side for folk to see it on their screens.
Regards.   Barr1e
 Barr1e's gear list:Barr1e's gear list
Olympus Stylus 1 Olympus E-5 Olympus E-M1
PPW Forum Member • Posts: 79
Can those of you who own the camera comment on the speed & accuracy of its
autofocus, especially in low light (indoors), without the AF illuminator light?
Thank you.
- Paul
Is low-light a priority for a compact?
Personally I'm less interested in how the XZ-10 performs at ISO 3200, but I would like to know how it performs at ISO 100.  I just don't see low-light shooting as a particular strength of any small sensor compacts.
And there seems to be a real lack of normal outdoor XZ-10 images.  And the ones I have found, the infinity focus scenics, landscapes, cityscapes, etc. have not looked very impressive so I'm not sure I agree that any modern compact can produce excellent daylight images.  The bar set by the S100, P7700, G15, et al is pretty high.
And since there are really almost no normal daylight XZ-10 images on Flickr, I thought I'd ask the OP to post some, since he seems to be one of the few XZ-10 owners on this forum.
On Flickr the XZ-10 representation is a sad affair.  Note the only landscape image is shot at base ISO, but for some reason is incredibly noisy.
http://www.flickr.com/search/?q=Olympus%20XZ-10
Do you have any links?
Since most people use compacts for travel or vacation images, ideally a high-end enthusiast compact should be able to make sharp, colorful base ISO landscape / cityscape images.  Visit Flickr and you can find hundreds of excellent S110, P7700, G15, XZ-2 or MX-1 images.  The problem is the same type of images I've seen from the XZ-10 have failed to impress.  The close-up images do look good.  And some of the art filter images look good, but at infinity the lens/sensor combo is a big question mark for me (mainly because of the below samples, and some other P330-XZ-10 comparison images that show some some corner softness and fairly noticeable vignetting from the XZ-10.
Full-size XZ-10 landscape images from RAW
http://prohardver.hu/teszt/olympus_xz-10_a_kicsi_en/kepminoseg.html
Full-size XZ-10 landscape / cityscape
http://dc.watch.impress.co.jp/docs/review/newproduct/20130313_591282.html
XZ-10 Comparison with other compacts
ChrisWal Regular Member • Posts: 485
Re: Is low-light a priority for a compact?
Hi Markus,
I'm very pleased to say that my XZ-10 arrived today. The "form factor" is everything I hoped for: definitely pocket-sized and with a satisfying build quality. I only had a chance to grab a few snaps but already I think I'm happy. If I get the chance to go and get some real test shots over the next couple of days, what would you really like to see to help you with your choice? This will not be in the spirit of trying to prove a point (I'm already almost satisfied) but to help you (and possibly other enthusiasts) get closer to making a decision with this camera.
Best wishes
Chris
 ChrisWal's gear list:ChrisWal's gear list
Olympus E-1 Olympus E-300 Olympus E-620 Olympus E-5 Olympus OM-D E-M10 +13 more
ChrisWal wrote:
Hi Markus,
That's great.  Congratulations on the new XZ-10. It looks like a very nice camera.  I've seen a video on YouTube of it's AF performance, and it's most impressive.
I'd like to see some normal outdoor daylight images, scenics, architecture, landscapes, i.e., some local buildings, people milling about, anything really.  Nothing fancy, I just haven't seen many ISO 100-400 images (distant shots) from the XZ-10.
I've seen a few close ups and they look great like these XZ-10 shots for example.
The close-ups like these have been most impressive.  Sharp and colorful.
I have not seem too many more distant shots - landscaps, street images, candid, people or animal photos, etc.
Not worries, Chris, just have fun with your camera.  And thanks for thinking of us XZ-10 starved users.  Much appreciated.
jim4850
Weather too grey and lousy today to take any photos, with the right light and clear air magic can happen for anyone but with grey skies you need a magician.
Here's a nondescript photo I took a fortnight or so ago with blue sky that's not worth posting otherwise.
a bland wide angle shot.
Maybe I can add though that I'm finding the XZ-10 very useful, the results are good from anything I try and it has become a real good all rounder for the use I have for web posts, only lacking a decent zoom but all things are compromises. One of the very nice touches is the timer that doesn't reset until you want it to, I wish all camera's firmware were programmed like that.
Don't find it bland at all, Jim.  These are the kind of shots I cannot seem to find online from this camera. It's useful to see how the camera renders fine detail at infinity.
Question:  why is your image 16:9 aspect ratio? Did you crop it that way or is it an option to shoot 16:9 in the menu?
Re: the self-timer, I wish all cameras did that, as I hate having to buy a remote release and one thing that used to drive me nuts with my XZ-1 was I would use the 2-sec release to avoid any shake and it reset it after ever shot.  Whereas my Ricoh GRD III, the most photographer friendly compact I've ever used, you could just set it on 2-sec and leave it.  Good to know the XZ-10 has this feature.
Thanks a lot.  Regards, and happy shooting, Markus
jim4850
I regard 4:3 as a legacy ratio and haven't used it for years Markus, my shooting is usually 16:9 because that's what monitors are these days and also because I like it. Sometimes I shoot 1:1 because that's also useful. Yes it has 16:9 and 1:1 ratios available, as well as 3:2 which IMO is more useful than 4:3 especially if you get shots printed.
Re: Why not? Why put a fast lens on it otherwise?
Anyway, after having a look at these links, perhaps you'll understand my request to the OP.  My problem is I really like the XZ-10 form factor and bright lens and would buy it in a second if only I could find two or three sharp base ISO scenics from it. Thanks and happy shooting, Markus
Why can't low light be a priority for a camera that has an f/1.8-2.7 zoom? Oh sure maybe it will slightly blur the background a bit more than f/5.6, but at the focal lengths used for such small sensors the depth of field isn't going to be nearly as shallow as with a larger sensor camera that uses longer focal lengths to achieve the same fields of view.
Low light is a priority for my wife. Despite the fact that we have a Nikon DSLR and an Olympus OM-D E-M5 at home, along with a shelf full of f/2.8 and faster lenses, she has no interest in using a complicated camera that requires frequent lens changes. She would rather use her iPhone to take photos of our kids indoors. Even at the playground the light gets low (we live in the pacific northwest)
A few years ago I would have said there just isn't much point to buying a compact sensor camera for low-light photos, but that was because even high-end compact cameras had two big problems (three if count poor AF in low light): Horrid image quality above ISO 200 or 400 and slow lenses that would be at f/5.6 in the short tele range. Now you can get compact cameras (like the XZ-10) with bright/fast lenses that let you keep the ISO in the camera's comfort zone as the light gets lower. Combine that f/2.7 tele with very good ISO 400 IQ and you've got a camera perfectly capable of taking good available light photos indoors on a typical day in our house. If the ISO is still usable at 1600 or 3200 (by usable I mean looks good on the Web or in a 4x6 print), then it will be good for indoors at night as well. No it won't match my E-M5 at f/2.7, but it will blow an iPhone camera out of the water... as well as any two or three year old high-end compact cameras.
I use my E-M5 or my Nikon for landscapes and architecture, so I guess we are looking at the XZ-10 for very different reasons and both dismayed at the lack of reviews and sample shots
Note that I didn't say, "excellent." I said "very well." If I'm going for landscape shots to print at 13x19 or larger I'm going to stick with my larger sensor cameras and use a tripod along with my best lenses . Not that you can't get impressive results out of some of the cameras you mentioned, but aside from the S100 these are larger cameras...and the S100 has a slower lens. Olympus wouldn't put an f/1.8 to 2.7 zoom in a compact if they didn't intend for it to appeal to low-light shooters, and personally I wouldn't be surprised if they made some compromises to get the zoom that fast. Maybe the corner to corner sharpness will not be as good, or maybe there will be more fringing or CA with a faster lens. Hard to tell from samples that are likely shot as JPEG. Some of the ones I've seen were not taken in the best light either, so it's kind of like judging snapshots rather than looking at the results of people who have used the camera for a while and are presenting their best images.
It is a new camera though, so I guess we can't expect a ton of sample shots and professional reviews just yet. The most useful information, and best samples I've seen, have been from the jim4850  and others who have posted on this site.
Sean
