HELP!! Asus G75V loses sound when connected to Dell U3014
Started Mar 29, 2013 | Discussions
Gazza Wilson
Regular MemberPosts: 200
Mar 29, 2013
My Asus laptop has perfect sound when used alone, but NO sound when I connect it to my external monitor (Dell U3014). This problem occurs if I connect the monitor through HDMI or DisplayPort. I have no idea how to rectify the problem - any help would be gratefully appreciated.
Cheers, Gary.
Canon PowerShot G7
gs85739az
Contributing MemberPosts: 931
Re: HELP!! Asus G75V loses sound when connected to Dell U3014
In reply to Gazza Wilson, Mar 29, 2013
There is probably a way around within your sound setup.  Click the speaker, check the sound drivers,etc, had a similar problem hooking up a laptop to a plasma TV, there is also something within your monitor settings that might help also.
Start with: right click speaker icon[usually in lower right near clock]
left click " Playback devices" , go thru the choices there...good luck
Gazza Wilson
In reply to gs85739az, Mar 30, 2013
Thank you, sir! You are a marvel. My problem is solved - Very much appreciated.
Gary.
