Why the x100s files are lacking
Started Mar 29, 2013 | Discussions
samhain Senior Member • Posts: 1,157
I was just reading the comments in Huff's review of the x100s, and one of them stood out to me in a big way. It goes into why the x100s's files seem to be lacking that certain something. I think it's a fantastic post & very informative,  so I thought i'd share it here. Hopefully he see's this and steps in to expand on it.
Mauro B writes:
Fujifilm FinePix X100 Fujifilm X100S Fujifilm X-E1 Fujifilm X-Pro1
digby dart Veteran Member • Posts: 6,163
samhain wrote:
Not at all.
Lakeview Man Regular Member • Posts: 333
Re: Why the x100s files are lacking
Not really. Well, not informative for me anyway.
See, I love the files my X-pro1 gives me. Both in low and high ISO. So getting the same kind of  images from the X100s is something that makes me want to buy it.
It's a matter of taste then.
Ok, so it's informative after all. Now I want the x100s even more
 Lakeview Man's gear list:Lakeview Man's gear list
Fujifilm X100T Canon EOS 7D Fujifilm X-T1 Nikon D810 Canon EOS 7D Mark II +17 more
Daniel Lauring
Daniel Lauring Veteran Member • Posts: 9,033
"1600 iso = 987 iso measured
3200 iso = 1470 iso measured
I've read anywhere from half a stop to 3/4 of a stop of "cheating" by Fuji on the X-trans sensored cameras.  I would like to better understand how that magazine figured it was over a stop.  They are saying that ISO 6400 is close to 2 stops off!!!
As far as weird effects are concerned.  I saw them occasionally when I had the camera on the default settings.  Since I've switched to -2 NR and turned off auto dynamic range I haven't seen it.  What I have yet to do is selectively turn the "knobs" (NR, dynamic range, sharpness) to create and remove those watercolor effects.
Velu Contributing Member • Posts: 505
"Only time will tell" ... if you can wait a few months, user reports, comments and pictures will flood the place and last but not least ... Fuji's latest firmware at that time MIGHT have solved things IF there are issues as described ...
Meanwhile let's just hope there's imagewise nothing to fix
www.veluart.com
Keit ll Senior Member • Posts: 3,674
Isn't this just a myth , the old model is still the best ? It helps to comfort those who bought early & helps to clear out old stocks ? I don't have any Fuji X yet so all this is speculation from an outsider....
Keith C
samhain OP Senior Member • Posts: 1,157
Re: ?
samhain wrote:
Not at all.
Lol I should've known that was coming.
Well, I thought someone sharing test data that provides fuji's true iso's (which vary greatly from fuji's stated iso's), how it effects the files, providing explanations as to exactly why the photos have a certain 'look' that everyone keeps talking about, reasons why Lightroom & other processing programs have had such a hard time with the x-trans sensor files and then giving an opinion on the cameras' files and how they differ from each other having owned the x100, x-pro1 & xe-1- all in one post- well i thought it was pretty informative.
I take it you already knew all that stuff?
I haven't seen any of that info anywhere, just lots of questions & speculations.
I guess we all have different opinions as to what 'information' is. I found it pretty interesting so I thought I'd share it.
Adrian Tung Veteran Member • Posts: 3,052
I'm curious where or how they arrived at those figures.
Additionally, on an iso-less sensor (which I believe Fuji's is), it doesn't matter whether the image was taken at higher iso, or slot at lower iso and pushed digitally -- the difference is not significant.
 Adrian Tung's gear list:Adrian Tung's gear list
Nikon Coolpix A Canon EOS 10D Canon EOS 5D Mark III Sony Alpha 7R Canon EF 35mm f/2.0 +11 more
CraigArnold Contributing Member • Posts: 695
The original X100 has ISO measured at the sensor of 1000 at camera settings of 1600, 3200, 6400. So this is consistent with the engineering approach on the imaging pipeline of even their Bayer cameras.
As DXO explain, it's not "cheating" in any meaningful sense.
Surely the thing to decide is whether the images produced by the whole package of sensor, image processing chip and lens is something you like the look of?
Of course it's interesting HOW they do it, but really it comes down to whether you like the end results or not. We are blessed with plenty of options if the Fuji look is not to your taste.
I may be the world's biggest X100 fan, from day one with the earliest firmware I loved it. Unquestionably the best camera I've ever owned. Simply perfect for me. I am not at all sure I prefer the look of the X-trans, but I applaud Fuji for their willingness to experiment and their courage to innovate.
http://www.dxomark.com/index.php/Publications/DxOMark-Reviews/Fujifilm-X100-DxOMark-Review/The-ISO-Sensitivity-Graph-Explained
Blog ------------------------ http://craigspics.net/?tag=blog
X100 Blog ----------------- http://craigspics.net/?cat=6
X100 Quickstart Guide -- http://craigspics.net/?page_id=1345
 CraigArnold's gear list:CraigArnold's gear list
Fujifilm FinePix X100 Olympus Tough TG-4 Sony Alpha 7R Sony FE 35mm F2.8 Sony FE 55mm F1.8 +2 more
jonnie burtoft Contributing Member • Posts: 533
5
Thankyou for regurgitating old news.
Enjoy whichever camera you use. Don't forget to take photos.
Steve huff is a legend a photographic god I'm going to sell all of my equipment because he doesn't like it. Cheers Jon
Felts Contributing Member • Posts: 566
Re: ?
Lightroom has struggled with the x-trans algorithm, nothing else. I find it very hard to believe that at iso 6400 Fuji applies a magical tone curve that lifts the file over 2 stops, and can then still be extensively manipulated in post production. Surely any latitude would be pushed to the max for them to achieve this?
Not every thing written on the Interweb is fact, and some is quite frankly total nonsense. I think this falls into the latter category.
 Felts's gear list:Felts's gear list
Fujifilm FinePix X100 Nikon Df Nikon AF Nikkor 135mm f/2D DC Sigma 50mm F1.4 EX DG HSM Samyang 14mm F2.8 IF ED MC Aspherical +6 more
Keith C
It's not a myth, there's certainly something to it. As to the extent, it's hard to say. It varies from person to person.
Just like anything- to some it's a big deal, others not so much.
I think once adobe and other PP/raw programs get an angle on the x-trans sensor and figure out how best to extract the info from it, it'll probably smoke the older x100 sensor. But right now it's somewhat uncharted waters.
The photos from all the fuji cameras look damn good- we're really just splitting hairs. Both the x100 cameras will produce great photos and neither would be a bad purchase.
dengx Senior Member • Posts: 1,018
X100 did exactly the same
X100 did exactly the same and had max ISO=1000.
Regards
sgoldswo
sgoldswo Senior Member • Posts: 5,525
Re: ?
samhain wrote:
samhain wrote:
Not at all.
Funny, doesn't the X100 rely upon curve lifting as well to get to higher ISOs? It would have to give its the same sensor that was in my old A700
 sgoldswo's gear list:sgoldswo's gear list
Leica Q Leica M Typ 240 Nikon Df Nikon D810 Nikon D750 +1 more
I swear, there's always that guy on dpr that has to put down ken rockwell, thom hogan or Steve huff(even when no one is talking about them);  and then you have that other guy that tells people in a camera forum,(a forum specificly for camera nerds to talk about cameras) to just go take photos.
My friend, you managed to be both those guys in one post. And that is awesome
PG Thomas Contributing Member • Posts: 667
Re: X100 did exactly the same
ISO 1000... What does it matter?
Using film one bought, Say Tri-x at Iso 400, and then by processing with diferent developers and times resulted in a range of  ISO's 100 to 3200. So long as one exposed for the expected ISO you got the desired result.
Surely this is the same idea? Only now we can change the 'processing' frame by frame.
 PG Thomas's gear list:PG Thomas's gear list
Fujifilm FinePix F100fd Fujifilm X10 Pentax K20D Pentax K-5 Fujifilm X-T1 +14 more
It doesn't matter for me as long as the results are pleasing (and they are):)
Just pointing a flaw in the OP quoted logic implying that X100 was looking "less digital" because X-Trans does high isos in PP because X100 did exactly the same.
Regards
Photozopia
Photozopia Senior Member • Posts: 1,302
Re: ?
Felts wrote:
.... I find it very hard to believe that at iso 6400 Fuji applies a magical tone curve that lifts the file over 2 stops, and can then still be extensively manipulated in post production. Surely any latitude would be pushed to the max for them to achieve this?
What's so hard to believe?
All sensors have a natural base sensitivity (often ISO 100) and inherent maximum exposure 'tolerance' - usually topping out at about ISO 1000.
Images produced both up to, and over, the 'maximum' sensor limit are merely the result of electronic manipulation of that sensitivity range ... the creation of any ISO figure is an electronic process.
Higher range ISO - over natural sensitivity - has always been in the realm of individual manipulation by camera companies 'stretching the tech' as it were, to deliver extreme usable results.
Bench-testing data may not be the same as OEM in-camera results (DXO has admitted as much) and claims that Fuji 'ISO cheat' is no more correct than saying other (un-named) vendors get it right.
The only time ISO is wrong or incorrect (IMO) is when the results from any correct aperture/shutter combination results in under/over exposed images. Anything else is merely electronic engineering (or it's supporters) trying to prove a point.
Perhaps we should simply drop ISO function if it confuses ... why not low/bright light condition buttons (it worked for Kodak Instamatics etc) .... or perhaps fast/slow movement conditions .... or just Auto ISO - which we already have!
Thankyou, I do try my best
John Carson Veteran Member • Posts: 4,206
The brightening effect of higher ISO can be achieved in different ways in-camera. One way is using analogue gain. Another way is to use digital manipulation in the same way as a program like Photoshop does.
It would appear that the writer is not talking about the overall ISO but is instead talking about the portion of it that is the result of analogue gain.
john carson
 John Carson's gear list:John Carson's gear list
Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
