What should I check when buying a used Epson 3880
Started Mar 29, 2013 | Discussions
Radu Tenenbaum
Radu Tenenbaum Senior Member • Posts: 2,862
I'll be looking at a used Epson 3880 being offered locally.  Seller claims that it's only printed 300 times and that it has new inkset.
Is there a counter that I can check?  Aside from checking ink levels and asking for a nozzle check, what else should I be looking for?
Thanks!
Radu
www.raduray.com
 Radu Tenenbaum's gear list:Radu Tenenbaum's gear list
Nikon D800 Fujifilm X-E2 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Nikkor 35mm f/2D +17 more
Hugowolf Forum Pro • Posts: 12,545
Re: What should I check when buying a used Epson 3880
Yes, it is available through the console panel. Download the user manual and find out how to access it.
You might want to ask why it is being sold.
I would ask to watch a print coming off, preferably one of your images.
Brian A
irvweiner Contributing Member • Posts: 705
Write up a pre-nup agreement defining conditions for return--then get it signed!
irv
ps for 300 prints of moderate size the original carts should still be in place.
Radu Tenenbaum
Radu Tenenbaum OP Senior Member • Posts: 2,862
What was a waste of 90 minutes and two gallons of gas.
Ink was at 50-70% instead of the claimed 90% plus.  Maintenance cartridge was almost at capacity.  Ran nozzle check and there were gaps.  Ran auto nozzle check, where the printer iteratively checks output and cleans as necessary, but the Maintenance cartridge reached capacity after awhile and everything stopped.  What had printed to that point still had gaps.  Said goodbye.
Epson has a $250 rebate till the end of March, so I just ordered one from Amazon.
Radu
www.raduray.com
They will be at about 80% before you do a single print. It takes that much ink to prime the lines and align the head.
A maintenance tank is about $16.
More serious
Brian A
sjphoto Regular Member • Posts: 284
You did the right thing. Now you will have a brand new trouble free printer to enjoy for many years.
 sjphoto's gear list:sjphoto's gear list
Nikon D500
