Converting images to low res?
Started Mar 29, 2013 | Discussions
Elbert Zip Johnson
Elbert Zip Johnson Contributing Member • Posts: 834
Question:
Can  I load a bunch of images in a folder & do a quick conversion from a high res image to a lo res image(s) all in one, at one batch?
Would it be done best/quicker in Light room and/or PS?
What be the lowest res file setting to use?
I want 'em to see the image but difficult to get any good print from these images.
thanks a bunch
Zip
'EVENT PHOTOGRAPHER'
MID WEST
check me out? www.zipsphoto.photoreflect.com
Hugowolf Forum Pro • Posts: 12,545
Re: Converting images to low res?
Elbert Zip Johnson wrote:
Question:
If you have catalogued images in Lr, then you can export any you select in whatever resolution you want. Photoshop is basically a single image editor, it isn't set up for this. You can cartainly do it from PS, but it is more complex.
Brian A
Charles2 Veteran Member • Posts: 3,510
Fast Stone will batch convert your images
The donation-only viewer program Fast Stone has a batch conversion dialog. Choose by dimension, file size percentage or target size, etc.
Petruska Veteran Member • Posts: 7,549
Use Pixresizer
Question:
thanks a bunch
Zip
MID WEST
Free app, will do batch with ease and wii convert file formats.
Just search the web for it.
Bob P.
E Dinkla Contributing Member • Posts: 634
Question:
thanks a bunch
Zip
MID WEST
It can be done batch wise in PS and LR but I always go to Qimage Ultimate as it allows more choices in a transparent way and has good anti-aliasing choices with downsampling.
Met vriendelijke groet, Ernst
500+ inkjet paper white spectral plots: OBA content etc.
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
Elbert Zip Johnson
Elbert Zip Johnson OP Contributing Member • Posts: 834
OK I found it in Light room "Exporting"
thanks
Zip
MID WEST
