Expired ink for Epson 3800
Started Mar 28, 2013 | Discussions
rvc1
rvc1 Forum Member • Posts: 63
How long after the "use by" date are cartridges good for? If you could purchase a full set of inks that expired in 2008 and 2009, would you risk it? It seems like something that should be ok, but 3800 inks aren't cheap, even if discounted, so I thought I'd get some opinions.
Thanks.
 rvc1's gear list:rvc1's gear list
Canon EOS 550D Sony a6000 Canon EF 50mm f/1.8 II Canon EF-S 18-135mm f/3.5-5.6 IS Canon EF 75-300mm f/4.0-5.6 III +5 more
Howard Moftich
Howard Moftich Veteran Member • Posts: 7,697
Re: Expired ink for Epson 3800
this is one of the most popular questions asked.  You wont have a problem w/ inks 18-24 months out of date.  But you will want to gently agitate the carts.  You can do a search for prior questions and responses to this exact question.
JJ Winkel
JJ Winkel Senior Member • Posts: 1,387
I baught a few carts that expired 08/2009, still printing nicely ...
JJ.
Sal Baker
Sal Baker Veteran Member • Posts: 9,266
This seems to be a big advantage to using Epson inks.   The ink in Epson carts is enclosed in airtight bags so the ink isn't exposed to air.  Not only do the carts last well beyond the expiration date, they last forever (almost) once in the printer.  I still have a couple of carts that have been in my 3880 for over 3 years, still working perfectly.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Canon EOS 5D Mark II Fujifilm X-E2 Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +7 more
