Sigma SD1M wrong colors
Started Mar 27, 2013 | Discussions
Tom Schum
Veteran MemberPosts: 4,659Gear list
Re: Sigma SD1M wrong colors
In reply to anfat, Mar 27, 2013
Cinefeel posted something interesting a couple weeks ago and I believe the SD1 menu system allows something equivalent in-camera:
http://forums.dpreview.com/forums/post/41115168
Tom Schum
Sigma DP3 Merrill Sigma DP2 Ricoh WG-4 GPS Sigma dp0 Quattro Fujifilm X30 +8 more
Hardy Steiner
Senior MemberPosts: 2,442
Custom white balance
Your pictures look different because the white balance is not 100% the same. You might be using the same settings, but maybe they are differently interpreted by the camera/SPP.
If you aim to get the same white balance with both cameras, you should try to use an Expodisk to get a custom white balance. This should help I would assume.
Best regards,
Hardy
Join the Sigma DP Macro Group on:
http://www.flickr.com/groups/sigma_dp_macro/
My pictures on:
On Flickr: http://www.flickr.com/photos/diddy
Laurence Matson
Forum ProPosts: 11,493Gear list
anfat wrote:
if I use yousendit I have to post the links?
just send an e-mail. mine is public.
Laurence
laurence at appledore-farm dot com
"The fact of being reported multiplies the apparent extent of any deplorable development by five- to tenfold" (or any figure the reader would care to supply).
Barbara Tuchman, A Distant Mirror
http://www.pbase.com/lmatson
http://www.pbase.com/sigmadslr
http://www.howardmyerslaw.com
Laurence Matson
Re: Three color settings to check
anfat wrote:
I have tried all setting in the past days...no different result...
send the files if possible.
Laurence
Roland Karlsson
Forum ProPosts: 23,440Gear list
Re: Custom white balance
In reply to Hardy Steiner, Mar 27, 2013
The colors are too different to be able to be explained by white balance. Moreover, it seems to be mainly the red channel that is affected.
Of course its nice to use calibration. But .. the modern Merrill cameras shall behave more similar than that, without calibration.
Either something is wrong with the camera or with the usage IMHO.
So far it seems to be the camera, but we have to wait and see until some here has analysed the RAW file.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sony Cyber-shot DSC-RX100 III Sigma DP3 Merrill Sigma dp2 Quattro Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited +8 more
Kendall Helmstetter Gelner
Forum ProPosts: 19,206Gear list
A solution
I went out and shot a local fire hydrant myself with the SD-1, and DP-3m...  I was able to see the same thing, the DP-3M was red as it should be, the SD-1 hydrant was oddly orange.  Both shots used Auto white balance and neutral color mode.
The solution in my tests ended up being to use Standard, not Neutral, color mode for that image, along with setting the color adjustment dropper on something neutral (in my case a street) in the SD-1 image (I did the same thing in the DP-3M image but it had no effect).  Then the hydrant was red and the other colors matched also.  You don't have to re-shoot, just change in SPP.
I normally advocate using Neutral all the time, and in my shooting I mostly found it to be the most accurate.  I don't know what it is on the SD-1 that causes hydrant red to come out so orange in Neutral.  Perhaps over some firmware updates Standard on the SD-1 has drifted closer to being accurate than Neutral...
The hydrant in the SD-1 image was also a touch more vibrant at that point, I had to bring saturation on the SD-1 image down about -0.1 for a closer match (it was a little under then).
I also took a picture of a construction-orange / blue sign as well, and found the same thing - to have the SD-1 more closely match the DP-3M image in Neutral mode, I switched the SD-1 image to Standard color mode.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 85mm F1.4 EX DG HSM Sigma 1.4x EX DG Tele Converter Sigma 24-70mm F2.8 EX DG HSM Sigma 8-16mm F4.5-5.6 DC HSM +4 more
anfat
anfat OP
Forum MemberPosts: 75Gear list
Re: A solution
In reply to Kendall Helmstetter Gelner, Mar 27, 2013
I have tried standard and vivid, but the reds are always orange...
 anfat's gear list:anfat's gear list
Nikon Coolpix A Sony FE 55mm F1.8
yvind Strm
Veteran MemberPosts: 4,130
In reply to anfat, Mar 28, 2013
anfat wrote:
Hi, I have a new SD1M that produce colors not true: some reds are orange, some greens are light blue; I've tried to change wb and to set up a personal wb, but with no result...which could be the cause?
This seems like a similar situation to the green cast issue of the SD14. With that we saw unit variations, but a camera dependent correction value in SPP fixed the issue. I recall Guenther Borgermeister reported he had to use different corrections for his 3 (?) cameras. And saw none of the issue in an other users SD14.
With this SD1 thing, Kendall verifies that the issue is real. Tom pointed to a post by Cinefeel, with a suggested correction value: -15Y +5R. (Might not be SPP, so a value has to be found there)
SO anfat, try some correction around what Cinefeel suggest that and see if you get closer. A workaround, yes, but not a big one.
Kind regards
Øyvind
xpatUSA
Senior MemberPosts: 6,352Gear list
In reply to yvind Strm, Mar 28, 2013
That orangy red is an old friend for me - I once sold a perfectly good SD9 because of it. The same cast occasionally shows up on my SD10, no idea why. Artificial lighting did it on the SD9, even under tungsten with custom WB set. I tried SPP 2, 3, 4 and 5 . . nada. CFL's, tubes, candles, halogens, nuclear bombs, you name it, no difference until I went outside and kapow! - red reds suddenly appeared, so I do understand the frustration in the OP.
And we should not really be too surprised with the SD1M:
http://www.dpreview.com/reviews/sigmasd1/10 is that orange or what?
Yeah, I know, earlier version of SPP, I guess  . . .
Ted http://kronometric.org
SD10 table-top stuff
Panasonic Lumix DMC-LX7 Sigma SD14 Sigma SD1 Merrill Sigma SD10 Sigma 8-16mm F4.5-5.6 DC HSM +3 more
xpatUSA
A quick exposure test, SD10 reds for what it's worth . .
In reply to xpatUSA, Mar 28, 2013
I shot the card at ISO 200, bracketing from -3 to +3 in 1EV steps, here is a screen capture:
The shots above 0 were blown out and were discarded. The white balance was set from the gray patch on the card in ACR 5.4 and opened in PSE6 from which the screen capture was done. Each exposure was adjusted in ACR to make the histograms similar. The under-exposed red at the top looks quite familiar. That red has no blue in it, so something got clipped somehow. RGB equaled 195, 70, 0. Hue and Sat were 22 deg, 100%, obviously wrong.
Perhaps the OP should measure his orange-colored reds' RGB values (not with a screen picker) and deduce something from that?
Re: A solution
Odd, hopefully someone that gets the RAW files can figure out something.  Standard made the object quite red in my case.
Re: Some things to check
anfat wrote:
the same picture with the sd1m and with dp2m...that one shot with dp2m has true colors...
That really looks similar to the case I had.  If you change the color mode to "Standard" and click the white balance dropper on the black gravel, the slide should go red... you'll notice that in the image as you have it from the SD-1, the rocks are very blue compared to the more neutral DP-2M image.
SandyF
Forum ProPosts: 14,937Gear list
Re: examples of my DP2Merrill reds
In reply to Kendall Helmstetter Gelner, Mar 28, 2013
FWIW I've had no problems with reds from the DP2Merrill. Here's a train caboose that is really 'hot' red in the bright sun http://www.flickr.com/photos/sandyfleischmann/8078358553/ and in my DP2Merrill set on flickr I have many antique autos in a museum in Nashville. Really good reds on those with little editing http://www.flickr.com/photos/sandyfleischmann/sets/72157630945647842/
The only reds I have from the loaner SD1 are shots of red oriental rugs, which are fine, true tones (not online) and a couple of me in my red coat in Death Valley, taken by my husband. Coat color is exactly right looking at the RAWs (not online).
Best regards, Sandy
http://www.pbase.com/sandyfleischman (archival)
http://www.flickr.com/photos/sandyfleischmann (current)
 SandyF's gear list:SandyF's gear list
Sigma DP1 Sigma DP2 Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD14 +6 more
Hardy Steiner
In reply to Roland Karlsson, Mar 28, 2013
It would good if we had the X3F file to analyze this. There could be several reasons.
These pictures were taken at a different time of the day (the playground). First one looks more like overcast, whereas the second one seems to be more in sunlight.
Other important points to understand:
Which firmware are the cameras on?
Has the exposure been adjusted in SPP ... or fill light been used? Are all sliders on 0?
There might be really a difference, not counting it out, but without having a look at the X3F files it is difficult to say.
Best regards,
Hardy
My pictures on:
mburns
Regular MemberPosts: 251Gear list
It's simply that your SD1M is overexposing as compared to your other camera. Before anything else, get that fixed.
 mburns's gear list:mburns's gear list
Canon EOS 5D Canon EOS 30D Canon EF-S 18-55mm f/3.5-5.6 IS Canon EF 35-80mm f/4.0-5.6 III Canon EF 80-200mm f/4.5-5.6 II +58 more
Roland Karlsson
In reply to mburns, Mar 28, 2013
Thats quite likely.
The red channel might be out of gamut. The red channel (in the RAW data) might even be over exposed. Its not necessarily so. But ... if it is over exposed, then it can be seen in the RAW data.
Try to expose 1 or 2 stops less and see whats happening.
anfat
anfat OP
It happen only that the orange is darker but orange too..
Roland Karlsson
OK
Red becoming orange or pink is an old Foveon problem. It has been seen for SD14 and at least for the earlier DP cameras. And obviously some here have seen it with their SD1M cameras. Strange that they have not told it already. If its common, it might be an important information for potential buyers.
As far as I understand, you always get it. Which, of course, not is acceptable. So ... you have to do something. If you cant find any solution ... I assume you have to contact Sigma about it.
diolus
Regular MemberPosts: 439Gear list
Is that inconsistency which made me get rid of my sd15 and thought would get better before I bought another Foveon based camera but I guess I'll have to wait a little longer.
 diolus's gear list:diolus's gear list
Sigma DP2 Merrill Nikon D600 Nikon AF-S Nikkor 24-120mm f/4G ED VR +2 more
Park70
Regular MemberPosts: 189
In reply to diolus, Mar 29, 2013
Camera SD1M
Red, Orange and White in both photos taken near midday with light Cumulus clouds
Center - Weighted average metering
Camera settings: Standard, EV - 0.7, f8, 1/250 sec, 18-250 Sigma lens at 43mm
