Sigma SD1M wrong colors
Started Mar 27, 2013 | Discussions
anfat
anfat Forum Member • Posts: 75
Hi, I have a new SD1M that produce colors not true: some reds are orange, some greens are light blue; I've tried to change wb and to set up a personal wb, but with no result...which could be the cause?
 anfat's gear list:anfat's gear list
Nikon Coolpix A Sony FE 55mm F1.8
Sigma SD1
Hornbrille
Hornbrille Regular Member • Posts: 307
Re: Sigma SD1M wrong colors
Sounds like Foveon blue color mode. Post the picture for better answers.
Uwe 8-)
 Hornbrille's gear list:Hornbrille's gear list
Sigma dp2 Quattro
Kendall Helmstetter Gelner
Kendall Helmstetter Gelner MOD Forum Pro • Posts: 19,346
Some things to check
Can you post an example?
Some things to look at:
1) Have you tried bringing down exposure in SPP - the reds going to orange can be a result of over-exposure.
2) What color mode are you shooting in? Neutral yields I think the closest to real colors.  Also if reds still seem a bit orange, try +0.2-+0.3 saturation in SPP (processing a Neutral color mode image).
3) Do you have the SPP working space set to sRGB?  Display colors seem odd otherwise.  It doesn't mean you cannot still save in AdobeRGB or ProPhoto, it only affects review.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
anfat
anfat OP Forum Member • Posts: 75
Re: Some things to check
color mode is neutral, color space srgb...
ArvoJ
ArvoJ Senior Member • Posts: 1,277
Sample X3F file would be really helpful.
Arvo
Sigma/Foveon information collection and little galleries:
http://www.stv.ee/~donq/sigma.htm
http://www.stv.ee/~donq/images.htm
 ArvoJ's gear list:ArvoJ's gear list
Sigma SD14 Sigma 10-20mm F4-5.6 EX DC HSM Sigma 105mm F2.8 EX DG Macro +1 more
anfat
the same picture with the sd1m and with dp2m...that one shot with dp2m has true colors...
Roland Karlsson
Roland Karlsson Forum Pro • Posts: 24,124
Re: Something is wrong
Woa!!!
Yeah, something is wrong here.
I cant help you, but I sure hope someone else can.
Maybe publishing the X3F file might be a good idea.
EDIT:
Just one thought. Are you sure about the DP image being right?
The top of the chair, and also other red parts look somewhat too much pink too me. Maybe they are, just look little curious.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited +8 more
anfat
same two cameras and same setting: neutral, auto wb...
Roland Karlsson
Hmmmm ... neither look correct to me.  The SD image is too orange, but the DP image feels too pink to me. Should it not be redder?
Laurence Matson
Laurence Matson Forum Pro • Posts: 11,586
Could you please send the raw files. You can use Yousendit if you do not have a server or use something like Dropbox. One per message with Yousendit.
Laurence
laurence at appledore-farm dot com
"The fact of being reported multiplies the apparent extent of any deplorable development by five- to tenfold" (or any figure the reader would care to supply).
Barbara Tuchman, A Distant Mirror
http://www.pbase.com/lmatson
http://www.pbase.com/sigmadslr
http://www.howardmyerslaw.com
anfat
Arvo
Is it possible to charge a so large file?
Laurence Matson
Three color settings to check
There are three basic color settings to check in order for us to figure out what is going on.
- On the back of each camera, click the QS button twice. At the top right it should show QS2. The top box is for the white balance setting. Set this to the same value on both cameras (anything will do for comparisons).
- On the bottom of the same QS2 menu window is the color mode. This is somewhat less important for the moment, but still make sure both are at your chosen Neutral setting.
- Then in SPP, make sure you still have those settings in the respective windows in the tool set (White Balance Setting and Color Mode). And when you export the file, make sure you use your chosen sRGB each time.
Laurence
Laurence Matson
anfat wrote:
Arvo
Try this:
https://www.yousendit.com/
Laurence
anfat
Re: Three color settings to check
yes, neutral, auto wb, srgb for all the four pictures...
Laurence Matson
Just for a test, set WB to overcast or something not Auto.
Also, make sure you get the metering right.
Laurence
anfat
I have tried all setting in the past days...no different result...
Tom Schum
Tom Schum Veteran Member • Posts: 4,983
I've noticed it on my SD1 also.
Reds go orange on a regular basis, especially under tungsten light.
Tom Schum
Sigma DP2 Sigma DP3 Merrill Ricoh WG-4 GPS Fujifilm X30 Sigma dp0 Quattro +8 more
anfat
if I use yousendit I have to post the links?
Davethepom
Davethepom Regular Member • Posts: 379
Me too Tom...
... but usually it's in cases where there is a strong spot-light or un-natural light on the red surface and it's usually over exposed as a result. A classic scenario would be a car show, with RED Ferrari. Usually it's also when the finish is highly polished, so there may be a reflection / reflective issue there too. I'm at work at the moment so I don't have examples.
Pom
anfat
other color...
