Canon 7d pictures flat?
Started Mar 27, 2013 | Discussions
rekomaged1 Regular Member • Posts: 132
What do you guys think?
I feel like it doesn't have the pop
Canon EOS 7D
rekomaged1 OP Regular Member • Posts: 132
Re: Canon 7d pictures flat?
By the way the first picture for some reason came out 90 degrees off.
BAK Forum Pro • Posts: 20,705
The first shot is so badly exposed that it is hopeless.
The second shot "snaps up" nicely with thirty seconds of levels adjustment.
BAK
(unknown member) Senior Member • Posts: 2,853
If maintaining highlight detail in the flower itself is the point I don't think it is a horrible exposure, although I don't really get the settings used.  Drop the ISO and shutter speed?
"Snap", "pop", or even "crackle" are a matter of internal settings OR good editing.  If these two were shot in the RAW the first one should be pretty easily adjusted within reason and the second one will pop like a firecracker if you want it to.
BAK
 howardroark's gear list:howardroark's gear list
Canon PowerShot G1 X
JTuuti Forum Member • Posts: 62
I think the white balance is way off...  That is usually the first thing to check when the photos seem flat.
Here's a two quick twek:
I dont see how it is so under exposed? I was trying to get the shot with the pure sunlight hitting right on it. Maybe its my techniques that is wrong?
(unknown member) Senior Member • Posts: 4,085
Wow!
Thanks for posting, have a great day.
John
 j2l3m7's gear list:j2l3m7's gear list
Canon EOS 70D Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon PowerShot SX60 HS Canon EF 85mm f/1.8 USM +10 more
epozar Regular Member • Posts: 250
Maybe you shot using Adobe RGB ........... ?
regards,
Emil Pozar, http://emil-pozar.photoshelter.com/
Atoche
Atoche Contributing Member • Posts: 669
IMHO: "pop" requires a combination of sharp subject and background separation (well for me anyway).  The flower is not really sharp, and the lighting is a bit harsh:
Starting with your .jpg, import to LR4 - export again to jpg
Lens correction
luminance noise reduction
sharpness increase
sharpness radius increase
sharpness UN-mask increase
increase clarity
increase saturation
increase luminance
increase contrast
white balance adjustment
"I may be a geek, but it pays for the car...!"
 Atoche's gear list:Atoche's gear list
Pentax Optio WG-2 GPS Canon EOS 7D Sony Alpha NEX-3N Canon EOS 6D Canon EF 17-40mm f/4.0L USM +7 more
Sovern Contributing Member • Posts: 907
Also shooting at a higher iso than needed (you can get away with iso 100 in these shots) is going to kill off some of your dynamic range (each bit helps) which will also make your photos appear more flat.
I'd lower their exposure a small amount in LR, add some contrast and possibly raise the black levels a long with clarity levels a notch to make them pop.
Thanks, and no my pictures are in sRGB.
Atoche
Subject matter helps too - yellow "pops" from the green - naturally, then when u apply some of the techniques above...
Matt Senior Member • Posts: 2,387
enough pop?
it is a little under exposed.  If you shoot RAW you can salvage lots of those things.  Another question is why you use ISO250 and 1/1000?  You can go down on both ISO and shutter speed and have enough light to expose it more.
Other than that, images dont pop because of flat light during the shot and not enough saturation.  But not every image has to pop like a piece of neon plastic.
pic 1: Due to the subject/colors, there isnt much that could pop ... still if you increase sat and contrast it will pop a bit more
pic 2: there is enough color in there and I dont think it needs to "pop" more. still, if you want then increase cont and sat.
Other things to consider are: are you shooting JPG with a neutral color profile (or whatever its called), saturation and contrast turned down? Are you shooting Adobe RGB and displaying sRGB?
For the pic to be rotated, some software you are not using is not reading your location sensor data or the sensor isnt working
I dont see anything really wrong with those pics, except #1 a bit underexposed and you are using settings that are not ideal
Canon EOS 400D
Sigma 24-70 HF
Canon 50 f1.8
Atoche
thank you for posting this, it has helped me - I hope it helps the OP as well...
(unknown member) Senior Member • Posts: 5,590
You could try printing them on a mug or a ball.  Or anything curved really.
Don Richardson Senior Member • Posts: 1,454
I didn't read where anyone said "Out of Focus". That's the first thing I saw. Try MF and see if that helps. If it does adjust the lens to correct focus and see if that helps.
 Don Richardson's gear list:Don Richardson's gear list
Canon EOS 7D Tamron SP 150-600mm F/5-6.3 Di VC USD Epson Artisan 835 +1 more
PhilPreston3072 Senior Member • Posts: 2,290
The first shot looks fine to me.  Perhaps you're not seeing the pop because you've only got the dark side of the flower in focus.  If you've shot raw, you can increase the brightness/exposure with editing software and see if that helps.
The second shot is suffering from too shallow DOF.  If you look closely you'll find hardly any of the flower buds are in focus.  Try closing the aperture to F8 or F16 and see if that helps.  Also you've got a very busy background behind your subject which distracts the eyes.  Try to find an angle where background isn't so busy and that way your subject will pop out a lot more.
 PhilPreston3072's gear list:PhilPreston3072's gear list
Canon EOS 450D Canon EF-S 18-200mm f/3.5-5.6 IS +1 more
