D7100 - OK, here's my first RAW-shot image (done totally by accident)
Started Mar 27, 2013 | Discussions
RudyPohl
Senior MemberPosts: 3,585
Mar 27, 2013
I went out today testing my new camera and didn't realize that I accidentally changed my settings from Fine JPEG to RAW only. Thanks to a member here I was put on to Nikon's View NX2 and was able to convert my files to JPEG's. Here's my first one.
Rudy
Nikon D7100
Andrazh
New MemberPosts: 8
Re: D7100 - OK, here's my first RAW-shot image (done totally by accident)
In reply to RudyPohl, Mar 27, 2013
Which lens did you use?
RudyPohl
In reply to Andrazh, Mar 27, 2013
The lens was the Nikon 70-300mm G VR which I fine tuned to the camera.
Rudy
nfpotter
Veteran MemberPosts: 4,080
Rudy
Did you use PROPER testing procedures before you fine-tuned it?
Fine tune is NOT a toy, and should not be used unless REALLY necessary.
poidog73
New MemberPosts: 17
In reply to nfpotter, Mar 27, 2013
Nice shot!
RudyPohl
nfpotter wrote:
Rudy
I might not have used the correct terminology... I used the AF Fine Tune feature in the Setup Menu.... used a simple technique... shoot, adjust, observe... shoot, adjust, observe... found best focus at -4 for this lens.
Rudy
RudyPohl
nfpotter wrote:
Rudy
Upon re-reading my post, I realized that I had in fact described that incorrectly. I did not fine-tune the lens to the camera, but rather I fine-tuned the camera to the lens using AF Fine Tune feature.
Rudy
Whalligeo
Regular MemberPosts: 245
I have to say, that is one of the best natural looking shots I've seen on here. I suggest your workflow should extend to: Print>Frame>Hang-on-wall. Can I nick it for my desktop?
They said it couldn't be done, so I encouraged my peers not to bother.
nfpotter
RudyPohl wrote:
nfpotter wrote:
Rudy
Rudy
That's EXACTLY what I'm talking about.  That is NOT the correct way to use AF Fine Tune (IF it's even needed, which most of the time it is not).
You need to do CONTROLLED TESTS, not just random shooting.  Too many variables, your way.  Ask Mako (or others here) for proper procedure, I don't have time to write it out, or search for it.
nfpotter
RudyPohl wrote:
nfpotter wrote:
Rudy
Rudy
You did it wrong.  See my post above.
RudyPohl
In reply to Whalligeo, Mar 27, 2013
Hi Whalligeo:
Thanks so much for your very kind words! I'm brand new to DSLR wildlife photography so your encouragement is much appreciated.
And yes, if you would like to use this image for your desktop, please help yourself.
Rudy
nfpotter
You're kidding, right?
the Mtn Man
Regular MemberPosts: 144
So out of curiosity, why don't you shoot RAW?  Everything I've read leads me to believe that it's largely superior to JPEG and gives you a wider latitude for post-processing.
Retzius
Contributing MemberPosts: 591Gear list
Thats a nice image.
Have fun with your D7100.
Its refreshing to see images of real things and not brick walls, resolution charts, and focus testing lines.
 Retzius's gear list:Retzius's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +1 more
thomas2279f
Senior MemberPosts: 2,626Gear list
Nice image.
 thomas2279f's gear list:thomas2279f's gear list
Sony RX100 Panasonic Lumix DMC-FZ1000 Nikon D800 Canon EOS 70D A3000 +49 more
rhlpetrus
Forum ProPosts: 24,088Gear list
Once you start,
it's hard to go back.
I still recall my excitement when I bought the D80 in mid 2007 and downloaded the CNX trial version that came with it.
Once I started paying with u-point tools I never went back to jpeg shooting. Later I learned about WB control, then HLs and LLs recovery tools became available and RAW became even more relevant.
If you test recovering shadows or HLs with jpegs and raws you will see the difference. WB, of course, is the single most important reason to shoot RAW.
Good luck! (But View NX is just a converter, no actual PPing capabilities like CNX2 or other PP softs).
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
RudyPohl
In reply to the Mtn Man, Mar 27, 2013
Hi Mtn Man:
Actually, I always do shoot and post process in RAW, never JPEG.
I'm brand new to Nikon and I didn't know that there was already free software support for the NEF files that my new D7100 produces. I do all my processing in Photoshop CS5 and Adobe Camera Raw and my software does not support NEF files.
Now that I have Nikon's View NX2, and seeing that it does such a great job, I'll be shooting all RAW from now on.
Rudy
RudyPohl
Re: Once you start,
In reply to rhlpetrus, Mar 27, 2013
Renato.
OnExposure member
(after Ed Murrow)
Hi Renato:
Yes, I am aware that View NX2 is just a converter, but it'll do just fie until Adobe's DNG Converter supports the NEF files from the D7100.
By the way, I find the RAW files from the D7100 are just fabulous. I applied ZERO sharpening, zero noise reduction, zero brightness, contrast etc, on this image, all I did was lighten the blacks on the head a little to bring out shadow detail and that's it.
Rudy
Whalligeo
why?
RudyPohl
Whalligeo wrote:
why?
Why what?
