HS50EXR and F900EXR reviews ...
Started Mar 27, 2013 | Discussions
Kim Letkeman
Forum ProPosts: 33,332Gear list
Re: part 6 -- how about that reach?
In reply to nobbyball, Mar 30, 2013
nobbyball wrote:
From the birder/photographer perspective - you are right about the great reach to get that sort of detail from that distance. Wow. Even more impressive is that the bird is a Merlin which is the smallest of the falcons/hawks you'd get in your area (not much bigger than American Robin).
I am now slightly annoyed at you as I'd given up on the HS50 as not being special enough over the HS30 I have. This however...
Yes, I apologize for finding its weaknesses before its strengths
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F200EXR Fujifilm FinePix F770EXR Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GF3 +16 more
Kim Letkeman
Re: part 7 -- the raw hack
In reply to AdamT, Mar 30, 2013
AdamT wrote:
I used to hack RAWs with a HEX Editor , I`d have thought swapping the 5 in HS50EXR to a 2 or 3 would have worked
Duh ... you are correct
But the issue would have remained the same. Truly different sensor means Adobe's internal transformations simply don't work.
I'm hoping Obiwan Adobe will come through in time ...
Kim Letkeman
Re: part 8 -- astro (starry fields and looking forward to Comet ISON)
In reply to alexisgreat, Mar 30, 2013
alexisgreat wrote:
Kim, both the moon and Saturn looking breathtaking! This lens really is sharp and it looks like it even shows detail on Saturn at ISO 3200!
And do remember that Saturn was perhaps 10 degrees above and to the right of a 3/4 moon last night, so it's not like conditions for my brand of "pulling the shots out of my astrophotography" were ideal ...
I hope it will surprise with its long exposure (starry field) performance too.
Still a half inch sensor .... but yes, it might be ok for slightly long exposures at base ISO.
The skies remain crystal clear right now, but there are many hours again until sunset, so there is no telling what we will see later.
I want to use it on that Great Comet we have coming in November (it's supposed to be the brightest comet in over 100 years, brighter than the  full moon and even visible by daylight!) Its tail is going to pass through both Saturn and Mars- what wonderful photo ops!
Yeah, it would sure be fun on a cheap alt-az mount like a Cube ...
During August 2013, it should become bright enough to be visible through small telescopes or binoculars, becoming visible to the naked eye by late October or early November and remaining so until mid-January 2014.[7][12]
Interesting to shoot it slightly wide field during the Perseids ...
In a recent study, 1,897 observations were used to create a secular light curve. The resulting plot shows the comet increasing its brightness relatively quickly at R+4.35 [Unit?].[18] If this continues up to perihelion, the comet could reach magnitude −17, brighter than the full moon.
Now that has some serious fun potential ...
AdamT
Forum ProPosts: 58,213Gear list
In reply to Kim Letkeman, Mar 30, 2013
I`m sure they`ll come through - but in time ?- hope so .. I`m amazed that as it`s a truly different sensor, that it seems to perform the same as its predecessors (or looks like no real improvement anyway)
Canon PowerShot G1 X Nikon Coolpix P330 Panasonic Lumix DMC-GM5
Me Tarzan
Senior MemberPosts: 1,392Gear list
Re: part 8 -- astro
Ssheesh. Crackin good work, Kim.
Say Cheese!
Frank
Kim Letkeman
part 9 -- daylight indoor LvsM ISO ladder using GOOD settings
This is such a tiresome debate, but it makes sense to go through this again using what I have learned so far with the HS50's JPEG engine ...
So here you are ...
http://kimletkeman.blogspot.ca/2013/03/hs50exr-and-f900exr-review-part-9.html
Note that M wins easily, as is always the case in a thorough and fair test
wymjym
Veteran MemberPosts: 5,465
Re: part 9 -- daylight indoor LvsM ISO ladder using GOOD settings
So here you are ...
the debate will continue (for me at least).....I generally save my XS1 files @ 1800 x ????, regardless if shot M or L size. I have seen evidence that L size can be sharper and more defined in certain situations but then just when I thought I had found the holy grail I'd find another shot (similar scene/lighting) and the M size was clearly better.
I believe that the fuji processing is the reason for my confusing observations.
I appreciate all of your time and effort.
If you applied the pksharpening to the L size in your last test....would that change the apparent advantage the upsized M is showing?
wj
nikonfujicanonandricoh
Gingertwist
Junior MemberPosts: 38Gear list
In reply to wymjym, Mar 30, 2013
Hi,
Any chance of doing more of a review of the F900? Would be very much appreciated.
Thanks,
jcmarfilph
Veteran MemberPosts: 7,592Gear list
So here you are ...
> Kim Letkeman whined:
A note on the whole L versus M debate. Don’t be fooled by the forceful opinions you see where L “crushes” M and blurry images are posted to prove it. These images are invariably poorly shot, with no attempt to sharpen up the M size image after upsizing (showing a profound lack of skills and understanding of what interpolation does to an image) and with little attention to surfaces, dark subject, and very fine details.
> Blurry buildings do not an argument make, except on the Internet. So please just examine these closely. I shoot M size exclusively, and nothing I have seen from the HS50 has changed my mind, except perhaps when shooting with factory settings. Then maybe it does not matter because I think there is a bug in the firmware. But if you drop noise reduction to –2, and shoot every else at 0, then M mode seems to shoot very nicely.
Lol. 1/900s shot of a building blurry? I wasted time looking at your samples but it clearly showed L size has more details on the note and sharper too? Again who will believe in your lousy comparison? You cannot magically produce a detail that is not there.
Just for goodness sake, stop with your delusional claim. You've ridiculed yourself once again. LSize is sharper and has more detail than upsized M size.
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
KJaay
Senior MemberPosts: 4,802Gear list
Re: part 8 -- astro
wow on your moon shots!!
KJ
 KJaay's gear list:KJaay's gear list
Canon PowerShot S3 IS Fujifilm X-S1 Nikon Coolpix P600 Nikon Coolpix P900 Canon EOS 450D
Kim Letkeman
In reply to wymjym, Mar 31, 2013
wymjym wrote:
So here you are ...
No ... the noise in the L shots (it's always there, sometimes just under the threshold of visibility) that is responsible for the issues with surfaces and edges sharpens really poorly.
For simple subjects with a lot of contrast (bringing noise floor far down) you can probably do ok with L size ... but the advantages -- when they exist -- are minor. The disadvantages pile up in a hurry and I personally see nowhere near an appropriate risk / benefit ratio there ...
Kim Letkeman
In reply to Gingertwist, Mar 31, 2013
Gingertwist wrote:
Hi,
Yeah ... I've pretty much settled on nice settings for the HS50, so I can get back to the F900 Now
I had to take the detour because the HS was looking like a dog at first. Of course, it is nothing of the sort.
Kim Letkeman
In reply to jcmarfilph, Mar 31, 2013
jcmarfilph wrote:
So here you are ...
And Joms posted the same old dregs of an argument that Kim did not even bother to read.
Tim39
Senior MemberPosts: 2,884
In reply to Kim Letkeman, Mar 31, 2013
So here you are ...
Great work you're doing, Kim: a real service to the forum.
No quarrel from me on M vs. L, but things sure head south in a hurry after ISO 800 -- both sizes.
Tim
alexisgreat
Veteran MemberPosts: 5,659Gear list
Sure is- most of those other recent bright comets were much more easily seen in the southern hemisphere- there is speculation that this is a piece of the Great Comet of 1680- which was spectacular in the Northern Hemisphere.  It will reach maximum brightness on Thanksgiving Day!
http://www.space.com/17762-newfound-comet-dazzling-2013-display-c2012s1.html
The most exciting aspect of this new comet concerns its preliminary orbit, which bears a striking resemblance to that of the “Great Comet of 1680.” That comet put on a dazzling show; it was glimpsed in daylight and later, as it moved away from the sun, it threw off a brilliantly long tail that stretched up from the western twilight sky after sunset like a narrow searchlight beam for some 70 degrees of arc. (A person's clenched fist, held at arm’s length, covers roughly 10 degrees of sky.)
The fact that the orbits are so similar seems to suggest Comet ISON and the Great Comet of 1680 could related or perhaps even the same object.
Comet ISON will be barely visible to the unaided eye when it is in the predawn night sky, positioned against the stars of Leo in October 2013.
On Oct. 16 it will be passing very near both Mars and the bright star Regulus — both can be used as benchmarks to sighting the comet. In November, it could be as bright as third-magnitude when it passes very close to the bright first-magnitude star Spica in Virgo.
The few days surrounding the comet’s closest approach to the sun on Nov. 28, 2013, are likely to be most interesting. It will whirl rapidly around the sun in a hairpin-like curve and perhaps becomes a dazzlingly bright (negative-magnitude) object.
The comet will then whirl north after perihelion and become visible during December both in the evening sky after sunset and in the morning sky before sunrise. Just how bright it will be and how long the tail may get during this time frame is anybody’s guess, but there is hope that it could evolve into a memorable celestial showpiece.
http://Alex_the_GREAT.photoshop.com
 alexisgreat's gear list:alexisgreat's gear list
Olympus C-7070 Wide Zoom Fujifilm FinePix HS20 EXR Fujifilm FinePix HS50 EXR Olympus E-520 Olympus PEN E-PL6 +3 more
alexisgreat
Kim, about the separation of rings from Saturn test- I think you or someone else did the same with the HS10 awhile back + SONY TC, was that you or do you remember when they were posted here? I remember whomever that person was also talked about the benefits of stacking images, and he did a 5 image stack if I remember correctly.
Nando Kenobi
New MemberPosts: 21
In reply to alexisgreat, Mar 31, 2013
Pretty exciting
Nando Kenobi
New MemberPosts: 21
Re: HS50EXR and F900EXR reviews ...
A new set of videos:
1. http://www.youtube.com/watch?v=45qXiLGALhc (A short review, I don't understand the language but they show some nice pictures)
2. http://www.youtube.com/watch?v=_OSkiF6TVrk (pic/movie test)
3. http://www.youtube.com/watch?v=wAzUDhpcXyE (Some ISO test)
4. http://www.youtube.com/watch?v=0piiqth8jhU (showing the camera itself)
5. http://www.youtube.com/watch?v=Z8H-T9qN2Kk (Highspeed video)
english:
1. http://www.youtube.com/watch?v=qld5KR3JDZQ (unboxing + first look)
2. http://www.youtube.com/watch?v=FIqzgv7WHGI (Sample HD Video)
Regards
Kim Letkeman
part 10 -- HS50 and F900 default settings comparison
In reply to Kim Letkeman, Apr 1, 2013
http://kimletkeman.blogspot.ca/2013/03/hs50exr-and-f900exr-review-part-10.html
They both look great. Very little difference ...
I also updated the "How to Shoot an EXR Camera" article quite extensively for those who have not had a look in a while ... this is the first stage of the modernization to the HS50 and F900 ...
Nothing Special: How to Shoot an EXR Camera
alexisgreat
Re: part 10 -- HS50 and F900 default settings comparison
will also love to see the NR -2 HS50 vs F900/F770 comparison at higher ISO when you have a chance.  Thanks Kim!
I take it you wont be doing the long exposure starry field test though?  30 sec at ISO 100 is still the limit for the HS series I think.
