Compact Field Monitor For D800
Started Mar 27, 2013 | Discussions
jhinkey
Senior MemberPosts: 2,758Gear list
Mar 27, 2013
Often times I find myself struggling to use live view on my D800 while trying to obtain critical focusing for landscape shots on a tripod either due to the sun on the rear LCD or the position of the camera.
Does anyone have any suggestions for a compact field monitor solution that will allow me to view the what's being shown via live view with enough resolution, etc. to make critical focusing adjustments?
Corded via the USB out or HDMI out is fine and it can either be a dedicated field monitor or an Android-based tablet/phone device.  If an Android device which app?
Thanks -
John
 jhinkey's gear list:jhinkey's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-LX7 Nikon D800 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GH3 +20 more
Nikon D800
mnodonnell
Contributing MemberPosts: 639
Re: Compact Field Monitor For D800
In reply to jhinkey, Mar 27, 2013
You can try something like the or (pricier) Zacuto Z-Finder.
www.michaelneilodonnell.com
jhinkey
jhinkey OP
In reply to mnodonnell, Mar 27, 2013
That only helps when the sun is in the frame, but not when the camera is at a strange angle/elevation, hence I have not considered solutions such as the Z-finder.
Thanks - John
rubank
Contributing MemberPosts: 805Gear list
Here´s your answer
http://forums.dpreview.com/forums/post/50992027
It works just as well with a tablet as long as there is USB host support.
rgolub
Senior MemberPosts: 2,061Gear list
I have a Marshall 5" monitor (around $250, I believe) that I don't particularly recommend - cheap Chinese third tier construction, seems to work on a random basis.  Color is fair. With batteries and cable it weighs in at 1100 gm - quite a bit to carry around.  I do use it for video as it's much better than the camera LCD.
There are pricier and better functioning monitors - some with focus peaking which could be helpful for video.  The newer Atmos Ninja does raw video recording as well as acting as a monitor.   It's expensive but probably worth it if you do video.
I've gravitated to the Cam Ranger- a small Wifi hotspot that connects to the camera via USB and has a iPhone app to control it.  My current set up includes the CamRanger and a mini iPad - total weight 360 gms with cables and covers.  Allows you to view the camera from up to 50 - 60 feet reliably.
The main downside is that you need to come up with some sort of mount on the tripod so you can look at the image while framing.  Trying to move a ball head and camera while simultaneously  holding an iPad is a hassle.  You also get for almost free a general purpose computer to run maps, DOF calculators, sunrise calculators and the like.
No, I'm not paid by CamRanger (this is my 4th or 5th post suggesting them), it's just a nice system.  Decent support (you email the developer).
RG
www.lostrange.com
 rgolub's gear list:rgolub's gear list
Nikon D700 Nikon D4 Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF +12 more
jhinkey
jhinkey OP
Re: Here´s your answer
In reply to rubank, Mar 27, 2013
Thanks - I suspect my Android phone will have too small of a screen, but a 7" or so Android tablet might just do the job.
I'm concerned about being able to critically focus using a tablet that has lower screen resolution than the D800 LCD - but now that I see that the resolution of the D800 LCD is VGA, this should not be a problem if I get a small tablet that has 1024x600 pixel resolution (e.g., the Samsung Galaxy Tab 2 7.0
jhinkey
jhinkey OP
In reply to rgolub, Mar 27, 2013
RG
www.lostrange.com
Too bad the Cam Ranger only works with iOS.
rgolub
I believe they are working on an Android app.  For those poor unfortunates on the 'other' platform, there is Helicon Focus which is a USB tethered solution and I believe a couple of others.
I actually was going to get a small Nexus and play with those and then an iPad mini dropped from the sky...
RG
www.lostrange.com
Just a Photographer
Senior MemberPosts: 1,368Gear list
I have choosen to go by an iPad mini and a camranger (look for camranger.com)
Meaby it suits you as well.
 Just a Photographer's gear list:Just a Photographer's gear list
Nikon D4 Nikon D800E Fujifilm X-T1 Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +9 more
Billstek
Regular MemberPosts: 495Gear list
I have a Sony CLM-V55 monitor which connects to my d800 with an hdmi cable. It works well, but being a gearhead I am thinking about the Camranger since I have an Ipad.
I'd be willing to sell the Sony (with battery and charger) if you're interested.
Let me know.
 Billstek's gear list:Billstek's gear list
Nikon 1 V1 Nikon D5300 Nikon D810 Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR +10 more
Robin Casady
Forum ProPosts: 12,898
Does Helicon Remote work with CamRanger?
In reply to Just a Photographer, Mar 27, 2013
Are you limited to the CamRanger app on the iPad, or will it work with Helicon Remote and other apps?
Robin Casady
http://www.robincasady.com/Photo/index.html
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts."
— Bertrand Russell
digital ed
Veteran MemberPosts: 3,418Gear list
Thanks -
John
I use my Surface Pro 128. USB 3.0 connection to the camera. Excellent resolution (much better than D800 live view). I have loaded ControlMyNikon, PSCS6, LR4, DXO Optics Pro 8, Helicon Focus/Remote, Focal and many more PC programs. This morning I used it to check the calibration of some of my lens in a location that was not near my primary desktop. I have set it up so it boots and looks just like my desktop Win7 Ultimate. For all intents and purposes it is a small and fast 64 bit computer.
I also have an Android Zoom tablet which will also control the D800. Can process photographs using Adobe PS Touch. The Zoom is just not flexible enough and with the Surface Pro I have not found a PC program it will not run.
 digital ed's gear list:digital ed's gear list
Olympus E-1 Olympus E-3 Nikon 1 V2 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED +15 more
rubank
I have (access to) a Samsung 8.9 which has a resolution of 1280x768, it works very well.
Just a Photographer
Re: Does Helicon Remote work with CamRanger?
In reply to Robin Casady, Mar 27, 2013
Robin Casady
— Bertrand Russell
I can't tell you as I am not a Helicon user.
I use this setup for interior photography, portrait shoots and general landscape shoots and like the fact that its a wireless solution. For now there is a iOS and a Mac OSX (beta) version of the camranger software only. But I believe they are also working on an Android and PC version.
The app itself its very easy to use and it works very well to control your camera in every aspect. Checking critical focus is easy as you only have to pinch to see if you've got the focus right.
Haven't yet tried any other app to see if that would work too with the camranger as I have only been using it for one week now.
Another nice feature is that your customers can easily view the pictures you've taken and you don't have to worry that they fire the camera. For so far I am happy with what it can do.
jhinkey
jhinkey OP
In reply to jhinkey, Mar 28, 2013
Well, I ended up grabbing a Samsung Galaxy Tab 7.7 and when I get it I'll install Helicon on it (assuming it has ICS installed, which it should).  I figured that the 7.7" is a good size to carry in the field - not too big/heavy, but large enough that the live view image will be much nicer than on the rear LCD.
Just need to get the right cables and I'm all set.
I'll let you guys know how well it's working after I get it all set up.
John
jhinkey
jhinkey OP
In reply to jhinkey, Apr 3, 2013
My Galaxy Tab 7.7 just came - gorgeous screen BTW - and fortunately it came with ICS already installed.  Very very nice version of Android.  I'll load Helicon Remote on it this weekend and give it a go.
John
jhinkey
jhinkey OP
In reply to jhinkey, Apr 4, 2013
Just an update for those who care -
My Galaxy Tab 7.7 with Helicon Remote works beautifully with my D800.  I bought an USB OTG adapter for the Galaxy Tab and used the USB cable that came with the D800.
After playing around with Helicon Remote for 15 minutes or so it looks like it will be a very useful tool to have for tripod work.
I'll try to report back after some real field experience.
John
tsitalon1
Contributing MemberPosts: 611Gear list
Great!
My otg cable should be here soon, plan to use my nexus 7.
Also bought a hard back cover and will look at ways to Mount the tablet to the hot shoe.
