D7100 gets DXO'd
Started Mar 27, 2013 | Discussions
Tony Rogers
Contributing MemberPosts: 634Gear list
D7100 gets DXO'd
Mar 27, 2013
 Tony Rogers's gear list:Tony Rogers's gear list
Olympus E-M1
Nikon D7100
wlad
Senior MemberPosts: 1,486
summary:
In reply to Tony Rogers, Mar 27, 2013
D7100 is a D7000 with upgraded AF. Not much more.
bryand7k
Contributing MemberPosts: 608Gear list
Re: D7100 gets DXO'd
Hmm ... marginal increases over D7000 and still a long way off the D600.
Compared to the D90 its about half way between it and the D600!
 bryand7k's gear list:bryand7k's gear list
Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) Nikon AF-S DX Micro Nikkor 40mm F2.8 Tamron SP 150-600mm F/5-6.3 Di VC USD
mosswings
Veteran MemberPosts: 7,114Gear list
Re: summary:
In reply to wlad, Mar 27, 2013
Better tonal rendition, but yes.  If you have a D7000 there's not as much reason to upgrade than if you have an earlier generation camera.
 mosswings's gear list:mosswings's gear list
Olympus XZ-1 Olympus Stylus 1 Nikon D90 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +5 more
RhysM
Senior MemberPosts: 2,163
Love the way they say it gives full frame a run for it's money.
Yes, if you shoot at base ISO and aren't concerned with DOF. It's like saying my PC gives CIA super computers a run for their money... provided all you do is use Microsoft Word.
ajamils1
Senior MemberPosts: 1,450Gear list
Interestingly, it is lower Low Light score than D5200.
 ajamils1's gear list:ajamils1's gear list
Sony Alpha 7R II Olympus 12-40mm F2.8 Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sigma 24-105mm F4 DG OS HSM +2 more
nfpotter
Veteran MemberPosts: 4,080
In reply to RhysM, Mar 27, 2013
"Aren't concerned with DOF".
Probably one of the most retarded statements I've ever seen on this site.  Congrats.
PS - for me (and many, many others) FF is NOT an upgrade.
SHood
Veteran MemberPosts: 4,529Gear list
In reply to ajamils1, Mar 27, 2013
Actually, it is the same score.  Take a look at the noise charts.
 SHood's gear list:SHood's gear list
Sony RX100 Panasonic Lumix DMC-GH3 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
fotolopithecus
Senior MemberPosts: 1,699Gear list
Aside from resolution D7100 appears to be a relatively modest improvement on D7000 specs. Nonetheless, an improvement is an improvement.
 fotolopithecus's gear list:fotolopithecus's gear list
Nikon D610 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF-S Nikkor 50mm f/1.8G
AngryCorgi
Contributing MemberPosts: 916Gear list
The small variance between the scores in the different catagories is representative of sample variation and totally normal.
-AC-
Bailey151
Senior MemberPosts: 1,137
I love these "wah, it's not the 2nd coming" threads.
It's an evolution, just as the D7K was to the D90.......& so it continues.
InTheMist
Senior MemberPosts: 3,059Gear list
Same within the margin of error. Calm down.
In reply to fotolopithecus, Mar 27, 2013
The D7000 and D5100 were the same score. That the D7100 and D5200 have the same score within the margin of error doesn't surprise me at all.
Enjoy your new cameras, and stop measurebating.
/Ridicule is not C&C nor is it being helpful nor "stating your opinion"
www.flickr.com/InTheMist
 InTheMist's gear list:InTheMist's gear list
Leica M-Monochrom Nikon 1 AW1 Nikon Df Nikon D810 Nikon 1 J5 +16 more
photomunkey
New MemberPosts: 13
In reply to Bailey151, Mar 27, 2013
I've shot professionally with a D300 since 2008. I tried a D7000 and found the IQ very good but the AF system worse. I've tried two D7100s now and while the AF systems have had calibration problems, I won't go back to shooting either a D300 or a D7000 because the IQ is simply THAT MUCH BETTER. The ability to crop and resize photos like the 21+ mp output of the full-size Canon bodies makes this an incredible camera for a miniscule price. So what if it takes me a while to get one which focuses properly on all 51 AF points, once I do I'll be set with a fantastic DX body and my clients will be super-happy with the vibrant, sharp photos! That's the bottom line for this guy.
Whalligeo
Regular MemberPosts: 245
Indeed. Its not a must have if you already own a D5200 or D7000, more of a nice to have if you see benefits in the other features the D7100 offers excluding IQ. To see a 'real' IQ improvement, that means D600 or D800e (D4 bank buster even), unless of course your coming from a D70/80/90 or D300 series.
They said it couldn't be done, so I encouraged my peers not to bother.
BlueBomberTurbo
Contributing MemberPosts: 855Gear list
In reply to photomunkey, Mar 27, 2013
Confused as to why the D7100 is rated lower in dynamic range.  It shows higher on the charts in a few ISOs, but only a hair lower at ISO 100 and 25,600.
 BlueBomberTurbo's gear list:BlueBomberTurbo's gear list
Sony a6000 Nikon D750 Nikon 1 J5 Sigma 70-200mm F2.8 EX DG Macro HSM II Tamron SP 24-70mm F2.8 Di VC USD +13 more
Whalligeo
I think your seeing a benefit in the pixel count rather than IQ improvements.
rsjoberg
Contributing MemberPosts: 535Gear list
The bottom line for me is that I'll keep my D7000 and probably buy a Coolpix A, which is where I was headed anyway.
 rsjoberg's gear list:rsjoberg's gear list
Nikon D7000 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF +2 more
BlueBomberTurbo
In reply to Whalligeo, Mar 27, 2013
I've also come from a D7000, and I can easily say at 100%, the D7100's noise grain is much finer and more consistent, and the colors much more accurate and pleasing overall.  The colors are better retained at high ISO in comparison, as well.
If you shoot carefully and at low ISO , the sharpness of no low pass filter will allow a 100% image to be used in place of the usual scaled down cropped or full size image.  It's that sharp.  Never had an image like that from my D7000 (even with LV focusing), and I'm using all the same lenses.
sandy b
Veteran MemberPosts: 8,097Gear list
Well, same as D7000 with 8 more mp
Thats a win, IMO.
 sandy b's gear list:sandy b's gear list
Nikon Coolpix A Nikon 1 J1 Nikon D7100 Nikon D750 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
