First Impression on NX300 (unpacked)
Started Mar 27, 2013 | Discussions
wictred Senior Member • Posts: 1,195
Re: First Impression on NX300 (unpacked)
I hope they get rid of you asap.
And I wish snake would still be in this forum. You two would really hit it off.
 wictred's gear list:wictred's gear list
Sony Alpha 7 II Sony FE 35mm F2.8 +3 more
tjobbe
tjobbe OP Senior Member • Posts: 1,430
tecnoworld wrote:
it's not easy to evaluate...you should post unprocessed raw at ISO 1600, 3200 and 6400, side by side with one among nx20/200/210/1000
You know that with none of my recent camera's I ever did any side by side comparison that I did publish anywhere, but what I typically do is checking how far I can  push ISO performance by try and error with scenes I shot before. That is why I do believe that I can push the NX300 up to ISO6400 so 2/3 stop improvement to the NX20 I would guess that max out at ISO4000 for me.
Reason for not that many photos to share is twofold
a) the ones I did on Wednesday require (as being shot RAW) the RC LR4.4 and I did download that only yesterday so the ones I did share are all in camera raw conversion showing the performance of the onboard jpeg engine onyl (!) and I would say that different to before NX10/100/200/1000/20 that I did own or still own, this engine here is really usable up to all ISO levels that LR might be able to deal with. I am not yet able to compare onboard JPEG conversion with the LR4.4 as stated above.  So before sharing any of those let me first play with the RAWs carefully
b) lot of those images are private for the dance company I did the shooting for hence I will first review those with them before they release any. Reason is that at least few shall accompany some newpaper article. Right now I am relaxing with my girl friend, so better things to do
The screen as such has some added space but that (on the left) is used to access some direct touch function as e.g. the AF management and some WiFi. So the image as such looks better on the NX300, means a bit more realistic compared to the NX200 especially, where the AMOLED seemed to oversaturate and you often had some disappointment coming when you watched the images later.
Comparing especially the AF its not an easy thing.
Reason is simple, as indicated before, because the AF performance depends heavily on lens you attach. So I do believe that the NX300 AF outperforms e.g. the 85, the 20-50 by far (and I cannot think of any good reason to bundle the NX300 with that lens !!!! as it is clearly a minus when reviewed when AF Performance is tested). The 45mm and the 18-55 work fine regards the AF, especially the 2D 45mm seems to be ok. I did not yet attached the other pancakes or the 60mm... so cannot tell but based on experience I would see the 30mm being already outperformed on the NX20 regards AF, that it won't be better on the NX300. I would expect the 20 and 16mm pancakes to be able to benefit from the AF speed. Nevertheless the tracking AF and the touchscreen AF is huge improvement and I got already used to it.
The touch screen allows a pretty fast AF selection and I was able to use the tracking AF (activate via touch screen) as well as the AF-C from previous implementation... I have not yet fully determined the differences but I was able to shoot three consecutive RAWs with focus followed with the 85mm
I did buy a Nikon V1 recently on a firesale here and compared to that the pure AF seems to be on par, where the "1" is better still is on firing consecutive shots.
I cannot compare it to e.g. NEX or OM but when I tried the NEX6 at Photokina 2012 was not impressed so just my 2cent (Eurocent :-D)... this implementation is better compared to the OM-D... I would still see the Olympus at the top but I would wait for some better comparison.
All in All it
 tjobbe's gear list:tjobbe's gear list
Samsung NX300 Samsung NX30 Samyang 35mm F1.4 AS UMC Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +18 more
chrisrabe Contributing Member • Posts: 715
Can you tell me, does the nx300 have external microphone jack?
 chrisrabe's gear list:chrisrabe's gear list
Sony a6000 Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro Sony Alpha 7R II Sony FE 70-200 F4 +4 more
Coldamus Senior Member • Posts: 2,281
Not according to the user manual.  It shows only an HDMI port and a "USB and shutter release port".   However there is an optional external microphone EM10 that mounts in the hotshoe.  (same as for NX210, NX1000 and NX20).   Adorama have it listed for US$117.95 (ouch!).
Yes, the price is very high indeed.
That, along with poor availability, is why I was wondering if I could use another microphone.
Am sure I saw mentioned that the nx210 had mic input, so it's a bit disappointing this doesn't. Oh well
Thanks for answering.
Greynerd Senior Member • Posts: 5,534
Read the reviews though that would be a problem if you don't believe them. Can you believe the answers you get here? If you are after a square camera Canon do one, most are rectangular.
The Lens will definitely be round. The ISO and strap will be high.
I hope my replies are as fatuous as your questions.
Knallberto wrote:
Is camera square? Is lens round? Is ISO high? Is camera strap long? ....
 Greynerd's gear list:Greynerd's gear list
Olympus TG-310 Panasonic Lumix DMC-ZS30 Olympus Stylus XZ-10 Panasonic Lumix DMC-FZ70 Olympus OM-D E-M5 +9 more
Ariston Senior Member • Posts: 2,401
thanks tjobbe. how is the exposure btw? there was an image comparison between the NX200 and NX300 shooting the same scene where the NX300 exposed brighter than the NX200 at the same aperture, shutter and ISO using the same lens. by my estimation the exposure difference is about half or 2/3 stop.
anyway, I somehow agree with you with regards to the NEX-6 AF where I find the AF focusing speed not impressive at all in comparison with other mirrorless which performed better. I was pretty surprised about dpr's assessment that the AF is good or not bad at all for a mirrorless despite the fact the it doesn't appear to be even at par with the faster ones. in my opinion, the NEX-6 was no better than most mirrorless with CDAF which bring it's PDAF introduction rather empty or didn't deliver despite the promise that it could make things faster.
Knallberto Veteran Member • Posts: 5,478
Ouuuhh, thanx! All things I didn't know. My favorites are HelloKittyCams. Pink. With 6mp, more nobody needs.
For under $99 you get EXCELLENT extern mics - usable with EACH camera, 10x more features like such sea robbery mics.
tjobbe
Rgds Mic: there is no common jack for a standard Mic but as it was with the NX210/NX20/NX1000 the NX300 as well has a the option to mount the EM10 via Hotshoe so not sure where you misread the external microphone by interpreting that it has a dedicated mic jack i
Haven't tried that as I leave that to more academic dicussions here some shots from today trying to check the higher ISO values with OOC JPEG. I used VIVID and NR set to low with no further optimization made
tjobbe
OOC JPEG with VIVID and NR Low
Size reduced for another forum with limited space
tjobbe
tecnoworld
tecnoworld Veteran Member • Posts: 6,730
I'm astonished by iso8000....looks better than iso3200 on nx200...
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
tjobbe
Recall that this is in camera JPEG !!!! I did not process ANY raw image yet other than converting a RAW file within the NX300 with the onboard raw tools. These above are all OOC JEPG
timedrun Contributing Member • Posts: 683
Its all looking really encouraging, the iso8000 is totally useable. thanks for the efforts, got any higher iso pics? cheeky i know.
A little green rosetta......a tiny green rosetta........
 timedrun's gear list:timedrun's gear list
Samsung NX20 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake Samsung NX 45mm F1.8
fake !
tjobbe
Ariston wrote:
fake !
me2
tecnoworld
What do you mean?
tjobbe
tecnoworld wrote:
What do you mean?
he means that no Samsung camera will ever be able to shoot usable OOC JPEG at ISO8000 hence this is a fake....
So am I
forgot the smilies
tjobbe
chrisrabe wrote
Can you tell us though, can you charge the BP1030 in camera on over USB?
It would be great to not have to carry charger around if taking NX1000 as spare on holiday.
to answer that one: I am currently charging a 3rd party battery i bought for the NX200 being BP1030 compliant via USB in the NX300 so my answer is YES
