Question about Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
Started Mar 27, 2013 | Discussions
pavinder
Regular MemberPosts: 253
Mar 27, 2013
Just bought my OM-D today, and am considering which lenses to add on.  I currently only have the kit 12-50mm 3.5-6.3
My plan at the moment is to buy in the following order (when I have the cash)
1. Panasonic  35-100mm 2.8 - for longer shots and bright lens.
2. Panasonic 12-35mm 2.8 - brighter than the kit lens (but with rumours of an upcoming Olympus zoom with similar FL range I'm happy to hold off on this a while)
3. Panasonic 100-300mm 4.0-5.6 - all reviews and opinions indicate it's the best long lens.  I also saw a second hand lens at a good price today.
But I'm a little unsure of the 100-300mm and wondering whether I should wait on this too, mainly because the lens is getting on for 3 years old so I wonder if there a strong likelihood of a new lens being released to supercede this, either a brighter lens to complete a Panasonic f2.8 trio, or maybe a comparable Olympus?
Further to this, would a 100-300mm f2.8 lens be:
a) possible to make   or
b) prohibitively heavy/large/expensive  anyway?
Thanks for your opinions.
Bob Tullis
Forum ProPosts: 30,501Gear list
Re: Question about Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
In reply to pavinder, Mar 27, 2013
All those are good choices.   Though you might want to weigh the Oly 75-300 against the Lumix 70-300.
I'm firmly wedded to Lightroom, but use DXO Optics like a plug-in to run the 28-70/2.8 images through (you might want to check it out).
...Bob, NYC
http://www.bobtullis.com
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Olympus 12-40mm F2.8 Voigtlander 28mm F2 Ultron Sony RX1R II +20 more
JCB123
Senior MemberPosts: 1,248Gear list
A faster aperture version would be larger and heavier. A constant f4 version might not be too much larger, but f2.8 would be quite a beast.
There are not many choices in the native lens line up for exotic super telephoto. If you want a lot of reach you might want to consider using Canon, Nikon, et al lenses via an adapter. That will be manual focus and aperture only mind.
Native m43 options are Panasonic 45-200, Panasonic 100-300, Olympus 75-300.
Regards
John
 JCB123's gear list:JCB123's gear list
Sony RX100 Nikon D90 Nikon D7000 Olympus PEN E-PL5 Nikon D7100
pavinder
In reply to Bob Tullis, Mar 27, 2013
Thanks Bob.
I'll have a look at the Oly 75-300, and that DXO Optics looks very interesting too...
pavinder
In reply to JCB123, Mar 27, 2013
Thanks for the comments John.
Yes, I imagined size/weight might be an issue.  And I'll compare reviews of those alternative lenses too.
I saw the Panasonic 45-150, 45-175 and 45-200 at the shop today - definitely need to research the differences other than their FL.
I'd considered an adapter and DSLR lenses, but the main reason I've just bought into M4/3 is to reduce size/weight so I'd be contradicting myself a little.  But if adapters are cheap, I'll dig out my old FD Canon lenses and test them at a shop, see how they feel.
Setter Dog
Veteran MemberPosts: 4,504
I'm on my second trip through m43 land and Panasonic cameras and lenses. Before, I had the 45-175mm and the 100-300mm. I really liked both lenses.
This time I hoped to get away with a 45-150mm for my zoom work. It's a really, really good lens and has the compact M43 "look" that I like. It is basically my every day lens on a G5. However, just around the yard and locally, I felt zoom restricted and knew I would want something longer for Teton/Yellowstone and even kids' baseball. I ordered the 100-300mm and it will be here tomorrow. I like the lens stabilization in zoom lenses. Not sure how the IBIS looks through the EVF, but the view through the EVF with my Sony with IS and long unstabilized lenses is pretty shaky. Results are good, however.
I shopped eBay and was surprised that used 100-300mm lens sell, on average, for about $440. It seemed a no brainer to buy one for $499 at Adorama. Just like renting, I suppose.
You'll like the lens, especially the "look" through the EVF at long zoom.
Jack
Rol Lei Nut
Senior MemberPosts: 1,184Gear list
Don't know where you found "all" those reviews, but the Oly 75-300 is generally considered to be at least its equal optically.
I recently changed from the Panny 100-300 to the Oly 75-300 because the latter is far more of a "take anywhere" lens and handles better to boot.
In my tests, the OM-D's IBIS also outperformed OIS at 300mm
pavinder
In reply to Rol Lei Nut, Mar 27, 2013
By "take anywhere" do you mean because it's a bit narrower and 20% less weight than the Pany?
pavinder
In reply to Setter Dog, Mar 27, 2013
Setter Dog wrote:
Not sure how the IBIS looks through the EVF, but the view through the EVF with my Sony with IS and long unstabilized lenses is pretty shaky.I shopped eBay and was surprised that used 100-300mm lens sell, on average, for about $440. It seemed a no brainer to buy one for $499 at Adorama.
When I tried it on the OM-D in the shop, the IBIS worked wonders with the 100-300mm.  At 300mm it was steady as a rock.
As you say, second hand prices seem good.  I can pick it up for ¥40,000 whereas buying new it would be around ¥56,000.
Enjoy your new arrival tomorrow and the upcoming trip!
kenw
Veteran MemberPosts: 4,859Gear list
As others mentioned the Oly 75-300 is a good option.  Optically the equal and perhaps a little sharper - but also a little slower as far as aperture goes.  Smaller and lighter.  The new just released version is the same optics as the older one but now better priced and with better lens coatings.
Usually lenses have a very long lifetime as products.  If it was going to be replaced it would probably be a minor update like the Olympus 75-300 update which was mostly cosmetic.  Bodies update about one a year, lenses usually take five years or longer.
The front element would have to be 110mm in diameter at a minimum.  That is fairly gigantic even for a FF SLR lens.
Ken W
See profile for equipment list
 kenw's gear list:kenw's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GM1 Olympus E-M5 II Panasonic Lumix G Vario 7-14mm F4 ASPH +29 more
nick101
Contributing MemberPosts: 905Gear list
I'm a fan of the 100-300 (and an owner), but I'm seeing the Oly 75-300 at very low prices at the moment, so you might want to look at it - £120 (around $180) at Amazon UK.
It's a good lens by all accounts, and with the IBIS of the OM-5, the lack of in-lens stabilisation isn't an issue
 nick101's gear list:nick101's gear list
Sony RX100 Fujifilm X100S Canon EOS 7D Olympus OM-D E-M5 Panasonic Lumix DMC-GH2 +12 more
Vlad S
Veteran MemberPosts: 3,641Gear list
100-300mm F2.8
Sigma makes a 120-300mm f/2.8. The size difference for SLR and mirrorless lenses of the same FL is small for long lenses, so I think that a µ4/3 100-300 f/2.8 would look similar.
The lens is 289.2 mm × 114.4 mm, and weighs almost 3 kg, or about 6.5 lbs. It sells on Amazon for $2700. You can see images of it in the review here.
I think that as we get to the point where µ4/3 can easily be the only system that an advanced photographer can own, such a tool would be welcome, even if it is not something that a lot of people would buy. But the Sigma lens does not have peers from Canon or Nikon, and I do not think that Olympus or Panasonic will be interested in creating such a niche lens.
Vlad
 Vlad S's gear list:Vlad S's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +2 more
PAUL TILL
Veteran MemberPosts: 9,285
In reply to nick101, Mar 27, 2013
Care to share a link to that? The Olympus 75-300mm holds its value extremely well, I couldn't find one for less than £450.
Are you sure you're not thinking of another lens?
The 10% Rule:
You Must Be 10% Smarter Than The Equipment You're Operating
Pixnat2
Veteran MemberPosts: 3,428Gear list
This lens exists : the Zuiko 90-250mm f/2.8
Yes. The 90-250 f/2.8 is made for 4/3 sensor. There's even a Zuiko 300 f/2.8 made for 4/3 sensor
Yes, of course. You can look how large it is on m4/3 bodies :
http://www.four-thirds.org/en/special/matching.html
The zuiko 90-250 f/2.8 costs 6000 $ and weight 3.27 kg
The zuiko 300 f/2.8 costs 7000 $ and weight 3.27 kg
So, the answer is yes to all your questions.
I seriously doubt we will see one day such lenses for the m4/3 system. It would make no sense for a protable system.
 Pixnat2's gear list:Pixnat2's gear list
Nikon D750 Fujifilm X-E2 Olympus E-M1 Nikon AF-S Nikkor 85mm f/1.8G Nikon AF-S Nikkor 50mm f/1.8G +11 more
Paul North
Senior MemberPosts: 1,611Gear list
Well, if it is a good lens, and people are buying it, chances are Panasonic will not be updating it any time soon!  If Sigma or Tamron come out with a similar lens with better optics I would expect them to update it but not because it has been out there for 3 years.  Look at some of the canon lenses such as the 100-400, it has been around for years.
Paul.
Rol Lei Nut
Yes, because that's the difference which lets it comfortably slip even into a small bag's lens pouch...
Fredrik Glckner
Veteran MemberPosts: 3,251
I don't expect the 100-300mm lens to be revised.  Sure, it is not perfect, but at the price, it performs quite well.
Very few M4/3 lenses have been revised so far, and only the volume kit lenses. That makes sense from an economic point of view. To revise the 100-300mm lens makes less sense, since it is a low volume, specialized lens.
http://m43photo.blogspot.com/2011/10/lumix-g-100-300mm-f4-56.html
shihhan
Regular MemberPosts: 307
What about the 75-300 II? OIS is not an issue for EM-5 really...
The original 75-300 was slower than 100-300, but has better IQ (and funnily enough, cost more)
100-300 f2.8 will be stupidly large and prohibitively expensive (The FT 150 f2 was priced £2000).
I think you're more likely to see the 100-300/4-5.6 stay as the slow long tele lens... (along with 75-300 / 75-300 II)
If you want fast glass, there will be a 150 f2.8 (likely to be pricey)
Would love a 100-300 f4 or even just a 300 f3.5 would do!
Have you considered manual focus? Get some old OM / Nikkor stuff and use adaptor. Cheap way to get fast glass.
nick101
In reply to PAUL TILL, Mar 27, 2013
The 10% Rule:
You're correct - it's my mistake, and I apologise.
I was looking at the 14-150. I have no idea why I confused the two, unless it's just stupidity.
PAUL TILL
In reply to nick101, Mar 28, 2013
The 10% Rule:
Even the 14-150mm goes for more than that! Are you sure you're not thinking of the 40-150mm?
Lucky for you, you didn't click buy, you would have had a bit of a shock when it turned up.
The 10% Rule:
