X100S Video
Started Mar 27, 2013 | Discussions
vibranzeteh Forum Member • Posts: 65
X100S Video
Hey guys,
I just uploaded a video of X100S, I would say it is ungraded as I merely combined all the footages in Premiere Pro without tweaking anything at all.
Hope it is useful to those who like to find out the video quality from X100S especially in low light.
At the moment, only Youtube link is available. I am uploading to Vimeo and will share the link once it is finished.
Here is the link.
http://www.youtube.com/watch?v=J_kktTUKdRY
Thanks.
 vibranzeteh's gear list:vibranzeteh's gear list
Sony SLT-A99 Fujifilm X-E2 Sony 70-200mm F2.8 G Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 85mm F1.4 ZA Carl Zeiss Planar T* +2 more
Fujifilm X100S
vibranzeteh OP Forum Member • Posts: 65
Re: X100S Video
Vimeo link is up - https://vimeo.com/62776099
Enjoy!
Oger Junior Member • Posts: 43
Re: X100S Video
Hey thanks a lot for the video!!!
can you just tell us what settings you used on the X100s?
I guess 30fps?
aperture?
Astrophotographer 10 Senior Member • Posts: 6,594
Re: X100S Video
Its quite good but Fuji needs to add some sort of stabilisation like Sony Steady Shot. Otherwise even though your video is not particularly jittery it is a bit and this detracts from the video result a lot.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +4 more
hellocrowley Senior Member • Posts: 1,271
Re: X100S Video
The inability to set shutter speed caused all neon/fluorescent lights to blink non-stop through out the video. Also the moire is quite horrible. I guess it's ok for a walk but I've seen P&S do better.
Allen Chernack
Allen Chernack Senior Member • Posts: 1,401
Re: X100S Video
All in all, a good video. Hong Kong looks like N.Y.   I saw the neon flash someone mentioned otherwise I thought it was so steady  that you used a tripod or mono pod.  I'm never that steady.
tourretired
Travel in RV when not home.
 Allen Chernack's gear list:Allen Chernack's gear list
Sony Cyber-shot DSC-HX30V Fujifilm X-E1 Fujifilm X-T1
Re: X100S Video
Greg.
Thanks Greg.
It was taken handhold without tripod so yeah, it's not stabilized hence the jittery. The only technique that I used was to make use of the neck strap as a stabilizer.
Cheers.
Re: X100S Video
tourretired
Thanks Allen. HK is a very lively city, some people like some hate.
My trick to make it steady is to hang the strap on my neck and pull the cam all the way in front of my face until the strap strained out and it will make the cam steady.
Btw, I'm shooting using LCD, that's why the trick works. If you are using EVF/OVF then you can't use it.
Cheers.
Re: X100S Video
I guess 30fps?
aperture?
Hi Oger,
You are welcome.
Initially I shoot at 30fps until I found out that it can actually be change, from there on I always h shoot 60fps. The video is kind of mixed between 30fps and 60fps but the template I choose in Premiere Pro is AVCHD 60FPS.
Aperture always set to f2.0. Film mode sometime Pro Neg Hi sometime Velvia.
Cheers.
Re: X100S Video
Which P&S? RX100?
Cheers.
klukkluk New Member • Posts: 18
Re: X100S Video
After seeing this video (nicely done btw!) I would like to visit Hongkong. Seems like a vibrant city.
Re: X100S Video
Thanks klukkluk. Yes, it's a must visit country. Just pack and go!
ralphdaily Regular Member • Posts: 257
Re: X100S Video
Thank you for posting, the HK videos were very interesting.  I've always been interested in HK.
 ralphdaily's gear list:ralphdaily's gear list
Fujifilm FinePix X100 Sony RX100
