Good 50mm Lens For Sony Nex ... on a Budget?
Started Mar 27, 2013 | Discussions
saintz Contributing Member • Posts: 549
Re: Good 50mm Lens For Sony Nex ... on a Budget?
I bought mine recently for about $50. If you look hard, you can find at that price. Otherwise, yes, they're closer to $100.
 saintz's gear list:saintz's gear list
Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS
Louno OP Regular Member • Posts: 101
saintz wrote:
The Pentax Takumar versions (SMC, Super, Super Multi Coated) are my favorite. The 50 f1.4 can be had around $50. Make sure you know if you're getting a Pentak K mount or M42 mount so you know what adapter you need.
Second choice would be the Minolta 50 f1.4. Then a Canon FD or Nikon.
The cheap $10 eBay adapters work fine for these.
Interesting, which of these would be more compact, with an adaptor? It seems the adaptors are pretty chunky, are there a type of lenses that have smaller adaptors but are as good and inexpensive?
 Louno's gear list:Louno's gear list
Sony Alpha NEX-3N Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +1 more
Chris_Downunder Contributing Member • Posts: 611
Louno, the adapters for any lens designed for a 35mm SLR camera will be about the same size as this is the distance required to get the lens to focus correctly (called the registration distance). The alternative is a rangefinder lens like one of the Russian-made lenses or Contax lenses (but the Contax are expensive) which use an M39 threaded adapter. Considering what you are planning to photograph, I'd suggest a lens designed for macro work as these tend to produce better image quality at closer focus. I have a 50mm f3.5 Olympus macro which cost $70 and produces very nice images.
All the best,
Chris
Russian 50mm Industar with M39 mount (but this model has a lousy minimum focus distance).
 Chris_Downunder's gear list:Chris_Downunder's gear list
Sony Alpha NEX-5N Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sigma 30mm F2.8 EX DN Sigma 19mm F2.8 EX DN +9 more
BasiliskPhoto Contributing Member • Posts: 990
The Soviet rangefinder lenses are OK - like the Jupiter 8 - makes for a nice compact setup. However the quality control is not even as good as the East German lenses they ripped the designs from - my Jupiter is a fairly low contrast lens - and as you say, the minimum focus distance (1m) is over double that of my Super Takumar or Canon FD 50mm lenses. If it was a better lens then I might consider one of the helicoid M39 adaptors that acts like a collapsible extension tube.
clearzoom Senior Member • Posts: 3,026
This got me concerned,as I am getting one of these two lenses and want to make sure I get correct adapter
1) Pentax Takumar 50 f1.4 but cant see which mount is it and which adapter should I order out of these two. pl assist
http://www.amazon.com/RainbowImaging-Pentax-mount-Camera-Adapter/dp/B003X19WZC/ref=sr_1_4?ie=UTF8&qid=1369952289&sr=8-4&keywords=Pentax+adapter+for+sony+nex
http://www.amazon.com/RainbowImaging-Mount-NEX-3-Camera-Adapter/dp/B003YBPRHI/ref=sr_1_3?ie=UTF8&qid=1369952289&sr=8-3&keywords=Pentax+adapter+for+sony+nex
and this one does confirm it is 42mm mount but lot of items in ebay dont even say their mount K or 42
http://www.ebay.com/itm/Asahi-Pentax-SMC-Takumar-50mm-F1-4-Prime-Lens-M42-Screwmount-/121108988388?pt=Camera_Lenses&hash=item1c32a881e4
2) and would this adapter work for Minolta Rokkor 50 f1.4 ?
http://www.amazon.com/RainbowImaging-Minolta-NEX-3-Camera-Adapter/dp/B003XQ6FDE/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=1ZRWLXA401IIJ&coliid=IAL5OHWHBYZF6
thks for help
 clearzoom's gear list:clearzoom's gear list
Sony Alpha NEX-6 Canon EOS 70D Sony a6000 Canon EF 70-200mm f/4.0L USM Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) +7 more
expireduser Regular Member • Posts: 161
I'm sure any good fast legacy lens will serve you well. I bought a Canon FDn 50mm f/1.4 for about $50 a couple months ago and it works very well for me. It's pretty soft at 1.4 but sharpens up quickly, even 2 is pretty good. It's great for low light video at 1.4. It's incredibly sharp stopped down, and infinity focus is perfect with my $9 rainbow imaging adapter - no problems going past infinity for example.
Honestly just get whatever brand you feel most nostalgic about and have a blast.
 expireduser's gear list:expireduser's gear list
Sony Alpha NEX-7 Sigma 30mm F2.8 EX DN Sigma 19mm F2.8 EX DN +5 more
ProfHankD
ProfHankD Veteran Member • Posts: 3,881
IDing lens mounts, matching adapters
It's easy to tell from the photos of the rear; see http://rick_oleson.tripod.com/index-99.html
Aside from that, I've noticed that many K lenses say Pentax on them, whereas the M42 ones say things like Auto, Super, or SMC but not Pentax. There are photos of all the MANY variants at pentaxforums. Also, beware that some M42 adapters have a little shelf in them to press-in the rear stop-down pin -- those will not work on the later SMC lenses because they block the lens from being fully screwed in (the pin is supposed to be pressed by a little flip-out tab, whereas the shelf goes all the way around the rear of the lens, interfering with a tab that was added in the last generation of M42 SMC Takumars).
Rokkors are generally Auto, MC, or MD (with later MD lenses dropping the Rokkor name and saying Minolta); Minolta also sold a cheaper line of nearly identical lenses under the Celtic name. The mounts are officially SR, MC, or MD, which are all compatible with the same adapters -- like the one you reference. Just beware that the later Minolta AF mount is completely different -- and is now known as Sony A-mount; this mount is easy to spot because there are electrical contacts on the mount (although the number of contacts has varied over time).
In my opinion, the M42 50mm f/1.4 Takumars give among the best bokeh renderings of any lens, with good sharpness provided it isn't yellowed. If it is yellowed (by the mildly radioactive element inside), UV cleaning will dramatically improve sharpness -- the yellowing seems to do more badness than merely tinting the image and reducing transmissivity (a seriously yellowed f/1.4 can pass less light than a clean f/2.8).
The old Minolta lenses also give better than average bokeh -- consistent color and good bokeh were attributes Minolta emphasized back when the fact that they made their own glass allowed them to do color matching better than competitors like Nikon. Each company tended to have their own weighting of which attributes they'd optimize for; e.g., it seems to me that Canon emphasized contrast in their lenses, with better contrast and often lousy bokeh and color compared to Minolta. In summary, nearly all "fast 50s" are pretty good, but different companies favored different attributes, and that's why people can have endless arguments about which is "best" overall.... Or, with NEX, you can just get all of them and use each for what it is best at....
Canon PowerShot A640 Canon PowerShot A720 IS Canon PowerShot S70 Canon PowerShot G1 Canon PowerShot G5 +24 more
If the rear of a Pentax/Takumar is threaded like a screw, it's a M42.
http://en.wikipedia.org/wiki/M42_lens_mount
If it's got the typical bayonet mount with three large tabs, it's likely K mount (assuming it's an older Asahi/Pentak/Takumar).
http://en.wikipedia.org/wiki/Pentax_K_mount
You can now find the SEL50f18 for about $200 on eBay. It's still (at least) twice what you'd pay for a good 50mm and adapter, but it's very sharp and has OSS and AF, if that matters for your purposes.
