DSLR camera in portrait mode
Started Mar 26, 2013 | Discussions
Riki
Riki Senior Member • Posts: 1,508
I was thinking of getting a universal L bracket for fast move from Landscape to Portrait mode.  I have a Arca Swiss B1 ballhead and Gitzo tripods. I will be buying the D800 soon. Is it better to get a L bracket or get another tripod or another head . What do others use ?
 Riki's gear list:Riki's gear list
Nikon D810 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +4 more
Nikon D800
Nigel Wilkins
Nigel Wilkins Senior Member • Posts: 1,006
Re: DSLR camera in portrait mode
I used to use a 3-way pan & tilt head which I could just tilt 90 degrees to get to portrait, but since buying an L bracket, I'd never do that again.  It's just so much more convenient with an L bracket & more stable at the same time since the camera's weight stays centred over the head.
I'd say an L bracket is one of the best investments I've made for a long time.  It also provides additional protection to the camera body as a bonus.
bravozulu
bravozulu Contributing Member • Posts: 897
I asked the same question a few months back. I've got an old heavy Gitzo tripod with a center column and a new Giottos ballhead. About 10kg capacity. I wondered what L Brackets were all about.
The folks who responded said the L bracket gives you speed when switching from landscape to portrait mode on a tripod. Using the drop-down slot on a ballhead is slow. And, to some extent not very repeatable. You have to set that angle level each time you switch.
And with some heavier lenses, flopping a ballhead into the slot throws off the balance of the tripod. With an L bracket, the weight of camera and lens are always centered on the ball.
If you are a pro, the L bracket with QR is a must. For an amateur like me, I'll pass. Way too much money for those fancy names with high prices. And I'm not in a hurry.
 bravozulu's gear list:bravozulu's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF-Nikkor 80-200mm f/2.8D ED +5 more
Russell Evans
Russell Evans Forum Pro • Posts: 11,514
A L-bracket let's me position the camera on my swing arm tripod in ways not possible without.
A L-bracket lets me use lighter as well as smaller supports with my camera.
In keeping with both the above, I can attach my camera to a lot of random objects. Sign posts, parking meters, railings, ...
If you are taking panoramas, the camera in the portrait position on the pano head provides a Vertical FOV for the finished photograph.
If you use a macro rail system, being able to mount the camera in landscape or in the portrait position can mean getting the exact framing you want.
All said, an L-bracket isn't less about speed for me, and more about getting more physical control over the camera.
Thank you
Russell
Riki
Riki OP Senior Member • Posts: 1,508
I think I will have to get a L plate. the Arca Swiss ones look very good but pretty expensive. I tried shooting portrait mode on my Gitzo Explorer 2220 and Novoflex Magic Ball and it wasnt bad at all with a light lens. However with a heavier lens I guess a dedicated L bracket is the answer. To answer bravozulu, no, I am not a pro but a over enthusiastic amateur.
puttin
puttin Veteran Member • Posts: 6,713
I got a 1 piece L bracket from ebay for $35 instead of $90-$100 for a dedicated one. Works on all my cameras.
 puttin's gear list:puttin's gear list
Fujifilm XF1 Fujifilm X100S Nikon Coolpix A Nikon D300 Fujifilm X-Pro1 +30 more
Riki
Which brand for $35/- ? Can you please point me where to look, thanks
puttin
Search ebay for universal L brackets. Desmond brand, model DAL-1. I just ordered another one 1 hr ago.
