On board flash importance
Started Mar 26, 2013 | Discussions
NancyP Veteran Member • Posts: 5,280
Re: pretty insects and spiders
Very well done. The good old "paper/foam dinner plate" diffuser?
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
dexter9 Regular Member • Posts: 142
Re: No
Ubilam wrote:
Matt wrote:
If I want to take photos (snaps) that are fine with an on board flash then I wouldnt be carrying a pro camera around.
Then what is wrong with you? If you are serious about taking pics, why would you not take your better gear out and about? I do. I don't use a P&S or smart phone. My 7D image quality tells me the hassle is worth it... even with snaps. You are lazy.
Ubi.
Isn't that like the pot calling the kettle black?
If you are serious about taking pics, why would you not take your better gear out and about (a dedicated flash)?
A dedicated flash will always produce better results than an on camera flash.
Perhaps you are the lazy one Ubi
And to answer your original question:
"Is an on-board flash on a camera important to you?"
No, not in the least bit.
 dexter9's gear list:dexter9's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 40mm f/2.8 STM
MisterPootieCat
MisterPootieCat Veteran Member • Posts: 3,097
60D on-board flash
NancyP wrote:
I should add, I have a 60D, I use the on-board flash as main flash only on rare occasions, and I don't expect good looking pictures, just documentation. I don't like the straight-on flash flatness. If the 60D on-board flash was a control unit, I would use it as such.
The 60D supports wireless flash, same as the 7D.
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon PowerShot S2 IS Canon PowerShot S5 IS Canon PowerShot G10 Minolta DiMAGE Z1 Konica Minolta DiMAGE Z2 +22 more
borno
borno Senior Member • Posts: 1,109
Re: On board flash importance
I would rather not have a flash circuit in my camera as my first digital body got fried when it was only a couple weeks old by the flash capacitor. Most built in  flash shots are not appealing anyway to me. I have a metz if I need it. : )
 borno's gear list:borno's gear list
Canon PowerShot G1 X Canon EOS-1Ds Mark II Canon EOS 7D Mark II
BAK Forum Pro • Posts: 20,632
Yes it is
All the built-in flash on my camera will do is light up shadows.
Chances are when I move to another camera, I will get one with a built-in flash that also triggers remote flash units wirelessly.
Jeff Peterman
Jeff Peterman MOD Forum Pro • Posts: 11,763
One reason I've been reluctant to buy a 5D is the lack of an on-board flash. The flash isn't very powerful, and isn't in a great location, but it means I always have a flash if I need one. If I know ahead of time that I'll need a flash I'll pack a 580EX or other lighting gear. But there have been times when I've only been planning to shoot with available light and someone says "can you take a shot of us?" under conditions I know will give a poor image without flash - I can just press the flash button, shift my mode to C1 (which I have pre-configured as my starting point for on-board flash) and quickly take the shot.
The on-board flash is also useful for triggering external flashes.
Jeff Peterman, Moderator 7D and Phone/Tablet forums.
Not a staff member, or paid employee, of DPReview.
Any insults, implied anger, bad grammar and bad spelling, are entirely unintentionalal. Sorry.
www.pbase.com/jeffp25
www.jeffp25.smugmug.com
 Jeff Peterman's gear list:Jeff Peterman's gear list
Panasonic Lumix DMC-FZ40 Canon PowerShot S110 Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +18 more
Jeff Peterman
Re: No
Hmm, the response to your question was no: for this person, on-board flash isn't important. Why does this upset you?
As I said, for me on-board flash is important, even when shooting for others at events. But I can fully appreciate why others (who take different types of shots) would not consider a built in flash important.
(unknown member) Senior Member • Posts: 5,590
Yes I think many people would now find it useful.  To be fair to Canon though, their own extensive research with many photographers in many countries at the time indicated that there was little or no demand for it.  Given that feedback I'm really not surprised they left it off but I suspect if they repeated those surveys today they might get a different result.
It is also true that the flash on top of the pentaprism is a weak point in terms of potential damage / water resistance.  On models that have it that have been dropped or suffer impact damage the flash often has to be completely replaced.  The water resistance issue can be largely be overcome of course, if enough is spent on engineering but at the time they really didn't think it was worth spending the time on.
BDW_12 Regular Member • Posts: 142
I have never used it. I always use a 580ex.
--Bruce
Christoph Stephan
Christoph Stephan Veteran Member • Posts: 3,969
Yes, very important
Ubilam wrote:
I like the available on-board flash on my 7D and it comes in handy. The so-called PRO canon cameras have no built-in flash so you have to carry around a dedicated flash and attach it when needed, or use high noisier ISOs to capture the moment while paying more to do so.
The question I ask is... "Is an on-board flash on a camera important to you?"
(This is my 3,000 post on DPR)
May be no one dares to admit it, but I do: I find the onboard falsh very useful, not only for pictures in the dark, but also for fill flash - a creative tool which cannot be simply replaced by longer exposure and high ISO
Another use is in macro pictures. I stop down the macro lens to f < 22, and use manual mode and the fill flash to get pictures with great depth of field and any disturbing backgorund veiled in black by deliberate underexposure.
You will need to use negative flash exposure compensation for this, otherwise the flower in the foreground is to bright.
I have a seperate flash but it is seldom with me: I always prioritise addtional lenses over it on a trip.
 Christoph Stephan's gear list:Christoph Stephan's gear list
Canon EOS 20D Canon EOS 40D Canon EF-S 17-85mm f/4-5.6 IS USM Canon EF-S 55-250mm f/4-5.6 IS Tamron AF 28-300mm F/3.5-6.3 XR Di VC LD Aspherical (IF) Macro +1 more
Re: Yes, very important
Yes, it's useful as long as you are not to close to the subject.  A 50mm macro for example at 1:2 will be so close that any subject will only be partially illuminated at the top by an onboard flash and the light fall off can be quite dramatic.
jrkliny
jrkliny Veteran Member • Posts: 3,503
I use mine infrequently but really appreciate having it when needed:
fill flash
flash trigger
emergency flash
Jim, AKA camperjim, formerly from liny, Long Island New York
 jrkliny's gear list:jrkliny's gear list
Canon EOS 600D Canon EOS 760D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +6 more
Christoph Stephan
Yes, 1:2 is approximately borderline for what you can use the onboard flash, I experienced this with my Sigma 50mm f2.8, too.
I wonder whether the Canon EF-S 60mm f2.8 does not shadow the onboard flash at closer distances, as it does not extend during focussing.
Old Sarge Regular Member • Posts: 194
Jeff, this is exactly the way I feel about it (I think I'll do what you mention and set C2 for my flash starting point).  This subject, like "lens protection" filters and Av vs. Tv settings, seems to generate a lot of heat with little information.  I started photography in an era when flashbulbs were the general rule (I lusted for a Honeywell strobe and a Braun was just a pipe dream) and back when I was shooting weddings (on film) I used Vivitar 283s and had a Stroboframe to get the flash off the camera but I still appreciate the on-board flash both for fill outside and as a convenience inside. I probably use it more than I do my 580EXII for that reason.  I also appreciate the ability to use it as a trigger sometimes if I feel like a more elaborate set-up.
To each, their own.
The Old Sarge
It's not just the lens shielding the subject but also that the flash itself is slightly pointing in the wrong direction.  It's like the parallax error in a rangefinder camera - the flash is directed so that its spread is even on a subject about 2-3 metres away.  But as you move progressively closer the error increases.
There have been a few on-board flashes where the beam of light could be angled downwards slightly which helps, provided you don't forget to reset it for normal work.
Zee Char Forum Pro • Posts: 10,519
Limburger wrote:
It's my IR transmitter
Cheers Mike
It works very well. I know there is the whole line of site thing but indoors is no issue unless you are around 5 corners. I was in a lighting workshop on Sunday put on by a local camera club. We split in 2 groups and went to separate rooms. The door had about a 2' by 2' window. The cactus trigger in our room failed so we went optical. Every time they fired the flash in the other room it set ours off. We had to tape cardboard to the window   Outdoors it gets dicey.
 Zee Char's gear list:Zee Char's gear list
Canon EOS 7D Mark II Canon EF 300mm f/4.0L IS USM Canon EF 70-200mm f/2.8L IS II USM Canon Extender EF 1.4x III Sigma 2x EX DG Tele Converter +3 more
fill flash
flash trigger
emergency flash
Yeah even though I said it is too small a light source for me it can come in handy. It just one time I tried to rotate it for bounce flash and tore it off my camera They sell diffusion screens and bounce back reflectors but you can make your own for pennies. Just not my thing. I think it has popped up 3 times in 3 years on my 7D and that was by mistake.
Klaus dk
Klaus dk Veteran Member • Posts: 3,342
Cardboard - why didn't you just change channels?
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF 50mm f/1.8 II +9 more
Limburger
Limburger Senior Member • Posts: 6,324
Cardboard is more DIY
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100
Limburger
Zee Char wrote:
Cheers Mike
Splendid story
Reminds me of a story some guys were taking remotes to clubs changing track on the cd players
In the club they probably figured carboard is a very handy thing to work with.
Cheers Mike
