On board flash importance
Started Mar 26, 2013 | Discussions
(unknown member) Veteran Member • Posts: 3,860
I like the available on-board flash on my 7D and it comes in handy. The so-called PRO canon cameras have no built-in flash so you have to carry around a dedicated flash and attach it when needed, or use high noisier ISOs to capture the moment while paying more to do so.
The question I ask is... "Is an on-board flash on a camera important to you?"
(This is my 3,000 post on DPR)
Canon EOS 7D
Matt Senior Member • Posts: 2,387
No
If I want to take photos (snaps) that are fine with an on board flash then I wouldnt be carrying a pro camera around.
The only advantage of the on board camera (IMO) is that it can be used as a flash trigger and even that is of questionable value to me as I always use dedicated wireless triggers anyways.
So no, I surely dont need an on board flash
Canon EOS 400D
Sigma 24-70 HF
Canon 50 f1.8
rodbam Veteran Member • Posts: 9,046
Yes for macro
I use the built in flash along with a large white plastic plate diffuser & get really well lit macro shots. I read about doing this here from a poster from Spain who posted some magnificent macros done this way. I haven't done too many but I think the soft light from the on board flash works great. I couldn't get the same light from my 430ex but I didn't persevere with it.
Regards Rod
(unknown member) OP Veteran Member • Posts: 3,860
Re: No
Then what is wrong with you? If you are serious about taking pics, why would you not take your better gear out and about? I do. I don't use a P&S or smart phone. My 7D image quality tells me the hassle is worth it... even with snaps. You are lazy.
Ubi.
Klaus dk
Klaus dk Veteran Member • Posts: 3,349
Who is lazy?
Ubi.
Ubi, it is you who is lazy if you will neither carry a proper flash nor read Matt's post properly. And why call other names, just because they disagree with your OP?
I use the OCF as a disabled master. I have little use for OCF, but if I need one, I use a Nissin DI 866 mk. II which tilts, swivels, can be taken off camera with an eTTL-cord or wireless. For portraits, I use my studio strobes.
Im am not a professional photographer. I rarely bring my 7D on travels, as a tourist I use my S100. The S100 never ceases to amaze me. It is versatile and offers lots of creative possibilities in a tiny package, and delivers more than acceptable IQ.
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF 50mm f/1.8 II +9 more
Traveller Veteran Member • Posts: 5,027
And You're Not Lazy, You're Just Smart...lol...nt
Traveller
JTuuti Forum Member • Posts: 62
Yes, for controlling remote units (NT)
No text.
Suave Senior Member • Posts: 1,220
Re: On board flash importance
I have never used a flash on my 7D, not a single time.  Don't think I ever will.
 Suave's gear list:Suave's gear list
Nikon D7000 Olympus PEN E-PL2 Canon EOS 5D Mark III Canon EOS 700D Canon EF 50mm f/1.4 USM +8 more
Re: Who is lazy?
Klaus dk wrote:
Ubi.
I thank you for your response and if i offended you... I don't care. You never hoisted a Bigma on a 7D with grip and two batts. The 7D onboard flash actually works well on long glass too. But, thats something you'll never know since you are a tourist?
Re: No
Ubi.
I am confused.  You obviously use on-board flash... In OP:
then you go on to argue that the reason photographers with pro-grade bodies need to carry extra units is because they do not have the built-in ones.
You seem to be very Pro-onbord-flash, yet you call ppl lazy [for not carrying the extra gear with them?] I don't get it...
By the way, why don't you test to see what kind of image quality you get with your 7D's built-in flash vs. a properly set-up speedlight.  I think you just may find that the difference is about as significant as it is.. well.. between a P&S or a smart phone and your 7D.
Although I do agree the built-in unit may come in handy for fill flash, but even the lowliest, 100% pocketable 270EX is sooo much better there is really no reason to use the built-in one.
alberto888 Junior Member • Posts: 49
Re: Who is lazy?
+1.
OCF is important n handy. Imaging what happens if your 600ex flash suddenly damaged in the middle of a portrait takes... I always use -1 on my 7D ocf for a quick portrait or head shots.
(unknown member) Senior Member • Posts: 5,590
Re: Who is lazy?
5
Ubilam wrote:
Klaus dk wrote:
Ubi.
Fortunately petulance is something most adults grow out of.
Alastair Norcross Veteran Member • Posts: 5,548
I use it occasionally for fill flash outside. It's useful for that. If I want decent quality flash shots inside, I use my 430EXII, either with a softbox or an omnibounce. I also find the external flash with a softbox is perfect for macro, but the OCF will do for that in a pinch. So, I suppose I like having the onboard flash, but it wouldn't be a deal killer to be without it. If I had the money, I'd get a 5DIII right now, and almost certainly not miss the onboard flash. I had film SLRs for 25 years without onboard flashes.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD450 Canon PowerShot SD870 IS Canon PowerShot S45 Pentax Optio W60 +16 more
Zee Char Forum Pro • Posts: 10,877
No. At one time it was helpful for optical transmission for OCF but I never used it for anything else. Light source is far too small to be of use to me.
 Zee Char's gear list:Zee Char's gear list
Canon EOS 7D Mark II Canon EF 300mm f/4.0L IS USM Canon EF 70-200mm f/2.8L IS II USM Canon Extender EF 1.4x III Sigma 2x EX DG Tele Converter +3 more
rndman Senior Member • Posts: 1,595
Re: Yes for macro
Regards Rod
I would say that's some use of the OCF. Good work..
 rndman's gear list:rndman's gear list
Rokinon 14mm f/2.8 IF ED MC Rokinon 8mm f/3.5 Aspherical Fisheye
Limburger
Limburger Senior Member • Posts: 6,456
It's my IR transmitter
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100
MisterPootieCat
MisterPootieCat Veteran Member • Posts: 3,121
Better than a poke in the eye with a sharp stick
Any flash is better than none. The wireless flash function on the 7D is icing on the cake for me.
The 1 series pro cameras have serious weatherproofing, my guess is the pop-up flash would be a nightmare to weatherproof. But I don't know why they refuse to put one on any of the 5D bodies.
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon EOS 40D Canon EOS 300D Canon EOS 7D Canon EOS 80D Canon EF 50mm f/1.4 USM +22 more
scorrpio
scorrpio Veteran Member • Posts: 3,388
I find onboard flash inadequate.   Use it only as wireless control.  Especially in the light of that 'why won't you take your best gear' comment:   why won't I take my best flash unit?   I dismount the Speedlite from my camera only when I pack it into bag for transportation.   (Or to use it off camera)
Standard neck strap makes carrying a camera with flash awkward at best.  Sling-style strap like BlackRapid RS-7 makes carrying a camera with flash attached a LOT more comfortable.
A pro body user is not going to rely on built-in flash for backup.   He will have 3-4 580's in the bag.
NancyP Veteran Member • Posts: 5,316
7D on-board flash is a controller for off-camera slave flashes
That could be very convenient and save a bit on speedlites. You could buy the 430 EX I/II to slave as your "main" flash and use your on-board flash at very low power for a "fill" flash.
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
Re: 7D on-board flash is a controller for off-camera slave flashes
I should add, I have a 60D, I use the on-board flash as main flash only on rare occasions, and I don't expect good looking pictures, just documentation. I don't like the straight-on flash flatness. If the 60D on-board flash was a control unit, I would use it as such.
Macro: I have a MT24 EX double flash unit which I am learning to use, flashes are NOT on axis and can be individually adjusted re: power and position. To my amazement, I can get decent looking hand held 1:1 photos in dim light. I can hardly wait until warm weather and insect/spider activity.
Sigma DP3 Merrill
