Is this something I should worry about?
Started Mar 26, 2013 | Questions
Mako2011
Mako2011 MOD
Forum ProPosts: 19,205
bottom
In reply to Sensei Mike, Mar 26, 2013
Sensei Mike wrote:
No there no distractions in the top of the frame.
Check the bottom of the frame...there are a number of the exact same effect in the unprocessed OOC jpeg. The one covering the smoke stack actually starts at the bottom of the frame and goes up...IMO
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
mosswings
Veteran MemberPosts: 7,109Gear list
Re: bottom
In reply to Mako2011, Mar 26, 2013
+1.  I saw the OOF smudges along the bottom right of the frame as well. My vote is for some lower foreground dry grasses.  The 2nd shot looks clean, and there aren't any foreground objects.
 mosswings's gear list:mosswings's gear list
Olympus XZ-1 Olympus Stylus 1 Nikon D90 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +5 more
carandu
New MemberPosts: 9
Re: It shows up with some PP
In reply to Whalligeo, Mar 26, 2013
I had the same problem. Much more noticeable and during a long exposure.
I'm returning the camera.
Mako2011
Mako2011 MOD
No problem
In reply to carandu, Mar 26, 2013
Your problem resulted from you not covering the viewfinder during long exposure as the manual states. I tested now on two diffrent bodies (D70 and D7000) and confirmed your result is normal. The OP's problem here seems to be obstruction in front of the lens. See the OOC unpressed pic he posted..the obstructions are more obvious.  Both indicate no problem with the camera, likely.
photoreddi
Veteran MemberPosts: 6,192
Re: I see 6...
Mako2011 wrote:
Sensei Mike wrote:
Here is the SOOC jpg, it was processed in the Lightroom 4, the lens was 70-300vr.
I see six of the same lined up at the bottom of the exposure... getting bigger left to right. Largest falls on the smoke stack. Looks like there was grass or something in front of the lens when yo took the shot. Since it's not in the other shots...I assume you moved the car or moved the lens. Using a telephoto, we often don't notice close obstructions.
Sherlock, you've returned!
Whalligeo
Regular MemberPosts: 245
Re: Heres on shot at the same time.
I don't think you have a problem. As someone above says the mark seems to extend down into the water. It is quite possible its caused by something like a blade of grass close to the lens. Carry out a few tests to confirm, but I think your ok.
They said it couldn't be done, so I encouraged my peers not to bother.
Horshack
Veteran MemberPosts: 5,740
Lens looks decentered
Doesn't have anything to do with your issue but the right side looks badly decentered vs the left.
Sensei Mike
Contributing MemberPosts: 522Gear list
Re: Is this something I should worry about?
Thank everyone for your comments, I'll look in to that focus issue on my 70-300vr.
I went out and took a bunch of shots this morning and don't have any repeat issues of the haze.
Phew!!!:-D
 Sensei Mike's gear list:Sensei Mike's gear list
Nikon D300 Nikon D7100
Sensei Mike
Re: Lens looks decentered
In reply to Horshack, Mar 26, 2013
Is this something I fine tune or should send it in to Nikon?
Mako2011
Mako2011 MOD
If it is decentered...only Nikon can fix that.
poidog73
New MemberPosts: 17
In reply to whiggy, Mar 26, 2013
whiggy wrote:
Did you shoot this through some tall grass? That's what it looks like to me.
That's what it looks like to me, especially if shooting from height of car seat - it looks like the same stuff that's growing on the other side of the water.
pixd90
Senior MemberPosts: 1,354Gear list
Surprised nobody picked it up that you are canadian. If you look at the bottom left you will see that its the dreaded "french Canadian red smog creature".  They show up now and increase until April 1st.
 pixd90's gear list:pixd90's gear list
Nikon D90 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G
Sensei Mike
In reply to pixd90, Mar 26, 2013
I thought I had too may beers eh!
