Choosing between spyder 3 and 4
Started Mar 26, 2013 | Discussions
murcielago New Member • Posts: 14
Not sure if this is the right place to post this.
Basically I need to calibrate the hopelessly out of contrast lcd screen on laptop which has a glossy screen and maybe calibrate my PC's LCD which has a glossy screen as well.
i read somewhere that spyder 3 removed some ambient light sensor or luminance light sensor from spyder 2 and put it back in spyder 4 ?
anyway the key problem with my laptop is that when the background is white and the words are grey/black, it becomes hard to read. furthermore if the room has bright even lighting, the words become unreadable unless i crank up the brightness which become very glaring to me. turn down the brightness and it becomes hard to read.
should i get the cheaper spyder 3 pro or the more expensive spyder 4 pro?
malch Forum Pro • Posts: 13,126
Re: Choosing between spyder 3 and 4
The Spyder3 isn't made anymore. On the plus side, you may be able to pick up a used one cheap on Ebay, Craigslist or whatever.
I'm not at all sure either of them is going to help significantly with that problem.
willvan Senior Member • Posts: 2,116
I have Spyder 4 pro which I use on my Asus laptop and on my Desktop. I was pleasantly surprised by the difference it made to my laptop and if I recall correctly, the program did not call for the ambient light detector when calibrating the laptop but it did on the desktop. Both are glossy screens and I do not have an IPS monitor.......wish I did but the moderately priced Samsung on the desktop is quite good, particularly now that it is calibrated. Can't speak to the Spyder 3 as version 4 is my first.
edit:  Malch is probably right that if you have a more specific problem than simple calibration, even Spyder 4 may not be able to resolve your issue.
Bill
murcielago OP New Member • Posts: 14
yes i intend to get it from ebay/amazon etc
I figured my problem with the lcd is a question of contrast, colour balance because when i compared it to my LCD monitor, it appears much "cooler" in colours
hotdog321
hotdog321 Forum Pro • Posts: 15,742
I, too, think you may have some sort of issue with your monitors. And, of course, you should work in a dimly illuminated room, but that might be impossible.
But for what it is worth, I'm using an old Spyder 3 Express on my Win 7 desktop and laptop and it works fine for color control. I shoot for newspapers, magazines and wire and no one has ever had an issue with my color balance.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
hmm
i guessed my problem with the lcd is a question of contrast, colour balance because when i compared it to my LCD monitor, it appears much "cooler" in colours
am i mistaken somehow?
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
you cant compare those to each other
you cant even compare to like laptops because there is a good chance they are slightly different.
JMO
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
Pictus
Pictus Veteran Member • Posts: 5,572
Between the them, I prefer the 4...
Get a 4 Express and calibrate this way
http://forums.dpreview.com/forums/post/50454217
http://forums.dpreview.com/forums/post/50741555
But your problem is trying to use a glossy screen in bright room...
actually it's not that bright as u think.
