So what's the best printer under $100?
Started Mar 26, 2013 | Discussions
vjk2 Regular Member • Posts: 231
It looks like the Selphy CP900 is the only game for dye sublimation. What about inkjets?
Serhat Abaci Regular Member • Posts: 265
Re: So what's the best printer under $100?
i would  go for an Epson dye 6-color based printer...
had FOUR Epson Stylus Photo P50 (europe) T50 (US i think)
I used them on prom events to print out fotos directly on the event for 2-5€ per print since
all cartriges i used are refillable ones and high quality dye ink options are cheap as hell.
I actually even recorded a 10min video of my printer for the ebay auction
http://www.youtube.com/watch?v=wFfDuyBo8nE
dont mind its german but there you have an slight view how GOOD acutally the print quality is on glossy photo papers. Its just awesome!
I did print A WHOLE LOT of 10x15cm Prints and 13x18cm borderless.
All Epson Desktop Photo Printers and Photo AIO (All in One) Units I had come in contact that uses 6 Colors (Light Cyan and Light Magenta added to C Y M K ) have just fantastic results.
I myself have an 13x19 Epson Stylus Photo 1400, in the US the epson desktop printers
with photo capabilites called Artisan, you should even look for a used unit on ebay or craigslist...
 Serhat Abaci's gear list:Serhat Abaci's gear list
Canon EOS M Canon EOS Rebel SL1 Canon EF 40mm f/2.8 STM Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +3 more
JulesJ
JulesJ Forum Pro • Posts: 39,635
I don't know but my experience of printers under $100 and I have had three in the last few years, is that a new set of inks for them will also cost you $100. we had one multi use Canon (scanner, printer, card reader etc) and one day it came up with an error number and wouldn't work. Googling I discovered that it was irreparable. Junked it. So my view is they are fine for testers and ringing out web info, but not great for photos.
Jules
ukkisavosta Regular Member • Posts: 171
I agree
I agree.
If a used unit will do, you can find a used 6-color dye ink Epson for as low as 10 bucks. A set of refillable carts will put you down 15 bucks, and a set of dye inks, good for 5 fills, can be had for as low as 10-15 bucks. Color neutrality might be a problem, but I'm sure that there are neutral inks available for a bit more... it helps if you can profile your inks & papers.
The quality is unbelievable, considering how little you actually need to spend.
Jaakko
