Copying EXIF 'date taken' to Windows file name
Started Mar 25, 2013 | Questions
Paul Barrett Regular Member • Posts: 103
I have several hundred images which have been copied onto my PC and acquired the same file date. I need to restpre this to 'date taken' from the exif data. I read somewhere that irfanview might d this but I can't see the option in the copy I just downloaded.
All advice gratefully received, either on irfanview or any alternative batch method
Shalom2006
Shalom2006 Regular Member • Posts: 260
Re: Copying EXIF 'date taken' to Windows file name
Not sure if this helps?
http://graphicssoft.about.com/cs/renamers/ht/acdsee5rename.htm
Best Regards
Steven
Chigwell, UK
 Shalom2006's gear list:Shalom2006's gear list
Canon EOS 5D Canon EF 24-105mm f/4L IS USM Canon EF 70-300mm f/4-5.6 IS USM
rio911
rio911 Contributing Member • Posts: 973
 rio911's gear list:rio911's gear list
Sony RX100 Sony SLT-A77 Sony 50mm F1.4 Sony 70-300mm F4.5-5.6 G SSM Sony DT 16-50mm F2.8 SSM
malch Forum Pro • Posts: 13,126
If you're willing to install Perl and the Image:Exiftool module, you can use a script something like this:
http://www.malch.com/nikon/perl.txt
CAcreeks
CAcreeks Veteran Member • Posts: 8,933
Paul Barrett wrote:
I have several hundred images which have been copied onto my PC and acquired the same file date. I need to restore this to 'date taken' from the exif data. I read somewhere that Irfanview might do this but I can't see the option in the copy I just downloaded.
Yes Irfanview can do this. It is a bit complicated.
  1. Select menu File > Batch Conversion/Rename.
  2. Click radio button Batch Rename.
  3. Under Batch Rename Settings, click Options.
  4. In the Name Pattern box, type $E36867-# (see below).
  5. Possibly change other settings and click OK.
  6. In Output Directory for Result Files, select a folder.
  7. On the right side, select files to rename.
  8. On lower left, click Start Batch.
The $E means EXIF tags. Number 36867 designates date and time of the original. The -# adds sequence 1-9  in case date and time are identical.
rio911 wrote:
I think this will be more useful:
https://irfanview-forum.de/showthread.php?t=5147&highlight=exif+rename
I think the OP wants to set the file created/modified timestamps to the date/time the image was captured. That's very different from embedding the date/time of capture in the file name.
Paul Barrett OP Regular Member • Posts: 103
Thanks for the advice CAcreeks but, having tried that out it, it does not do what I want.  The most likely reason is operator error (usually is with me!).
I think I have followed your instructions correctly:
But the results I get are not as expected.  What I wanted was the date taken to be substituted for the windows file date and time.  What I got was the fields renamed with a sequential number and an unchanged windows file date and time stamp:
So, 'close but no cigar.'  Any further ideas pls?
Correct.  But you know what?  I'll do what rio911 suggested if there's no way to do what I want.
OP
It can certainly be done. How many images do you have and how big are they?
I'd be happy to do it for you if you can get them to me on-line or even via snail mail.
rio911
OP
Oooops,
sorry guys, I did not read the question like that.
My question is why do you need it?  Sorting the files? Getting the date and time in the file name will achieve a similar sorting ability.
Good luck,
rio
Heinrich Schulz Regular Member • Posts: 139
Based on your file output it seems as if 1) there might not be EXIF info in the files, or 2) the EXIF is not read for some reason.
1) Try to see if the EXIF date actually exist in the files (you can view it in Irfanview from the Image Menu->Information->Exif Info button-> DateTimeOriginal field)
Viewing EXIF info in Irfanview
, or
2a) make sure you use the latest version of Irfanview with all the EXIF related plugins installed (EXIF plugin is required!),
2b) make sure you use the exact correct name pattern without any spaces or special characters (see the irfanview help file for specific details - HELP button on the batch rename settings dialog window). I use the pattern $E36867_$E272_$F to rename to the Original date ($E36867) and Camera model name ($E272) and original file name with extension ($F) - and using the "Replace text" option to replace the : from the date format with _ underscores. It works perfectly every time.
My Irfanview batch rename settings
You can also use the "run test rename" option to see what the output for your selection might look like.
I suspect your problem might be related to not having the EXIF plugin installed in Irfanview...
That was the problem - no EXIF plugin.  Works a treat now.  Thanks.
Actually this has got me to a position that I did not anticipate.  It has put the date and time stamp into the file name not the file data and time attributes.  But that's actually better because it has allowed me to merge photos from 2 cameras with different naming conventionsinto one chronological stream
AxelR Senior Member • Posts: 1,147
Exactly, and you just gave me a feature idea for next weekend
Have fun with Time Zones, Daylight Savings and those horrible FAT/NTFS inconsistencies
The fact that EXIF doesn't make any TZ provision won't help either
Most users probably set their camera to the current wall clock time wherever they are, and manually adjust for DST so there is indeed no way for a program to be sure.
Still, an imperfect solution is better than "Jan-1-80" or some other arbitrary time and I think I can do something about this in the form of a batch-processing action that will do exactly what the OP hopes for, in a simple manner.
It could be done today in a crude way from a Custom Script action in FPV, with a couple-of-lines script using the Shell object ("Shell.Application"), but scripting is an advanced topic and the time-zones issues you mentioned would either need to be ignored, or handled explicitly by the script.
Yes, I think that would be useful.
It's pretty much impossible to handle the TZ/Daylight Savings issues fully automatically and correctly. I'm inclined to think that can be addressed quite simply by allowing the user to specify an offset (assuming the EXIF is simply localtime).
Sean Nelson
Sean Nelson Forum Pro • Posts: 11,776
If you were very clever, you could assume that the camera was always set to the local time zone and use GPS data and a daylight savings time algorithm to look up the time zone and calculate the UTC time...
CAcreeks
Yay! Glad you got it working.
(Just returned from a trip, catching up.)
