Connecting MBPro to TV
Started Mar 25, 2013 | Discussions
Vernon Snider Contributing Member • Posts: 903
Can a MBPro be connected to a CRT TV that has connections for a VCR?
I would like to show some pics that I have on my MBPro on our TV so that they are more easily seen by a number of people.
Thanks for your help.
Vernon
Howard Moftich Veteran Member • Posts: 7,861
Re: Connecting MBPro to TV
The term 'connections to a VCR' is not really enough information.  Do you know what *exact* connection it is?  Is it an 'F' type (the kind used for cable TV, a single screw-on nub w/ exposed center wire) or is it something else?
Tom_N Forum Pro • Posts: 10,242
What types of input does the TV have?
  • Screw terminals?
  • A F-terminal for a screw-on antenna cable?
  • A composite video input (single RCA jack, not counting the ones for audio)?
  • A S-Video input?
  • A component video input (three RCA jacks, not counting the ones for audio)?
  • A VGA input (unlikely, but found on some HDTVs)?
  • A DVI input?
  • A HDMI input?
Standard VCR output will be one or more of (antenna cable, composite video, S-Video), but if your TV can do better, and you're not making a VCR recording, I wouldn't limit your presentation based on that.
HDTVs usually have at least one of the good types of input (component, VGA, DVI, HDMI).  (Those allow greater-than-NTSC resolution without conversion to RF and back.)
Steve Mitchell Veteran Member • Posts: 3,313
With Apple TV and Mountain Lion, you can connect via Airplay.
 Steve Mitchell's gear list:Steve Mitchell's gear list
Apple iPhone 6 Apple iPhone 6 Plus
Only if you can connect the Apple TV box to the TV set (i.e., this CRT-based TV happens to be a CRT-based HDTV with a HDMI input).  Also, I believe that some Airplay features (mirroring?) may require fairly recent Mac hardware.
Vernon Snider OP Contributing Member • Posts: 903
  • Screw terminals?
  • A DVI input?
  • A HDMI input?
Tom,
TV has the following:
  • A composite video input (single RCA jack, not counting thenes for audio)
  • A S-Video input
Vernon
I don't know how much luck you're going to have, but that at least tells you what kind of cables or adapters to look for.
The ports or slots on a MacBook Pro that would be the most useful sources for video would be:
  • MiniDisplayPort or Thunderbolt port - look for a MiniDisplayPort-to-XXXXX adapter or cable.
  • DVI port (I'm not sure if MBPs ever had these) - look for a DVI-to-XXXXX adapter or dable.
  • CardBus 34 slot (found on 17" MBPs and older 15" MBPs) - might allow the installation of a miniature video card with one of those three types of output.
There might also be USB-based devices.  My impression was that those were normally used for low-resolution video capture, but perhaps some also allowed output the other way.
Another possibility - if you have a MacBook Pro with a Firewire port, and a MiniDV camcorder, might be to record a presentation to MiniDV tape and then use the camcorder to get the video to the TV.  Another workaround along the same lines would be creating a DVD-Video disc using the (dearly departed and sorely missed) iDVD or an application like Toast.
Thanks for your replies and help.  I appreciate it.
Vernon
